Pages: [1] 2 3 ... 33   Go Down
Author Topic: [MOD] Arduino Enhanced Release 1.0.5 for Windows (installer, drivers, etc) +SRC  (Read 99762 times)
Chile
Online Online
Hello there! this is a tweaked Arduino IDE, don't lose time setting up Arduino, Java or the drivers, just use this fully automated installer. Plus, you get a improved experience:
Download (2013-05-23):
* Recommended main package
* Light version without Java runtime
* Energia version (TI MSP430)
Less than 40 mb, for Windows XP, Windows Vista, Windows 7/8 (x86/x64), Requires .Net Framework 4.0 and nothing else required at all, no other app, package, drivers, just your arduino and brain. Want to keep me interested on improving our arduino experience?, so maybe you can buy me a glass of pepsi? (I love it! smiley-lol):
_____________________________________________
Features:
Note: There are few things actually implemented in some way in the official IDE, like the installation because this mod originally comes from Aug 2012.
1. Standard windows install
Couple of clicks and ready!
2. Driver installer
Prepares your system for the boards. Tested in Windows 8.
3. AVRDude wrapper/fixer
When uploading a sketch, if port does not respond the IDE will try to fix the issues instead of showing  you the "port already in use message", no reboot, no physical unplug/replug, finding the app using the port.
4. Menu with Scroll support and better organization
Lots of Sketches? lots of Libraries? lots of Examples?, No problems at all.
5. Pretty Windows Icon
No more blurry/ugly icons For Windows 7/8 taskbar.
6. No delays over Tools menu or at startup
Produced by some BT dongles (More information: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1237179908).
7. Sketch template
Start coding right away, the first sketch is compilable without pressing a key! The IDE finds a sweet spot to place the cursor for you. Also notice the fancy new font:
8. More and custom settings
Does not mess with other Arduino IDE versions and preferences (not even with official 1.0.1). You can go to Preferences and set another Sketch directory to keep your User librararies and sketches appart.
Also the font is customizable easily.
9. File association, desktop icon, Start menu program group icons
Small details for your own amusement
10. New library manager
Manage your libraries from Documents/Arduino/Libraries folder with ease and the IDE will reflect the changes without restart smiley
* Enable or disable them: Click the checkbox (disabled libraries will not appear in the IDE or their EXAMPLES)
* Delete library: Select library and press DEL
* Add library: Click ADD, then select the a proper file of the library or select a ZIP file (manager will handle everything for you)
11. More IDE enhancements!
* Undo/redo: Now remember the cursor position, almost unlimited buffer for undo
* Easy mouse selection: Now the selection with the mouse is slowed down to keep it controlable when selecting lots of lines
* Smart Reference!: Detect the selected word automatically, now you don't need to select the whole word or even a part! anything will work just right click http://screencast.com/t/dfp7m4vA7k
* More useful Copy/Cut functions: If you right click without selection, the action applies to the Line smiley-cool
* Hold Shift key on Verify: To get Verbose compilation
* Hold Control key on Upload: To open the Serial Monitor automatically when upload complete (do not lose a bit! from the Serial data or compulsivelly click the serial monitor button).
Additionally you can use the new option in File menu too:
Or maybe you just forget all of those things? so just click once and Schedule the Monitor to open automatically when upload completes:
* Options to get the Hex file path and open the Compilation folder in one click:
12. Better search and replace
Big project? Lots of tabs? No worries! Use the Search all tabs option:
13. Little Serial Monitor improvements
Hold the output unchecking "Receiving" when you like and/or set "AutoClear" to automatically clear the monitor output if more than 1 second elapsed since last data (debug anything with ease!), and reset button to manually reset some boards:
14. New WinAVR and RAM usage prediction
Official arduino uses ancient WinAVR (from 2008 or 2009), this version uses last one 20100110. Also based on http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1224729260/all (thanks to member dcb) IDE now shows ram usage to help begginers even more!:
15. Unninstall & small package
Not an improvement but as a normal windows app, includes an easy way to remove it smiley and the setup including java and everything you need is about 35 mb.
Source Code:
Java & .Net updated code:
https://github.com/eried/Arduino/
Commit History (features+source files):
https://github.com/eried/Arduino/commits/master
Changelog:
* 1.0.5 20130523: Updated to official 1.0.5 version. Some fixes in the Import library function. New option to avoid placing the cursor on the Setup function when opening a sketch.
