Topic: DIY Arduino problem (Read 3832 times) previous topic - next topic
CrossRoads
Promini uses external 8 MHz oscillator, not internal.
pito
learn how to use fuses:
http://www.engbedded.com/fusecalc/
The 22pF caps on the crystal are important as they help crystal to oscillate on its fundamental frequency..
Vincent19
So, the minimum circuit for an arduino based development board is a 16MHz crystal and the 100nF cap for power supply and pull up resistor for RESET pin ?
No, you can use the internal oscilator (there is a fuse). And the reset is not required. The minimum is just the cap for the supply
Why reset is not required ? I thought RESET should be pulled up for normal usage ?
Thanks :D
CrossRoads
Reset pullup needed for most stable operation, see Section 3
You are free to chase noise issue, odd resets, etc. if you so choose.
Vincent19
Yea, so I neeed a pull up resistor :D
Thanks ^^
