Topic: ITDB02_Touch problems (Read 11561 times) previous topic - next topic
Joes
hi there im having problems uploading ITDB02_Touch calibiration to my mega2560 with my 3.2 wc utft i haveinstalled libraries ITDB02_Touch
ITDB02_graph
ITDB02_graph16
utft
code error; no matching funtion for call to 'ITDB)"_Touch::ITDB02_touch(int, int, int, int)'
code im using
Code: [Select]
// ITDB02_Touch_Calibration (C)2010 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program can be used to calibrate the touchscreen
// of the ITDB02 modules.
// This program requires the ITDB02_Graph library (8bit mode)
// or ITDB02_Graph16 (16bit mode).
// It is assumed that the ITDB02 module is connected to a
// ITDB02 Shield, a ITDB02 Mega Shield or that you know how
// to change the pin numbers in the setup.
// Instructions will be given on the display.
// Remember to change the next line if you are using as 16bit module!
#include <ITDB02_Graph.h>
#include <ITDB02_Touch.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Uncomment the next two lines for the ITDB02 Shield
//ITDB02        myGLCD(19,18,17,16);
//ITDB02_Touch  myTouch(15,10,14,9,8);
// Uncomment the next two lines for the ITDB02 Mega Shield
ITDB02        myGLCD(38,39,40,41);   // Remember to add ASPECT_16x9 if you are using an ITDB02-3.2WC!
ITDB02_Touch  myTouch(6,5,4,3,2);
int cx, cy;
int rx[10], ry[10];
float px, py;
int ox, oy;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(SmallFont);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_LOW);
void drawCrossHair(int x, int y)
  myGLCD.drawRect(x-10, y-10, x+10, y+10);
  myGLCD.drawLine(x-5, y, x+5, y);
  myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
  int iter = 2000;
  int cnt = 0;
  unsigned long tx=0;
  unsigned long ty=0;
  boolean OK = false;
  while (OK == false)
    while (myTouch.dataAvailable() == false) {}
    while ((myTouch.dataAvailable() == true) && (cnt<iter))
      myTouch.read();
      tx += myTouch.TP_X;
      ty += myTouch.TP_Y;
      cnt++;
    if (cnt>=iter)
      OK = true;
      tx = 0;
      ty = 0;
      cnt = 0;
  cx = tx / iter;
  cy = ty / iter;
void calibrate(int x, int y, int i)
  myGLCD.setColor(255, 255, 255);
  drawCrossHair(x,y);
  readCoordinates();
  myGLCD.setColor(80, 80, 80);
  drawCrossHair(x,y);
  rx[i]=cx;
  ry[i]=cy;
  while (myTouch.dataAvailable() == true)
    myTouch.read();
void waitForTouch()
    myTouch.read();
    myTouch.read();
void startup()
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 239, 13);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.drawLine(0, 14, 239, 14);
  myGLCD.print("ITDB02 TOUCH CALIBRATION", CENTER, 1);
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.print("INSTRUCTIONS", CENTER, 30);
  myGLCD.print("Use a stylus or something", LEFT, 50);
  myGLCD.print("similar to touch as close to", LEFT, 62);
  myGLCD.print("the center of the highlighted", LEFT, 74);
  myGLCD.print("crosshair as possible. Keep as", LEFT, 86);