* 1.0.4 20130331: avrdude wrapper now adds linebreaks to the received messages.
* 1.0.4 20130330: Reset button in Serial Monitor. Adding atmega328 to avrdude.conf. Auto format now removes extra spaces.
* 1.0.4 20130314: Updated to official 1.0.4 version. New options in preferences to reuse always the current window and open the serial monitor as default. Driver installer updated. Font now is Source Code Pro due licensing of the old font. PATH is not modified anymore (uninstall previous version is recommended). Replace All button does not hang the interface anymore. Tab switching fixed. Control-C without selection now selects the whole line. Control-X at the end of the Sketch does not throws exceptions anymore. AvrDude.exe updated. Minor changes to the template Sketch to use the default Bare minimum sketch.
* 1.0.3 20130203: Key shortcut to upload and open the serial monitor is now Ctrl+M.
* 1.0.3 20130202: Tweaks for Windows 8 in the driver installer. Key shortcut to upload and open the serial monitor is now Ctrl+i to avoid issues with some locates. Returns the maximum items that fit in the current screen for the menu scroller now uses Paul Stoffregen code.
* 1.0.3 20121230: Very little tweak to the help dialog and instructions in Windows 8.
« Last Edit: May 22, 2013, 08:14:31 pm by eried » Logged
My homepage/blog: http://erwin.ried.cl
Rapa Nui
Pukao hats cleaning services
Great, congratulation!
I am using one small mod for redirecting the build process into a single specific directory (shall be inserted into preferences.txt) ie.:
build.path=C:\MyCode\Arduino\build.folder
p.
Chile
Online Online
p.
I don't understand, you say I should include that in the setup? When I need the hex file: I usually just press shift, then copy the HEX path and paste to a programmer (and the same hex file is updated on next compilations)
Rapa Nui
That ensures the hex files are always on the same place so you do not need to mess with copying build paths into the programmer (if somebody uses an external programmer). Inclusion in the setup - it is up to you..
Chile
Online Online
True but you at least need to select the HEX file once right?, so I think it is more work (because you have to select the correct hex file and browse to the path): http://screencast.com/t/JsuttIxWqw
Don't you think? smiley
Rapa Nui
It is matter of taste smiley Whatever sketch I compile, after compilation the hex is in buld.folder so opening my programmer offers that hex and I just clik on it (within the programmer). So at least once per session you have to click on the hex smiley
PS: maybe you have to place your [MOD] topic into "Using Arduino: Installation and Troubleshooting" forum item..
PS1: is the dotnet 4 installation safe? - I do not want to mess too much with my XP setup, so trying to avoid experiments...
« Last Edit: August 15, 2012, 07:26:05 am by pito » Logged
Chile
Online Online
Safe? it is official from MS and it is offered as update in Windows Update so I am pretty sure it is very safe smiley-grin
I thought about using a more older framework to avoid users to need .net 4 (version 4 has more than 2 years already btw), but I found that some stuff I was using like the x64 detection to install the drivers with ease was only available in "hacky"/ugly ways in older versions, so at the end I decided to set 4 for cleanliness.
About the forum, maybe this is a wrong place, I was not sure. If some moderator think it has to be somewere else, please move it
How about letting the user choose where the libraries folder is (like the user can with the sketch book)?
Chile
Online Online
It is doable, but since the preferences in this version are not shared with other arduino ides and the sketch folder can contain the libraries I don't think it is too useful, what do you think?
I hadn't realized that I could place my custom libraries in the sketch book. Thanks for the info, and because of that, I agree that it is unnecessary.
Near Paris in France
Hello, this is a tweaked Arduino IDE 1.0.1, hope you enjoy it!
Can you provide a little summary of the enhanced functions ?
Screen captures are not so explicit for me.
JLB
Chile
Online Online
JLB
Hi, which one for example?
Sorry I misunderstand the title of the post.
It's not an enhanced IDE... It's only a windows intaller...
No news in the IDE itself.
JLB
Chile
Online Online
JLB
There are some hacks in the IDE but they are little, and the snapshots reflects them, like the icon, template.
Fantastic work! I received a free license for the cross-platform installer from the guys of Bitrock, specifically for the purpose of making a multi platform installer for Arduino. If you want to use it, I could forward it to you.
Pages: [1] 2 3 ... 33   Go Up
