Topic: Unformatted write to SD (Read 13414 times) previous topic - next topic
ardnut
#30
Aug 19, 2012, 09:32 pm Last Edit: Aug 19, 2012, 11:12 pm by ardnut Reason: 1
Quote
I got the noise so low with just analogRead() that I couldn't do oversampling.  For a number of DAC steps the 10-bit Arduino ADC always gives the same value.  I don't need noise reduction, I need noise injection to make oversampling work.
Are you concluding that you are not getting any noise in the 10th bit, even without going into idle? It would be great if NR mode was not even needed.
pito
Wouldn't the internal reference help? - those ref sources are usualy noisy enough :) Or external zener diode, without a blocking capacitor..
fat16lib
The tenth bit is the same for 1000 reads with analogRead() for about three out of four steps when I generate a ramp with a 12-bit DAC.
Oversampling just gives the 10-bit values not extra bits.  This is because for oversampling to work you need.
Quote
• The signal-component of interest should not vary significantly during a conversion.
• There should be some noise present in the signal.
• The amplitude of the noise should be at least 1 LSB.
See http://www.atmel.com/Images/doc8003.pdf.
If you power the Arduino with USB or a cheap wall wart there is plenty of noise.
I use a real power supply - one with a three prong grounded plug and low ripple/noise.  This supply is good for lots of amps so it's real overkill.
The DAC is on the Arduino using a shield Limor Fried gave me as a prototype.  She is good with ground planes and filtering.  I even put a big, 100K, resistor between the DAC and ADC and still didn't get noise.  I did get noise when I added about two feet of wire in addition to the resistor.
I would love to see a good case study that shows when ADC Noise Reduction Mode is needed and helps.
ardnut
#33
Aug 20, 2012, 03:24 am Last Edit: Aug 20, 2012, 03:57 am by ardnut Reason: 1
I would love to see a theoretical study that shows how adding noise to your signal improves the s/n ratio! I get the gut felling that is violating the second law somewhere on the line ;)
While dithering can reduce the quantisation error, the premise of the method is that the noise is gaussian. However,  4 or 16 samples will not provide sufficient sampling of the population to ensure that the gaussian distribution is well represented. The sampling error is not accounted for.
Also, arbitrary noise samples like bits of wire or internal interference of an AVR are unlikely to be all that "white".
Introducing a clean cyclic signal seems more legit to me and was the way I was taught to do this.
Of course, at best, this can only reduce the 0.5 LSB of quantisation error. The other 1.5 LSB of accumulated errors (gain , linearity, etc.) will still prevent the result from being of 10b accuracy.
This is why I was cautious about ENOB. It is only a measure of resolution , not accuracy.
ardnut
Quote
If I'm interpreting that correctly, you are saying that about 25% of the 1000 readings were different in the LSB. If half of them were different that would be 1LSb of noise. So off the top of my head that sounds like 0.5 LSB.
Remains to be determined weather they are both noisy or one is 0.5 LSB better.
fat16lib
What happens is that three of the steps in the 12-bit DAC result in the same value for all reads with the 10-bit AVR ADC.
The fourth step results in two values but this doesn't mean there is 1 LSB of noise.  Often most of the readings are one of the values.
There is always some voltage where a tiny change will result in the next code.  At this point about half the readings will be n and half will be n+1 even with very low noise.
1LSB for The 10-bit AVR ADC with 5V reference means greater than 5V/1023 of noise.  You really should have more like twice that for oversampling to work.  You need to get more than one code for multiple reads at every voltage.
You really need to read about ADCs, all manufacturers have good app notes on oversampling.
Almost all app notes have charts to illustrate this concept and statements like this.
Quote
In this example, the actual voltage falls between two steps of the 12-bit ADC resolution and there is no
noise riding on the signal. It is easy to see the problem. With no noise on the signal, the ADC result for
each conversion will be the same. Averaging produces no effective gain in resolution.
ardnut
#36
Aug 20, 2012, 10:20 am Last Edit: Aug 20, 2012, 10:55 am by ardnut Reason: 1
Quote
I'm familiar with dithering as I said and Ive read the AVR app. note that you linked to. You suggested I should not rely too heavily on spec sheets. I certainly do not regard manufacturers' app. notes as rigorous theoretical works, though they are usually very valuable.
I am questioning the idea of decreasing the S/N of the input signal as a means of improving it's measured S/N. Especially when the source of that noise is likely to be far from a flat spectrum.
Sure, any grec that you add to a low noise signal will produce different levels in subsequent samples. Whether it does so in a statistically neutral way or whether it biases each oversampled result in an arbitrary way is what needs to be considered.
Adding truly white noise and grouping hundreds of samples would be valid, since the averaging would effectively reduce the noise component that was added at the same time as removing most of the 0.5LSB quantisation noise.
If the noise is not gaussian or it is insufficiently sampled you cannot expect to remove it effectively by averaging (oversampling). You will be injecting one or two LSB of uncharacterised noise in the hope of reducing 0.5LSB of quantisation.
If your signal is "too clean" it would seem preferable to inject a clean cyclic signal than arbitrary environmental noise of unknown  quality that will almost certainly be far from gaussian.
Anyway , we're rather drifting off the topic. Hopefully I will have some hardware today so I can start testing using your libs and examples.  8)
ardnut
#37
Aug 20, 2012, 10:35 am Last Edit: Aug 20, 2012, 10:40 am by ardnut Reason: 1
Quote
Here's an interesting test. How about you post me the two sets of data and I try to tell identify which is which ?  1024 points would be preferable.
fat16lib
The data looks like 10-bit stair-steps with a little fuzz every once in a while.  It should look like 12-bit stair-steps.  You can't see the fact that the input was from a 12-bit DAC and you can't recover the fact by averaging data.
I'm not going to waste any more of my time.
It's time for you to go back to school and learn what every young EE knows about digital converters.  I work with lots of EE students and they know this stuff.
There are plenty of free sources on the web.
There are newer books but this is a great book and it's free http://www.analog.com/library/analogDialogue/archives/39-06/data_conversion_handbook.html.
Your going to have more problems using a multiplexed AVR ADC to do oversampling on multiple channels.  So learn a little first.
Good luck.
ardnut
I'm aware channel swapping will introduce a bunch of other issues. But the channel swapping application is a lot less exigent than your audio context.  Like I said earlier, I'm just interested in learning the limits of this hardware, to establish what it's good for. This project won't be pushing it to it's limits.
Thanks for testing N/R mode. I was concerned that not using it would have had a heavier penalty. I'm still rather surprised they would have gone to that trouble if it brings no discernible benefit.
The SD logging tests provide most of what I need and will save a huge amount of time and effort.
fat16lib
#40
Aug 20, 2012, 06:10 pm Last Edit: Aug 20, 2012, 07:04 pm by fat16lib Reason: 1
I decided To post the DAC/ADC test data.  The DAC is a MCP4921 with 5 V ref. http://ww1.microchip.com/downloads/en/DeviceDoc/22248a.pdf.
I got the noise really clean now as you will see in the attached file.  Only about one reading varied in the set of 64 that I took at each DAC value.
Here is the sketch that generated the data
Code: [Select]
#include <McpDac.h>
 mcpDacInit();
 for (uint16_t i = 2000; i < 2024; i++) {
   mcpDacSend(i);
   for (uint16_t j = 0; j < 64; j++) {
     Serial.print(i);
     Serial.write(',');
     Serial.print(j);
     Serial.write(',');
     Serial.println(analogRead(0));
void loop() {}
The sketch loads values from 2000 through 2023 into the DAC.  It then does 64 reads with analogRead() for that DAC value.
There are three columns: DAC value, reading #, ADC value.
The Arduino I used has a large offset error so it reads about 3 counts low.  This is not uncommon for an AVR ADC.  Be sure to calibrate your Arduino http://www.atmel.com/images/doc2559.pdf.
2001 on the DAC should be 500 on the ADC (2001*1023/4095 = 499.9).  The ADC reads 497.
You must be logged in to see the attached file.
Edit: I have now attached files taken with three Arduinos.  Arduino two and three have the fluctuation property since the DAC/ADC values lineup just right.
This does not mean there is more noise with Arduino two and three.  If you don't understand, read the app notes, you claim to be an engineer so this should be easy.
fat16lib
I missed this.
Quote
Your funny, wrong but funny.  Time to read the ADC theory.
Quote
Note that this averaging is possible only if the signal contains perfect equally distributed noise (i.e. if the A/D is perfect and the signal's deviation from an A/D result step lies below the threshold, the conversion result will be as inaccurate as if it had been measured by the low-resolution core A/D and the oversampling benefits will not take effect).
The above means adding noise can improve accuracy with enough oversampling.  Too little noise will result in lower resolution.
This is why I never use oversampling, too much can go wrong.  Better to use a more accurate ADC.
Quote
Wrong again.
ENOB specifies the number of bits in the digitized signal above the noise floor, this is accuracy.  A 12-bit ADC has 12 bits of resolution but may not be accurate to 12-bits.
Are you really an EE?
Maybe I expect too much.  In physics I work with EEs that design ADCs and other IC parts.
I worked on the CERN Atlas experiment that discovered the Higgs Boson.  The front end electronics used ASICs (Application Specific Integrated Circuit) designed by CERN engineers.  This is necessary for low noise, high speed, and these parts must be Radiation Hard.
I expect EEs to know theory.
ardnut
#42
Aug 20, 2012, 10:04 pm Last Edit: Aug 20, 2012, 11:00 pm by ardnut Reason: 1
Quote
No it's not ,  it's resolution. Your arduino with a 3LSB offset  is less accurate. Does it have any less ENOBs because of that offset?
fat16lib
#43
Aug 20, 2012, 11:04 pm Last Edit: Aug 20, 2012, 11:35 pm by fat16lib Reason: 1
This a quote from Analog Devices (not mine).
Quote
Here is another definition, not mine:
Quote
The effective number of bits (ENOB) is a way of quantifying the quality of an analog to digital conversion. A higher ENOB means that voltage levels recorded in an analog to digital conversion are more accurate.
Here is another from Analog Devices.
Quote
Resolution. An N-bit binary converter has N digital data inputs (DAC) or N digital data outputs (ADC). A converter that satisfies this criterion is said to have a resolution of N bits.
Resolution has nothing to do with accuracy.  It's the number of bits an ADC outputs or the number of bits of input to a DAC.
DC accuracy involves these (From Analog Devices), not resolution.
Quote
The static absolute accuracy of a DAC can be described in terms of three fundamental kinds of errors: offset errors, gain errors, and integral nonlinearity.
Another quote from Analog Devices.
Quote
The traditional static specifications such as differential nonlinearity (DNL) and integral nonlinearity (INL) are most certainly reflected in the ac performance.
That's why ENOB is a better measure for quality of signal measurements.  It combines all factors regarding accuracy of the measurement.
For simple DC measurements, non-linearity is the big deal.  Offset errors are easy to calibrate.  Many ADCs like the MCP3421 do it automatically.
From Microchip for the MCP3421
Quote
Self Calibration of Internal Offset and Gain Per Each Conversion.
It's true offset errors may not affect AC performance.  You must compensate for the AVR offset errors for DC measurements.
This is such basic stuff for an EE.  Are you really an EE?  If so when did you go to school?
ardnut
#44
Aug 21, 2012, 12:19 am Last Edit: Aug 21, 2012, 12:38 am by ardnut Reason: 1
Quote
This a quote from Analog Devices...
So having started by telling me to "ignore" their data sheets, you now wish to use them in an  appeal to authority argument.
Quote
You seem to be reading something more into that than there is stated. Yes, better resolution can  contribute to better accuracy , that does not mean resolution IS accuracy, which is what you seem to be implying it says.
Quote
Wrong again, as you would say. Resolution is one factor that contributes to (or limits) accuracy.
You may increase resolution by dithering and oversampling, thereby improving accuracy within the limit of the quantisation error you had previously. If you have 0.5LSB of quantisation error you cannot improve the quantisation error by more than 0.5 LSB. Neither will oversampling correct non-linearaity or gain errors. The major part of the 1.5 LSB errors reducing the basic 10b sample.
You may also remove gaussain noise by oversampling. But if your noise is not gaussian  it will NOT be correctly removed.  There will remain a bias in the result, the sign and magnitude of which you will not be able to know. If you do not know the nature of the noise you are injecting by waving a piece of wire around, you cannot know what will be left after oversampling. You will therefore have degraded the S/N of the result (notwithstanding the limited improvement gained by dithering).
That is why I suggested that, since you seem to have got a very clean signal, a suitable cyclic perturbation signal would be better than arbitrary, uncharacterised noise.
This is so basic, I don't see why I am having to lay this out for a third time.
If you see something wrong with my argument I'd be more impressed if you could say where it was wrong rather than pretending app. notes are some kind of text book on methodology or saying "bah! go back to school" and questioning my credentials.
I deliberately left that last comment short. Yet you ignore it. I'll ask again...
Quote
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