  myGLCD.print("still as possible and keep", LEFT, 98);
  myGLCD.print("holding until the highlight is", LEFT, 110);
  myGLCD.print("removed. Repeat for all", LEFT, 122);
  myGLCD.print("crosshairs in sequence.", LEFT, 134);
  myGLCD.print("Further instructions will be", LEFT, 158);
  myGLCD.print("displayed when the calibration", LEFT, 170);
  myGLCD.print("is complete.", LEFT, 182);
  myGLCD.print("Do NOT use your finger as a", LEFT, 206);
  myGLCD.print("calibration stylus or the", LEFT, 218);
  myGLCD.print("result WILL BE very imprecise.", LEFT, 230);
  myGLCD.print("Touch screen to continue", CENTER, 305);
  waitForTouch();
  myGLCD.clrScr();
void done()
  myGLCD.clrScr();
  myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
  myGLCD.print("To use the new calibration", LEFT, 50);
  myGLCD.print("settings you must edit the", LEFT, 62);
  myGLCD.setColor(160, 160, 255);
  myGLCD.print("ITDB02_Touch.cpp", LEFT, 74);
  myGLCD.print("file and", 136, 74);
  myGLCD.print("change the following values.", LEFT, 86);
  myGLCD.print("The values are located right", LEFT, 98);
  myGLCD.print("below the opening comment in", LEFT, 110);
  myGLCD.print("the file.", LEFT, 122);
  myGLCD.print("PixSizeX", LEFT, 158);
  myGLCD.print("PixOffsX", LEFT, 170);
  myGLCD.print("PixSizeY", LEFT, 182);
  myGLCD.print("PixOffsY", LEFT, 194);
  myGLCD.print("Connected module:", LEFT, 250);
  myGLCD.drawLine(0, 155, 239, 155);
  myGLCD.drawLine(0, 209, 239, 209);
  myGLCD.printNumF(px, 2, 100, 158);
  myGLCD.printNumI(ox, 100, 170);
  myGLCD.printNumF(py, 2, 100, 182);
  myGLCD.printNumI(oy, 100, 194);
  if (px>=0)
    myGLCD.print("2.4\"", 144, 250);
    if (py>=0)
      myGLCD.print("3.2\"", 144, 250);
      myGLCD.print("Negative numbers for PixSizeX", LEFT, 270);
      myGLCD.print("is expected :)", LEFT, 282);
      myGLCD.print("3.2\" Wide", 144, 250);
      myGLCD.print("and PixSizeY are expected :)", LEFT, 282);
  startup();
  drawCrossHair(10,10);
  drawCrossHair(10,160);
  drawCrossHair(10,309);
  drawCrossHair(120,10);
  drawCrossHair(120,160);
  drawCrossHair(120,309);
  drawCrossHair(229,10);
  drawCrossHair(229,160);
  drawCrossHair(229,309);
  calibrate(10, 10, 0);
  calibrate(10, 160, 1);
  calibrate(10, 309, 2);
  calibrate(120, 10, 3);
  calibrate(120, 160, 4);
  calibrate(120, 309, 5);
  calibrate(229, 10, 6);
  calibrate(229, 160, 7);
  calibrate(229, 309, 8);
  px = ((float(rx[0]+rx[1]+rx[2])/3)-(float(rx[6]+rx[7]+rx[8])/3))/220;
  if (px>=0)
    ox = (((rx[6]+rx[7]+rx[8])/3))-(px*10);
    ox = (((rx[0]+rx[1]+rx[2])/3))+(px*10);
  py = ((float(ry[0]+ry[3]+ry[6])/3)-(float(ry[2]+ry[5]+ry[8])/3))/300;
  if (py>=0)
    oy = (((ry[2]+ry[5]+ry[8])/3))-(py*10);
    oy = (((ry[0]+ry[3]+ry[6])/3))+(py*10);
  done();
  while(true) {}
P18F4550
#1
Aug 15, 2012, 07:57 pm Last Edit: Aug 15, 2012, 08:10 pm by P18F4550 Reason: 1
Code: [Select]
is not needed for Mega unless your using 8bit mode.
