Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC (Read 537281 times) previous topic - next topic
eried
Thank you for sharing. Very good.
An question.
Do you think it's had to implement an intellisense for IDE editor like codeblock or visual studio ?
Well, yes and no. I will love to have intellisense, but not a crappy implementation... so for now I think you better try with VS plugin or eclipse plugin for Arduino.
My website: http://ried.cl
nid69ita
my name is IGOR, not AIGOR
gc9n
i have a problem adding libraries , i tryied to add for example SoftPWM library
https://code.google.com/p/rogue-code/wiki/SoftPWMLibraryDocumentation
and when i launch the program hang , and terminated.. is this normal?
eried
How you added the library? I tested that softpwm lib and it Works nice: http://screencast.com/t/zktXVt1lB1H4
gc9n
ok , i just paste the folder and its contents into the C:\Program Files (x86)\Arduino\Arduino ERW 1.0.4\libraries
i have the win 7 home
eried
Well, you shouldn't paste it there directly (also that folder requires administrator privileges), as you can see in the video, this 'enhanced' ide will even auto detect the things inside the library automatically, so try that way. Just click "Manage libraries..." and "Add"
gc9n
Ok i will try that. , i think this way send the libraries into the folder
my documets\arduino\libraries
eried
karl_eller
Any chance of you being able to add line numbers to the code window? Or is that beyond what you're able to change in the IDE?
ttttkk
Great job! But one question though. Mine is duemilanove w/328p, when I tried upload a sketch, it said [font=Verdana]"avrdude.exe: stk500_getsync(): not in sync: resp=0x00"[/font]. But in fact I got the same message while uploading with official IDE 1.0 or above. On the contrary, I received no error message if using 0023 IDE. Do you happen to know how to fix it? I know it is nothing related to your program, but this problem has been troubling me.
eried
It is possible as a hack I think. It depends on how much is wanted by the users :D
Hi, there is another item in the boards called "duemilanove w/328" without the "p" can you test that one?
Sembazuru
I guess, count this as vote #2. (I haven't checked if one can print from the IDE, I'm not near my PC at the moment. But if printing is there please also add line numbering there as well. If that is too hard, I can always print with line numbers from PSPad...)
http://www.catb.org/jargon/html/I/I-didn-t-change-anything-.html
Docedison
Enried, I want to take this chance to publicly thank you for a really valuable addition to the IDE and as much as I would love line numbers... I can wait until it happens, quietly now....  <BFG>
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
