Topic: Problem in Interfacing arduino due with spi expander mcp23s08 (Read 3039 times) previous topic - next topic
chinni4292
here is my code.
Code: [Select]
  Code to test MCP23S08 SPI B-bit I/O expander
  See:
     <http://code.rancidbacon.com/LearningAboutArduinoMCP23S08>
     <http://www.arduino.cc/en/Tutorial/SPIEEPROM>
  Current features:
      * Read input pins
      * Set output pins
      * Write output pins
      * Gratuitous LED fiddling
      * Terrible hacked-together code
// Define SPI-related pins
#define PIN_DATA_OUT 11 // MOSI (Master Out / Slave In)
#define PIN_DATA_IN  12 // MISO (Master In / Slave Out)
#define PIN_SPI_CLOCK  13 // SCK (Serial Clock)
#define PIN_SLAVE_SELECT 10 // SS (Slave Select)
byte deviceOpcodeRead = 0;
byte deviceOpcodeWrite = 0; // TODO: handle this better?
byte pinState = B00000000;
unsigned long clk = 0;
void setup () {
  Serial.println("Setup enter...");
  Serial.print("SPCR: "); Serial.println(SPCR, BIN);
  // Configure SPI
  //   Configure I/O pins
  pinMode(PIN_DATA_OUT, OUTPUT);
  pinMode(PIN_DATA_IN, INPUT);
  pinMode(PIN_SPI_CLOCK, OUTPUT);
  pinMode(PIN_SLAVE_SELECT, OUTPUT);
  digitalWrite(PIN_SLAVE_SELECT, HIGH); // Disable slave
  //    Configure SPI Control Register (SPCR) (All values initially 0)
  //     Bit  Description
  //       7  SPI Interrupt Enable    -- disable  (SPIE --> 0)
  //       6  SPI Enable              -- enable   (SPE  --> 1)
  //       5  Data Order              -- MSB 1st  (DORD --> 0) (Slave specific)
  //       4  Master/Slave Select     -- master   (MSTR --> 1)
  //       3  Clock Polarity          --          (CPOL --> 0) (Slave specific) ("Mode")
  //       2  Clock Phase             --          (CPHA --> 0) (Slave specific)
  //       1  SPI Clock Rate Select 1 -- }        (SPR1 --> 0)
  //       0  SPI Clock Rate Select 0 -- } fOSC/4 (SPR0 --> 0) ("Fastest" but see SPI2X in SPSR)
  SPCR = (1<<SPE)| (1<<MSTR);
  // Clear previous data and status (TODO: Determine if necessary/better way.)
  // (Based on Playground SPI example.)
  byte dummy;
  dummy = SPSR;
  dummy = SPDR;
  delay(10);
  // Serial.println((1 << SPIF), BIN);
# define SLAVE_ADDRESS_BASE    (B01000 << 3)
# define SLAVE_ADDRESS_BIT_A1  (0 << 2)  // TODO: Allow non-zero and define constants
# define SLAVE_ADDRESS_BIT_A0  (0 << 1)  // TODO: Allow non-zero and define constants
# define SLAVE_ADDRESS         (SLAVE_ADDRESS_BASE|SLAVE_ADDRESS_BIT_A1|SLAVE_ADDRESS_BIT_A0)
# define CONTROL_BIT_READ 1
# define CONTROL_BIT_WRITE 0
# define REG_IODIR 0x00
# define REG_IOPOL 0x01
# define REG_GPIO 0x09
//  byte deviceOpcode = 0;
  //TODO: Reset slave?
  deviceOpcodeRead = (SLAVE_ADDRESS | CONTROL_BIT_READ);
  deviceOpcodeWrite = (SLAVE_ADDRESS | CONTROL_BIT_WRITE);
  Serial.print("Device opcode (read): ");
  Serial.println(deviceOpcodeRead, BIN);
  Serial.print("Device opcode (write): ");
  Serial.println(deviceOpcodeWrite, BIN);
  digitalWrite(PIN_SLAVE_SELECT, LOW); // Enable slave
  spi_transfer(deviceOpcode);
  // spi_transfer(REG_IODIR);  // The register we want to read
  // spi_transfer(REG_IOPOL);  // The register we want to read
  spi_transfer(REG_GPIO);  // The register we want to read
  // int data; // Correct type?
  byte data; // Correct type?
  //unsigned long data; // Correct type?
  data = spi_transfer(0xFF); // Transfer dummy byte to get response
  byte iodirVal = 0;
  Serial.print("IODIR response: ");
  iodirVal = getRegister(deviceOpcodeRead, REG_IODIR);
  Serial.println(iodirVal, BIN);
  byte newVal = 0;
  // newVal = iodirVal & B01111111;
  // newVal = B01111111;
  newVal = B00001111;
  Serial.print("newVal: ");
  Serial.println(newVal, BIN);
  setRegister(deviceOpcodeWrite, REG_IODIR, newVal);
  //setRegister(deviceOpcodeWrite, REG_GPIO, B10000000); // on
  //setRegister(deviceOpcodeWrite, REG_GPIO, B00000000); // off
  setRegister(deviceOpcodeWrite, REG_GPIO, pinState);
  Serial.print("Initial GPIO response: ");
  Serial.println(getRegister(deviceOpcodeRead, REG_GPIO), BIN);
  Serial.println("Setup exit...");
  clk = millis();
byte getRegister(byte targetDeviceOpcode, byte registerAddress) {
  spi_transfer(targetDeviceOpcode);
  spi_transfer(registerAddress);  // The register we want to read
  return data;
void setRegister(byte targetDeviceOpcode, byte registerAddress, byte value) {
  // TODO: Do Better?
  spi_transfer(registerAddress);  // The register we want to write
  spi_transfer(value);
// From Playground
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait for the end of the transmission
  return SPDR;                    // return the received byte
byte buttonState = 0;
  if (pinState && ((millis() - clk) > 750)) {
    // pinState = B00000000;
    pinState = (pinState >> 1) & B11110000;
    clk = millis() - 500;
  // Serial.println(getRegister(deviceOpcodeRead, REG_GPIO), BIN);
  buttonState = (getRegister(deviceOpcodeRead, REG_GPIO) & B00000001);
  // Serial.println(buttonState, BIN);
  //if (buttonState && !pinState) { // TODO: mask off pin(s) we're interested in & do better.
  if (buttonState) {
    // pinState = B10000000;
    // pinState = B11110000; // Note: You need to set as outputs remember!
    if (!(pinState & B10000000)) { // Compare to top-most output bit
      pinState = (pinState << 1) | B00010000; // Add bottom-most output bit
    delay(75);
    clk = millis();
  else if (!buttonState && pinState) {
  delay(50);
chinni4292
my errors during compiling
sketch_jul15a.ino: In function 'void setup()':
sketch_jul15a:42: error: 'SPCR' was not declared in this scope
sketch_jul15a:63: error: 'SPE' was not declared in this scope
sketch_jul15a:63: error: 'MSTR' was not declared in this scope
sketch_jul15a:70: error: 'SPSR' was not declared in this scope
sketch_jul15a:71: error: 'SPDR' was not declared in this scope
sketch_jul15a.ino: In function 'char spi_transfer(char)':
sketch_jul15a:178: error: 'SPDR' was not declared in this scope
sketch_jul15a:179: error: 'SPSR' was not declared in this scope
sketch_jul15a:179: error: 'SPIF' was not declared in this scope
chinni4292
i am following this link
please help me..
chinni4292
can anyone provide me mcp23s08.h and mcp23s08.cpp files?
chinni4292
can anyone specify the connections
or change the code as it is complex