change it to
Code: [Select]
#include <UTFT.h>
also change
Code: [Select]
for
Code: [Select]
UTFT myGLCD(ITDB32S,38,39,40,41);
I've compiled it on IDE_0018 with Nega1280 and it works fine
nearly forgot
put this in setup, it sets orientation
Code: [Select]
myGLCD.InitLCD(PORTRAIT);
myTouch.InitTouch(PORTRAIT);
Shaun
Joes
now brings up Error compilling what have i dun now lol sorry if im being a bit dumb new to this
Code: [Select]
#include <UTFT.h>
int cx, cy;
int rx[10], ry[10];
float px, py;
int ox, oy;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  int iter = 2000;
  int cnt = 0;
  unsigned long tx=0;
  unsigned long ty=0;
  boolean OK = false;
  while (OK == false)
      myTouch.read();
      tx += myTouch.TP_X;
      ty += myTouch.TP_Y;
      cnt++;
    if (cnt>=iter)
      OK = true;
      tx = 0;
      ty = 0;
      cnt = 0;
  cx = tx / iter;
  cy = ty / iter;
  drawCrossHair(x,y);
  readCoordinates();
  drawCrossHair(x,y);
  rx[i]=cx;
  ry[i]=cy;
    myTouch.read();
void waitForTouch()
    myTouch.read();
    myTouch.read();
void startup()
  waitForTouch();
  myGLCD.clrScr();
void done()
  myGLCD.clrScr();
  if (px>=0)
    if (py>=0)
  startup();
  if (px>=0)
  if (py>=0)
  done();
  while(true) {}
P18F4550
#3
Aug 15, 2012, 11:24 pm Last Edit: Aug 15, 2012, 11:50 pm by P18F4550 Reason: 1
Well that's strange, with IDE_1.0.1 i get
Quote
In file included from ITDB02_Touch_Calibration.cpp:18:
/home/shaun/arduino-1.0.1/libraries/ITDB02_Touch/ITDB02_Touch.h:44:22: error: WProgram.h: No such file or directory
but with IDE_0018 i dont get the error
what error are you getting?
have you tried the UTFT font example?
what version of Arduino IDE are you using?
P18F4550
#4
Aug 15, 2012, 11:59 pm Last Edit: Aug 16, 2012, 12:00 am by P18F4550 Reason: 1
ok the answer to the error is
In ITDB02_Touch.h change #include "WProgram.h" to #include "Arduino.h"
do the same in
ITDB02_Touch.cpp
now no error, the calibration program works
Code: [Select]
#include <UTFT.h>
UTFT myGLCD(ITDB32S,38,39,40,41);   // Remember to add ASPECT_16x9 if you are using an ITDB02-3.2WC!
int cx, cy;
int rx[10], ry[10];
float px, py;
int ox, oy;
 myGLCD.clrScr();
 int iter = 2000;
 int cnt = 0;
 unsigned long tx=0;
 unsigned long ty=0;
 boolean OK = false;
 while (OK == false)
     myTouch.read();
     tx += myTouch.TP_X;
     ty += myTouch.TP_Y;
     cnt++;
   if (cnt>=iter)
     OK = true;
     tx = 0;
     ty = 0;
     cnt = 0;
 cx = tx / iter;
 cy = ty / iter;
 drawCrossHair(x,y);
 readCoordinates();
 drawCrossHair(x,y);
 rx[i]=cx;
 ry[i]=cy;
   myTouch.read();
void waitForTouch()
   myTouch.read();
   myTouch.read();
void startup()
 waitForTouch();
 myGLCD.clrScr();
void done()
 myGLCD.clrScr();
 if (px>=0)
   if (py>=0)
 startup();
 if (px>=0)
 if (py>=0)
 done();
 while(true) {}
eried
There is a new version of this library for Arduino 1.0
My website: http://ried.cl
Joes
Quote
just says error compiling
then inside the box
in file included from touch_calibration.cpp:18:c:\Users\Joe\Documents\arduino-1.0\libraries\ITDB02_touch/ITDB02_Touch.h:44:22:error: WProgram.h: no such file or directory
yes i can get a pic up on it
arduino 1.0
In my ITDB02_Touch folder
the one In ITDB02_Touch   Type is Arduino.h
and the other one ITDB02  Touch WProgram.h
is this ok?
