Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC (Read 459351 times) previous topic - next topic
AlxDroidDev
Following...
Just a quick question: has anyone from the Arduino team approached you to have you work in the official Arduino IDE that is about to be released (1.0.2) ?
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
eried
Following...
No, but it was never my idea.
I've been trying to help by doing small fixes to the environment since a couple of years, but the only users who experience most of the problems use windows, so I guess those issues seem to be not very important. You certainly care less for the platform you don't use.
Also, maybe 1.0.2 will be 1.5? I am not sure yet what one should I start to fix :D
My website: http://ried.cl
drjiohnsmith
AlxDroidDev
looks like its 1.5
It's off-topic, but it has been announced that there will be a 1.0.2 version shortly, for those that don't plan on working with the 32-bit Due.
It can be read here: http://arduino.cc/blog/2012/10/22/arduino-1-5-support-for-the-due-and-other-processors-easier-library-installation-simplified-board-menu-etc/
I have no idea why there will be a version 1.0.2, unless not all of the improvements planned for 1.0.2 made it to 1.5.
Lakes
In the Standard IDE this code displays correctly in the serial monitor.
But in yours its does not work.
Code: [Select]
//Manual Set Time example using Time.h
#include <Time.h>
  //setTime(hr,min,sec,day,month,yr);
  Serial.begin(57600);
  Serial.println("Serial Connected");
  Serial.println("Manual setTime Example");
     if(timeStatus() == timeNotSet){
    Serial.println("Please set the Time");
    TimeSet();
  else{
   // Serial.println("time already set");
      digitalClockDisplay();
void digitalClockDisplay(){
  time_t t = now();
  Serial.print("");
  Serial.print("Val t = ");
  Serial.println(t);
  Serial.print(day());
  Serial.print("/");
  Serial.print(month());
  Serial.print("/");
  Serial.print(year());
  Serial.print(" ");
  Serial.print(hour());
  Serial.print(":");
  printDigits(minute());
  Serial.print(":");
  printDigits(second());
  Serial.println("");
  delay(5000);
void TimeSet() {
// Input time
  Serial.println("Input time Day dd");
//  day[3] = 0;   //null char
byte Days = 0;
  for (byte x= 0; x < 2; x++)
  Days = (10* Days) + wait_read();
   Serial.print("Day is Set to ");
   Serial.print(Days);
  wait_read();     // nl char is discarded
  Serial.println("Input time Month mm");
byte Months = 0;
  Months = (10* Months) + wait_read();
   Serial.print("Month is Set to ");
   Serial.print(Months);
  Serial.println("Input time Year yy");
   byte Years = 0;
  Years = (10* Years) + wait_read();
   Serial.print("Year is Set to ");
   Serial.print(Years);
  Serial.println("Input time Hours hh");
byte Hours = 0;
  Hours = (10* Hours) + wait_read();
   Serial.print("Hour is Set to ");
   Serial.print(Hours);
  wait_read();     // newline char is discarded
  Serial.println("Input time Minutes mm");
byte Minutes = 0;
  Minutes = (10* Minutes) + wait_read();
   Serial.print("Minutes are Set to ");
   Serial.print(Minutes);
  Serial.println("Input time Seconds ss");
byte Seconds = 0;
   Seconds = (10* Seconds) + wait_read();
   Serial.print("Seconds are Set to ");
   Serial.print(Seconds);
  setTime(Hours,Minutes,Seconds,Days,Months,Years);
}  //End SetTime
//    Wait for Serial Input
char wait_read (){
  while(!Serial.available())     // Do nothing while waiting for input.
The conversion of a character that contains a numeric value that corresponds to a number
can be converted to the number by subtracting the char value '0' from it.  Char '0' = Dec 48
  byte num;
   byte t = Serial.read();
    if (t  >= '0' &&  t <= '9'){
      num = (t - '0');
     // Serial.print("Number Converted to");
     // Serial.println(num);
       return num;
}  //   End wait_read Function
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
eried
uhm... can you record a screencast video or something with the problem?
Lakes
I could do, will a couple of screen shots comparing two serial monitors do for now?
eried
Yes, some way to debug it
Lakes
eried
Thanks, I will check but it seems something with the font? can you change the font, or use the same settings in both?
By the way I updated the IDE today. The bug about the comments is fixed and there is a font settings now as you requested.
Lakes
I`ll check that tomorrow.
Quote
Fantastic! <insert thumbsup emoticon here> :)
guix
Hello, I have another suggestion that is easy to add (I think): a setting ine the config file, for scroll speed. I find the scroll speed (when selecting things in the editor) is way too fast, it's hard to select just what I want :)
eried
Already fixed 8) test it in the one you have installed.
guix
Sorry but I think it's not working then! It's still fast like the original IDE, I don't notice any "linear acceleration". I have version 1.0.1h, downloading latest now.
Edit: ok working with latest 1.0.1i, good work, thanks 8)
eried
Hehehe, yes version 1.0.1i and up. Someone asked for this describing the problem as "screen of custard", but he uses the 0022 so he maybe never will enjoy the enhancements. :smiley-roll:
