Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC (Read 517753 times) previous topic - next topic
eried
My website: http://ried.cl
Lopez_Lou
Thank you for your reply, and, once again, sorry for everything.
I don`t want to disturb anyone anymore because it can be a little out of topic so I think it is better to give you my topic where I have explained all my problem (with the error) and where our replys will not disturb anyone. Here it is http://forum.arduino.cc/index.php?topic=165461.0.
Thank you very much.
eried
I was closing some requests for next version (already 3 implemented brand new features  8)):
https://github.com/eried/Arduino/issues?labels=enhancement&page=1&state=closed
But, there are some usability "issues" I need to ask people who uses this version.
1) I was thinking to include Teensy stuff as default. (Ordered couple boards and it is just too amazing to not include... or to use the ugly official one  :smiley-roll:) any suggestion/concern? (filesize will increase around 5 MB only, and I have to figure out how to add the Serial installer for that board)
2) https://github.com/eried/Arduino/issues/8 <- anyone votes this up/down?
3) https://github.com/eried/Arduino/issues/7 <- senseful options this may require? just to switch from 4 spaces to 1 tab?
4) https://github.com/eried/Arduino/issues/3 <- autosave on compilation? AND/OR verification? option to disable visible in preferences? or asume True always as any modern IDE?
I think I can implement all the remaining ones easily, the only difficult one is https://github.com/eried/Arduino/issues/1
Thanks!
pico
1) I was thinking to include Teensy stuff as default. [...] and I have to figure out how to add the Serial installer for that board
This would be cool if you could do it, but I suspect that the external serial uploader Paul built might be hard to emulate in the standard IDE.
WiFi shields/Yun too expensive? Embeddedcoolness.com is now selling the RFXduino nRF24L01+ <-> TCP/IP Linux gateway: Simpler, more affordable, and even more powerful wireless Internet connectivity for *all* your Arduino projects! (nRF24L01+ shield and dev board kits available too.)
eried
I will re-use the same stuff, just thinking on recreate the differences between Arduino - Arduino with Teensy - Arduino modded
There is not a lot to copy (I am not sure if source is available, but I can use the compiled ones because the changes are small and I can even look the decompiled byte code to detect the changes, it is usually a new if/var or setting I have checked some files already):
Jantje
eried
If you want to support the teensy stuff Paul will be glad to help you.
He helped me with the implementation in my eclipse plugin. Basically there are 2 commands to run.
Below is a copy of the teensy part of Arduino 1.5.2 platform.txt which shows the commands to run.
Quote
# Teensy Uploader/Programmers tools
tools.teensy_reboot.config.path={runtime.ide.path}/hardware/teensy/tools/mac
tools.teensy_reboot.config.path.linux={runtime.ide.path}/hardware/teensy/tools/linux
tools.teensy_reboot.config.path.windows={runtime.ide.path}/hardware/teensy/tools/windows
tools.teensy_reboot.upload.params.verbose=
tools.teensy_reboot.upload.params.quiet=
tools.teensy_reboot.cmd.path={tools.teensy_reboot.config.path}/
tools.teensy_reboot.name=Teensy upload
tools.teensy_reboot.step1.pattern={tools.teensy_reboot.cmd.path}teensy_post_compile -path={build.path} -file={build.project_name} -tools={tools.teensy_reboot.config.path} -board={name}
tools.teensy_reboot.step1.name=Teensy post compile
tools.teensy_reboot.step2.pattern={tools.teensy_reboot.cmd.path}teensy_reboot -v
tools.teensy_reboot.step2.name=Teensy reboot
The code I build is very generic and yust does step1 step2 ... until no info is found.
That code is open source in case I forgot something in the platform.txt
So there is no need to reverse engineer to support teensy ;-)
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
eried
Yes, thanks. I already asked Paul and the source was being installed next to the main files :) (doh! didn't noticed that and I was just analizing the jars) so not need to reverse engineer.
hole
Eried, I'm just resting from a hour long search without any findings... But from the beginning: from now to then ERW stopped  loading the IDE, "launch4j an error occurred". I'm not sure what I did wrong...
Debug log showed nothing, so I stated poking around. I found that after deleting the "arduino/libraries" folder ERW starts fine. Restoring the folder, error.
So I installed the original IDE, copied the libraries folder from ERW to ORG, tried, starts OK.
So I deleted the libraries folder and merged the folder items by item, everything fine until I merged the last folder.... But: it isn't the folder. If I remove any random folder ERW works. If I add back that random folder I get the error.
Could it be that there is a libraries limit?
eried
Where exactly are you placing the libraries? Can you paste the path here?
There is a *limit* in the system libraries (I noticed when adding Teensy code last friday). The limit is based on the menu height (based on your screen dpi, and resolution). If you go to the library manager and click "browse" libraries and copy the libraries in that folder while you leave the library manager opened: does the problem still happens?
hole
libraries are in C:\Users\hole\Desktop\Arduino ERW 1.0.5\libraries
And bingo, you are right. In my cold shed I have a small monitor (1024x786) and remote I have as much as I want... and remote it does work.
Anything to fix that problem beside buying something bigger for my shed? :-)
eried
Well I am not sure if you have too many system libraries installed in c:\program files ... but for the moment there is nothing to do, the problem is already fixed but I still don't finish all the testings like to compile a new version
hole
Sounds good to me and I can live with it. I now know the reason so I can avoid it.
My setup is a portable one, I have everything in one folder on the desktop. Idea was to have it on a network drive, but my NAS is too slow and compiling a pain. So I have my main repository on the NAS and "localize" it by syncing the folder.
mcsean2163
I'm having the same issue with this installation, (Arduino ERW 1.0.5), that it is meant to resolve, namely the splash screen appears but the IDE does not.
Any ideas where I have gone wrong ?
Sean
eried
Sean
Do you have too many libraries too?
hole
Just for information and our all enjoyment... :-)
I moved from WINAVR to "MHV AVR Tools - A WinAVR Replacement". Code size of a random project changed from 12720 bytes to 11926 bytes. And as far as I see, everything works as before only with a current gcc toolchain.
Move is easy:
1. download http://www.makehackvoid.com/sites/default/files/MHV_AVR_Tools_20131101.exe
2. install somewhere, remember the folder name
3. after install, copy this folder to your desktop and rename it to avr
4. uninstall "MHV AVR Tools - A WinAVR Replacement" (installed in step 2. open folder, run uninstall)
5. open your Arduino-IDE folder, go to hardware\tools
6. rename "avr" to "avr org"
7. move the folder from step 3 to this folder
8. delete avrdude.conf in folder avr\bin
9 copy avrdude.conf from avr org\etc to avr\etc