P18F4550
#7
Aug 17, 2012, 10:43 am Last Edit: Aug 17, 2012, 10:48 am by P18F4550 Reason: 1
please see post NO.4
Quote
do the same in
ITDB02_Touch.cpp
I don't use Arduino 1.0 very often because all my code was written in IDE_0018. but i used it for this error and the calibration code is working for me, hope it works for you
Joes
HI there
just to let you no i did it on arduino 0022 and it now work's fine
has anybody got some good recommendations to have a look at some simple examples to get the nack of how to use this libraby?
P18F4550
Code: [Select]
Basically just play with it, that's how i leaned, sometimes it's hard to understand another persons code unless you do it yourself.
Have a look at the button example that comes with the library, it's a good place to start, maybe just start with one button first, and when you get the hang of detecting touch and getting co-ordinates then try 2 buttons or more.
The code is quite daunting to look at to start with but you'll soon get the hang of it
Joes
ok cool
just upload that up on my arduino compiled fine and upload fine brings up the display fine but the touch does not work dont no if i have missed something out
want to get it right before i start looking at it
Code: [Select]
// ITDB02_Touch_ButtonTest (C)2010 Henning Karlsen
// This program is a quick demo of how create and use buttons.
#include <UTFT.h>
extern uint8_t BigFont[];
//ITDB02        myGLCD(38,39,40,41);   // Remember to add ASPECT_16x9 if you are using an ITDB02-3.2WC!
//ITDB02_Touch  myTouch(6,5,4,3,2);
int x, y;
char stCurrent[20]="";
int stCurrentLen=0;
char stLast[20]="";
// Initial setup
  myGLCD.InitLCD(LANDSCAPE);
  myGLCD.clrScr();
  myTouch.InitTouch(LANDSCAPE);
  myTouch.setPrecision(PREC_MEDIUM);
  myGLCD.setFont(BigFont);
  myGLCD.setBackColor(0, 0, 255);
// Draw the upper row of buttons
  for (x=0; x<5; x++)
    myGLCD.setColor(0, 0, 255);
    myGLCD.fillRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.drawRoundRect (10+(x*60), 10, 60+(x*60), 60);
    myGLCD.printNumI(x+1, 27+(x*60), 27);
// Draw the center row of buttons
  for (x=0; x<5; x++)
    myGLCD.fillRoundRect (10+(x*60), 70, 60+(x*60), 120);
    myGLCD.drawRoundRect (10+(x*60), 70, 60+(x*60), 120);
    if (x<4)
      myGLCD.printNumI(x+6, 27+(x*60), 87);
  myGLCD.print("0", 267, 87);
// Draw the lower row of buttons
  myGLCD.fillRoundRect (10, 130, 150, 180);
  myGLCD.drawRoundRect (10, 130, 150, 180);
  myGLCD.print("Clear", 40, 147);
  myGLCD.fillRoundRect (160, 130, 300, 180);
  myGLCD.drawRoundRect (160, 130, 300, 180);
  myGLCD.print("Enter", 190, 147);
  myGLCD.setBackColor (0, 0, 0);
void updateStr(int val)
  if (stCurrentLen<20)
    stCurrent[stCurrentLen]=val;
    stCurrent[stCurrentLen+1]='\0';
    stCurrentLen++;
    myGLCD.setColor(0, 255, 0);
    myGLCD.print(stCurrent, LEFT, 224);
    myGLCD.print("BUFFER FULL!", CENTER, 192);
    myGLCD.print("            ", CENTER, 192);
// Draw a red frame while a button is touched
void waitForIt(int x1, int y1, int x2, int y2)
  myGLCD.drawRoundRect (x1, y1, x2, y2);
  while (myTouch.dataAvailable())
    myTouch.read();
  while (true)
    if (myTouch.dataAvailable())
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      if ((y>=10) && (y<=60))  // Upper row
        if ((x>=10) && (x<=60))  // Button: 1
          waitForIt(10, 10, 60, 60);
          updateStr('1');
        if ((x>=70) && (x<=120))  // Button: 2
