Loading...
Pages: [1]   Go Down
Author Topic: question?  (Read 206 times)
Offline Offline
Newbie
View Profile
In this project circuit http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads How many stage does this project has? I need this for my capstone project?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
It has five main stages but stage 3 has sub-stages 1 and 2 so you might see it as 6 or 7.
Logged
Offline Offline
Newbie
View Profile
Can you tell me these stages?
Im kinda new to this world of electronic but i know that the output voltage is 3.3 or 5V, so the first stage is a TIP-120  transistor to feed the Arduino Uno microcontroller with the required 5v needed for its operation.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
The Arduino does not get 5V power from the TIP-120 transistor.
There are four ways to provide power to the Arduino:
    USB cable provides 5V 500mA.
    Built-in regulator can accept 7V to 12V and provide 5V 1A.
        There are two ways to feed the built-in regulator:
             The power jack (center + and sleeve -)
             The Vin pin (+) and Ground (-).
    You can use an external regulator and provide regulated 5V to the 5V pin (+) and Ground (-).
The transistor acts as a switch: http://www.electronics-tutorials.ws/transistor/tran_4.html
The Arduino can use a weak (40 mA max) 5V output connected to the Base of the transistor to switch a higher current and higher voltage.
Logged
Pages: [1]   Go Up
Print
Jump to:
