Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC (Read 578902 times) previous topic - next topic
eried
G'Day,
I've been trying the mod with good results except when I drag the top of the window upwards to the top of the desktop to have the window full length (Win 7 Home premium 64bit). When I do that it freezes until I reduce the height o f the window.
Cheers ............ Mike B
Oh, never noticed that before, I don't use that vertical snap too much. I will look if I can fix it, happens the same with the original IDE
Would you be interested in helping me with my new IDE?  I'm a GUI expert but I'm not a Windows user so the Windows experience for ArduinoX will always be sub-par. I'm especially interested in your expertise with app packaging and drivers installation.  I have no idea how to do those.
- Josh
Sure Josh. Tell me what we can do.
My website: http://ried.cl
AlxDroidDev
Just a quick Q: does the installer install its own Java runtime?
Yes, it uses an internal (updated) java runtime
Can the installation of its own java runtime be optional, if I want to use my already-installed Java runtime?
The thing is that since I use a SSD drive, I am a bit (too) concious about wear leveling, so I tend to limit the writes as much as possible in the SSD drive. Besides, space is kind of a constraint as well.
Yes, but without it, the package will stay the same in size, it will only skip to write the Java folder, that is what you want? (another option is to detect if java is present and only download it if is not in the machine) in that way the package probably will be less than 5 MB in size.
Either way is fine for me, but the autodetect of a JRE at installation would be AWESOME!
What I am looking after is to minimize as much as possible the writes to the HDD at install time. This is a concern for those on SSD (my case), because there is a limited number of times each cell can be rewritten. So, if the setup program can install only the specific files (ie. no JRE), that would be great.
Besides, most people - specially those who are developers - already have a JRE preinstalled, so having a second one is unnecessary IMHO.
Anyhow, thank you for taking the time to look into my suggestion.
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
eried
For the next minor release I can add a "non-java" package and if some people download that version, I will keep uploading that one.
By the way, I don't have experience with SSD in my dev machines, but in my ultrabook I have one and I am certainly not worried about write cycles, I am pretty sure they design the drives to stand usual usage up to >4 years (where due capacity and speed, it is not convenient to keep the old drives anymore)
pico
Is it possible to install your 1.0.2 IDE package in a location other than \Program Files\Arduino?
When I move the installation to another directory (\Arduino) the IDE complained it couldn't find avr-g++ (even though the path it showed was in fact correct after moving the directory). I assume there is some registry value that is causing issues?
It gets quite confusing with multiple location of the sketches directory and the libraries directory when you have more than one version of the IDE installed.
Ideally I'd like to be able to specify a directory for "libraries", in the same way you can now specify the "sketches" dir. This would mean that I could maintain all my source user-level directories independently of particular IDE installations.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
pico
Also, does your pakage of 1.0.2 have the latest version of avrdude included? I was trying to build and upload for a mega2560 target, and avrdude complained it didn't have a definition for the "wiring" programmer (in earlier version, the programmer option passed to avrdude was "stk500v2" for the mega2560, I think. The "wiring" thing is new.)
Replacing avrdude2.exe and avrdudre.conf with a recent version fixed this. I haven't tested out the "official" 1.0.2 yet, to see if in fact the later version is bundled in that release.
jrlp
Pico,
I ran into the same problem you did today, as I just installed the software. It seems wiring isn't a known protocol for some reason. I changed the configuration file to try arduino as the protocol, but it would fail and not upload. So I changed it to stk500v2 and works like a charm.
In C:\program files (x86)\arduino\arduino erw 1.0.2\hardware\arduino the file is boards.txt
mega2560.upload.protocol=wiring
gets changed to
mega2560.upload.protocol=stk500v2
on line 136.
Works like a charm, I'm sure it will get fixed next revision. I'm not sure if this is the proper way to fix it, but it does _work_ in my limited testing!
pico
Also, how do you get extra board definitions included in the enhanced release (e.g., the ATtiny* chips)?
I copied the "tiny" subdir into the "\program files\arduino\arduino ERW 1.0.2\hardware" subdir, but no go... they didn't show up in the boards list at the next restart.
eried
How are you moving the installation? You need to uninstall it and then install it in another path (or manually change the PATH environment variable)
You need to edit boards.txt (try to backup the old one because it contains the "ram" size, and that's not a default thing)
BTW, did the jrlp's suggestion worked for the protocol issue?
pico
I was just cutting and pasting the top level directory from \program files\arduino to \arduino
OK, I've changed the PATH variable in environment settings.
How about specifying a path to user libraries? Is this already possible with your library manager?
Don't need to do this step with the "official" IDE -- what's the specific changed feature that requires this?
Will the build step correctly find the hardware\tiny\bootloaders and hardware\tiny\cores subdirectories if I simply add hardware\tiny\boards.txt to hardware\arduino\boards.txt?
Edit: Actually, copying the "tiny" directory into "hardware" DOES work, without having to modify anything else, now that I've moved things around out of \program files\arduino. Maybe I had copied the "tiny" directory into the wrong place before, I may have been getting confused as to where things were...
This all seems to be working well. This is very good, now I think I keep just two copies of the IDE on disk, the 0023 version for all my pre-1.0 stuff that I don't want to bring over to 1.0.x for whatever reason, and your EWR 1.0.2 for all the newer stuff. (Actually, there is a third version of the IDE installed, which is for the Teensy 3, but that's based on 1.0.2 so that may be able to be merged as well, but I haven't looked into that yet...)
But the 0023 and the EWR 1.0.2 won't clobber each other every  time they are run, which is great! Almost a sane set-up! Another Pepsi is on the way! ;) (BTW, did you look at the feasibility of the "no automatic prototype generation" option for the IDE preprocessor? What do you think?)
I don't know, I had already solved it by copying over a later version of avrdude that had the "wiring" programmer definition in avrdude.conf file.
I would fully expect it work, however, since up until recently stk500v2 _was_ the correct protocol for the mega2560, I believe... so if it worked before why wouldn't it work now? Unless they have changed something with the new mega2560 bootloader (but that would only affect those who had updated their bootloader, and I haven't read that anywhere.)
So  I don't know what the story is with the new "wiring" protocol.
Which version of avrdude is your distribution? The one I used to replace is v5.12.
Magicj
eried
Hi, thanks for the Pepsi :D, well not really, they are dependent on the user sketch directory, that can be modified but I think is more a hustle than something useful. You may look at "hard links" in Windows (mklink command) and create a hard link to the libraries in the other directory (to keep only 1 copy of the libraries but many folders as 'virtual' accesses)
Haven't checked this. I was trying to fix the resize window problem but it seems is something in java and it is not fixable (it was reported for win7, 2 years ago).
5.10
It did for me  :)
Nice!
jrlp
pico
Really? How so? I thought the libraries directory was always under the "main" install directory, along with "hardware", "lib" "drivers" etc. How does it's position change relative to the sketch directory?
Confused.  :~
dxw00d
Quote
The standard libraries are under the IDE main directory. Third party libraries are meant to be stored in a libraries sub-directory of the sketchbook directory, so that they are independent of the IDE installation.
pico
Quote
Oh, OK, thanks, I never realised that. I've always put all my libraries, and any third party ones, in the default one. I thought they needed to be there so the build could find them.
Still just use the #include <mylib.h>, and the build will find them?