          waitForIt(70, 10, 120, 60);
          updateStr('2');
        if ((x>=130) && (x<=180))  // Button: 3
          waitForIt(130, 10, 180, 60);
          updateStr('3');
        if ((x>=190) && (x<=240))  // Button: 4
          waitForIt(190, 10, 240, 60);
          updateStr('4');
        if ((x>=250) && (x<=300))  // Button: 5
          waitForIt(250, 10, 300, 60);
          updateStr('5');
      if ((y>=70) && (y<=120))  // Center row
        if ((x>=10) && (x<=60))  // Button: 6
          waitForIt(10, 70, 60, 120);
          updateStr('6');
        if ((x>=70) && (x<=120))  // Button: 7
          waitForIt(70, 70, 120, 120);
          updateStr('7');
        if ((x>=130) && (x<=180))  // Button: 8
          waitForIt(130, 70, 180, 120);
          updateStr('8');
        if ((x>=190) && (x<=240))  // Button: 9
          waitForIt(190, 70, 240, 120);
          updateStr('9');
        if ((x>=250) && (x<=300))  // Button: 0
          waitForIt(250, 70, 300, 120);
          updateStr('0');
      if ((y>=130) && (y<=180))  // Upper row
        if ((x>=10) && (x<=150))  // Button: Clear
          waitForIt(10, 130, 150, 180);
          stCurrent[0]='\0';
          stCurrentLen=0;
          myGLCD.setColor(0, 0, 0);
          myGLCD.fillRect(0, 224, 319, 239);
        if ((x>=160) && (x<=300))  // Button: Enter
          waitForIt(160, 130, 300, 180);
          if (stCurrentLen>0)
            for (x=0; x<stCurrentLen+1; x++)
              stLast[x]=stCurrent[x];
            stCurrent[0]='\0';
            stCurrentLen=0;
            myGLCD.fillRect(0, 208, 319, 239);
            myGLCD.print(stLast, LEFT, 208);
            myGLCD.print("BUFFER EMPTY", CENTER, 192);
P18F4550
Code: [Select]
//UTFT myGLCD(ITDB32S,38,39,40,41);
// [color=red]Uncomment the next two lines for the ITDB02 Mega Shield[/color]
The clue is here, your using Mega2560, so // top 2 lines and uncomment the 2 for Mega
Joes
lol  that was a bit obvious and embarrasing sorry
well i uploaded it to my arduino, the touch worked but all in the wrong places so i presumed i did the caliberation correctly so i preformed that again and now it seems i have nothing touch wise working does this all look reasonably correct?
#define PixSizeX   0.08
#define PixOffsX   1329
#define PixSizeY   0.01
#define PixOffsY   1641
Code: [Select]
#include <UTFT.h>
int x, y;
int stCurrentLen=0;
char stLast[20]="";
// Initial setup
  myGLCD.clrScr();
  for (x=0; x<5; x++)
  for (x=0; x<5; x++)
    if (x<4)
    stCurrentLen++;
    myTouch.read();
  while (true)
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
          updateStr('1');
          updateStr('2');
          updateStr('3');
          updateStr('4');
          updateStr('5');
          updateStr('6');
          updateStr('7');
          updateStr('8');
          updateStr('9');
          updateStr('0');
          stCurrent[0]='\0';
          stCurrentLen=0;
          if (stCurrentLen>0)
            stCurrent[0]='\0';
            stCurrentLen=0;
P18F4550
I may not have explained it well before, you only need to initLCD & initTouch once, you have done it twice here,
Code: [Select]
// Initial setup
  myGLCD.clrScr();
The Calibration sketch only seems to work in Portrait, after you have done the calibration you can use the screen however you want
Joes
have took those to top lines off and still not working
