Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC (Read 537072 times) previous topic - next topic
hole
Try this:
enter this into the IDE:
int blah;                                        // some comment
Now delete the comment starting with the //.
int blah;
If you press POS1 your cursor jumps to the begin of the line.
|int blah;
If you press END your cursor jumps to the end of the line.
int blah;                                       |
eried
I see what you mean, I will fix this, and try to implement the "upload hex" and then publish an update :)
My website: http://ried.cl
AlxDroidDev
Eried,
I understand you might be quite busy, but is there any chance any of my other suggestions be implemented? Specially the ability to explicitely specify the JRE folder to be used. Thanks.
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
eried
Eried,
Sure I can but, I need you to develop a little more your idea: Where this option should be? Can you do some tests running the IDE without the exe? (google for the bat and open the pde.jar), can you provide the 2 working bat files so I can fix the launcher? (the problem in this case probably resides on the launcher, not in arduino)
copet_pitik
:smiley-eek:  :smiley-eek: Hello World  :smiley-eek:  :smiley-eek:
Hello Eried,
I have a problem implementing how to fix a arduino blurry icon in win 7 taskbar
i downloaded your tutorial from here: http://servicios.ried.cl/arduino/temp/windows7_arduino-1.0.1_fix.rar
and when i try the 4th step, and run arduino it say:
"Could not read default settings.
You'll need to reinstal Arduino."
i also tried to replace the "awt.dll" in the "java/bin" folder
but nothing is solved so far.
P.S:
I am using Arduino 1.0.3
sorry if my English is bad
Program Studi Instrumentasi Medis
Politeknik Mekatronika Sanata Dharma
Yogyakarta Indonesia
eried
Hello Eried,
P.S:
You don't need that fix. Is bundled in this version. (also the fix is for 1.0.1, not 1.0.4)
psgarcha92
Hey eried,
By mistake i installed both the non-java version and Recommended version of your Enhanced Arduino 1.0.4 Package.
After a restart, one of the versions lost the Arduino icon, and shows up with "Unknown File" icon instead.
I have removed both and installed each one again, but i cant seem to get my Icon Back...
What to Do??
Regards
The Icon is like this, and it is the same way in Program Files (x86)/Arduino folder.
EDIT: I am on Windows 7 x64. Please Help.
eried
Manually delete the link from the desktop and then install the version you want (since both versions use the same link, the second one "respected" the existing icon, so it didn't removed it on the unninstall)
copet_pitik
Hello Eried,
P.S:
Okay, thanks Eried..
psgarcha92
@eried,
Thanks a lot...! Problem Solved.
Uninstalled, Rebooted, reinstalled and it worked like a charm.
Regards
dawiz711
I just had to say thanks, fought with the standard release for a sad amount of time before I found this. One liter of Pepsi coming your way my friend, my night just got alot better!
BobbyD
Eried ,
This installed perfectly. I have been trying to program ATTiny 85 for several days and run into a brick wall. I followed the same instructions with your 1.0.4 and it worked without a hitch .
Thank you for sharing !
BobbyD
eried
Try this:
int blah;
|int blah;
int blah;                                       |
Okay! it's Auto-format fixed now. Enjoy!
@eried,
Regards
Eried ,
BobbyD
Nice it worked fine for all of your machines.
PD: My pepsi stash is full for now! :D
hole
nid69ita
Thank you for sharing. Very good.
An question.
Do you think it's had to implement an intellisense for IDE editor like codeblock or visual studio ?
my name is IGOR, not AIGOR
