Topic: Run Servo with Accelerometer strange problem (Read 990 times) previous topic - next topic
stupsi99
Hello,
I'm new to arduino, but not necessarily to programming so I'm guessing the code is written okay, just the idea might be wrong.
I am now facing a problem with my ADXL335 accelerometer, which is supposed to control a servo.
I wrote code which averages 10 values and maps that average value to the servo. Also puts the servo value out on the serial monitor.
Now the strange problem is:
Serial monitor shows perfectly averaged, non jumpy, values, even when accelerometer is moved quickly. But as soon as I plug the servo to the Arduino Uno and Digital 9 (PWM), the accelerometer values become jumpy on the serial monitor and you can see that in erratic servo movement.
Can anyone help with this issue? I have seen the ADXL335 work nicely on videos, but can't get it to work.
If you have time on your hand, you could look at my code.
Thank you!
-Phil
Code: [Select]
#include <Servo.h>
Servo myservo;
const int xPin = 0;
int val;
int xRead[10];
int i =0;
int total=0;
void setup(){
  myservo.attach(9);
void loop(){
//set total to zero when restarting loop:
total=0;
//loop to get 10 values and average them
for(i=0;i<10;i++){
  xRead[i] = analogRead(xPin);
  //throw out bad values:
//if bad value bigger than last value+20
if(i>0){
  if(xRead[i]>xRead[i-1]+20){
    xRead[i]=xRead[i-1];
  //if bad value smaller than last value-20
  if(i>0){
  if(xRead[i]<xRead[i-1]-20){
  total= total + xRead[i];
//calculate average:
val=total/10;
val= map(val,269,404,0,179);
//limit servo:
if(val>179){
   val=179;
if(val<0){
   val=0;
  Serial.println(val);
  myservo.write(val);
  delay(30);
pito
..you cannot power the servo from arduino, use a separate power source with enough current. Servo needs a lot of power..
stupsi99
Hi and thanks for your quick reply!
I have a BEC now, which connects to servos ground and v-pin with 5V. Signal connected to D-Out 9, like before, but servo doesn't move anymore at all now, not even if I set a fix value for it in the program.
As soon as I connect ground and v-pin to the Uno again, it works like before, very jittery and the values jump.
Weird.
Can you help me sort this out?
Anyone had the same trouble?
Thank you again!
-Phil
pito
I do not know how the setup looks like, but gnd of arduino and gnd of servo and gnd of the power source for the servo must be connected together - common ground..
stupsi99
Hi!
Thanks for your answer.
Having a common ground didn't help!
Anyone an idea?
-Phil
pito
pito
..do not power the servo from arduino, use separate power source for the servo instead - that wiring (the servo powered from an external source) needs to be seen so we can help you..
stupsi99
Alright, I didn't know how to show that in fritzing.
1) As I said I have hooked up the servo like shown above.
2) Only difference servo Voltage pins both hooked up to external BEC which outputs 5 Volts and definitely works, cause I use it for other stuff.
3) Additionally I connected the BEC ground to the arduino ground and the servo ground.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
