Loading...
Pages: 1 [2] 3   Go Down
Author Topic: SPI Slave [SOLVED]  (Read 2190 times)
Offline Offline
Jr. Member
View Profile
ok, this is my new code with preconfigured rx_data as 0x00, and your modification.
Code:
#include <SPI.h>
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
void SlaveInit(void) {
  // Set MISO output, all others input
  pinMode(SCK_PIN, INPUT);
  pinMode(MOSI_PIN, INPUT);
  pinMode(MISO_PIN, OUTPUT);
  pinMode(SS_PIN, INPUT);
  // Enable SPI
  SPCR = B00101100;
  SPCR = (1<<SPE);
uint8_t RX_Data[32] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                       0x00, 0x00, 0x00, 0x00};
uint8_t ReadByte(void) {
uint8_t *ptr = RX_Data;
for (int i = 0; i < 32; i++){
// SPDR = 0x01; // preload the data reg
  while(!(SPSR & (1<<SPIF))) ;
*ptr++ = SPDR; // save byte
  SlaveInit();
ReadByte();
for (int j = 0;j<32;j++){  // note loop values
  Serial.print(RX_Data[j], HEX);
  Serial.print(',');
Serial.println(' ');
Code:
0,40,40,20,20,60,60,10,10,50,50,30,30,70,70,8,8,48,48,28,28,68,68,18,18,58,58,38,38,78,78,4,
28,28,68,68,18,18,58,58,38,38,78,78,4,0,40,40,20,20,60,60,10,10,50,50,30,30,70,70,8,8,48,48,
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
What have you got on the Arduino's SS pin? I see you are controlling it with the master, is it connected properly?
It seems that most bytes are being received twice, if we ignore that and look at the bits in the first few values
Code:
40 10000000
20 01000000
60 11000000
10 00010000
50 01010000
30 00110000
70 01110000
8 00000100
48 01001000
28 00101000
68 01101000
18 00011000
58 01011000
38 00111000
78 01111000
We can see there is a progression of sorts from the MSB position. In fact when I did the first 3 values I thought "Yes that's it, it's an MSB/LSB problem".
I still can't get the pattern but I think it's partly to do with transmitting MSB first and receiving LSB first , or vice versa.
Check out which is being used at both ends. I don't know what the Arduino SPI library defaults to but there is a SPI.setBitOrder() function to force it.
Also just thinking about the speed, at 2MBs you have 500nS to read and store a character, that's only 8 instructions on the Arduino, not long enough to do the job I think. Slow down the master (a lot) to prove this one way or another. This does have a quasi-random look to it that might be explained by the two ends being synced but the slave not being able to keep up.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Jr. Member
View Profile
Code:
40 10000000
20 01000000
60 11000000
10 00010000
50 01010000
30 00110000
70 01110000
8 00000100
48 01001000
28 00101000
68 01101000
18 00011000
58 01011000
38 00111000
78 01111000
_____
Rob
Thx for great help.
Now i should go to work, this evening when i come back i will do some modify, but i don't understand why if i configured all in lsb i've this this problem (SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB; STM32  DORD = 1 DORD - Sends data least Significant Bit First when 1, most Significant Bit first when 0 ARDUINO
For clock i will downgrade clock speed of stm32 from 24mhz to 8 mhz then i will have a 8/12 Mhz on the SPI and i can easily see if there is a clock speed problem.
Logged
Offline Offline
Jr. Member
View Profile
ok i slowed with prescale baud rate to: (24mhz/32) and configured master as MSB:
now i have this:
Code:
0,0,1,0,0,2,3,0,0,0,1,4,4,6,7,0,0,0,1,0,0,2,3,8,8,8,9,C,C,E,F,0,
8,8,9,C,C,E,F,0,0,0,1,0,0,2,3,0,0,0,1,4,4,6,7,0,0,0,1,0,0,2,3,8,
6,7,0,0,0,1,0,0,2,3,8,8,8,9,C,C,E,F,0,0,0,1,0,0,2,3,0,0,0,1,4,4,
1,4,4,6,7,0,0,0,1,0,0,2,3,8,8,8,9,C,C,E,F,0,0,0,1,0,0,2,3,0,0,0,
0,0,1,4,4,6,7,0,0,0,1,0,0,2,3,8,8,8,9,C,C,E,F,0,0,0,1,0,0,2,3,0,
P.S.
Multiple lines isn't a problem i use a delay to master to send only 32bit, i write here more than 1 line cause it can help to identify the problem.
P.P.S
I try to change DORD, for have LSB or MSB but nothing change.
« Last Edit: August 27, 2012, 11:46:25 am by zuzzuz » Logged
Offline Offline
Jr. Member
View Profile
i try to use new libraries of spi (1.01)
Code:
#include <SPI.h>
#define SCK   13
#define MISO  12
#define MOSI  11
#define SS    10
  pinMode(SCK, INPUT);
  pinMode(MOSI, INPUT);
  pinMode(MISO, OUTPUT);
  pinMode(SS, INPUT);
  SPI.setBitOrder(MSBFIRST);
 SPI.setDataMode(SPI_MODE3);
  //SPI.setClockDivider();
  SPI.begin();
ReadByte();
  Serial.print(',');
With this code SPI doesn't starts, i should to add "SPCR = (1<<SPE); but this shouldn't be necessary from library...
if i add this i have this output:
Code:
C,F,0,1,0,3,0,1,4,7,0,1,0,3,8,9,C,F,0,1,0,3,0,1,4,7,0,1,0,3,8,9,
« Last Edit: August 27, 2012, 02:32:07 pm by zuzzuz » Logged
Offline Offline
Tesla Member
View Profile
WWW
I've run out of ideas here I think.
I see you changed the clock phase and polarity as pylon suggested in reply #1? Maybe it's worth playing with them again.
______
Rob
Logged
Offline Offline
Jr. Member
View Profile
SOLVED
Code:
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
This is the final code
Code:
#include <SPI.h>
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
 SPCR = (0<<SPIE) ;
 SPCR=  (0<<DORD);
 SPCR=(0<<MSTR);
 SPCR=(0<<CPOL);
 SPCR=(0<<CPHA);
 SPCR=(0<<SPR1);
 SPCR=(0<<SPR0);
 SPCR = (1<<SPE);
 RX_Data[i] = SPI.transfer(0x00);
  SlaveInit();
ReadByte();
  Serial.print(',');
Thx a lot for your help, without that i will leave this project some time ago.
I rewrote routine and all setting from begin, and i use a part of new libreries.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Good stuff. Often the way to fix something that just refuses to work is do a rewrite.
I still don't see why the direct approach to SPDR didn't work, I have done almost exactly the same before with no problems. Here is the code from SPI.transfer
Code:
SPDR = _data;
  while (!(SPSR & _BV(SPIF)))
  return SPDR;
Apart from writing to SPDR because it is designed to send bytes as well it's really the same as your code. Go figure.
Now that I look at this I wonder if it works at high speed, just for an exercise can you crank the master back up to 2MHz and see what happens?
After I posted last night I wondered why you weren't using the SPI library and thought I'd suggest that in the morning. No need to now smiley
______
Rob
Logged
Offline Offline
Jr. Member
View Profile
______
Rob
Now i will go to work when i will come back i will try.
Bye
Logged
Offline Offline
Jr. Member
View Profile
ok i do this test 24mhz/8 as u can see there is some error sometimes
Code:
1,2,3,4,5,2,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,6,3,8,9,A,B,C,D,E,F,10,11,12,1,14,11,16,13,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,2,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,12,17,18,19,1A,1B,1C,1D,1E,F,20,
1,2,3,0,5,6,3,8,9,A,B,C,D,E,F,0,11,12,13,10,1,16,13,8,19,1A,1B,1C,D,1E,1F,0,
1,2,3,0,5,2,7,8,9,8,B,C,D,E,F,10,11,12,13,10,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,10,5,16,17,18,19,1A,1B,1C,1D,1E,1F,0,
1,2,3,0,5,6,3,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,13,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,10,11,2,13,10,15,16,17,18,19,8,1B,1C,1D,1E,1F,20,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,4,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,2,7,8,9,A,B,C,D,E,F,10,11,12,13,14,5,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,0,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,D,1E,1F,20,
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,10,15,16,17,18,19,1A,1B,1C,1D,1E,1F,0,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,0,11,12,1,0,15,16,17,18,9,1A,1B,1C,1D,1E,1F,0,
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,0,11,12,13,14,15,2,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,1,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,12,17,18,19,18,1B,1C,1D,1E,1F,20,
1,2,3,4,5,2,7,8,9,A,B,C,D,E,F,10,11,12,13,4,5,12,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,0,5,6,3,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,0,
1,2,3,0,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,0,
1,2,3,4,5,2,7,8,9,A,B,C,D,E,F,10,11,12,13,10,15,16,13,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,12,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,2,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,2,17,18,19,1A,1B,1C,1D,1E,1F,20,
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,11,16,17,18,19,1A,1B,1C,1D,1E,1F,0,
1,0,3,4,5,2,7,8,9,A,B,C,D,E,F,0,11,12,13,0,15,12,7,18,19,A,1B,C,1D,1E,1F,0,
At 24Mhz / 16 no Error found
Code:
Bye
Logged
Offline Offline
Jr. Member
View Profile
Now i will try to do arduino as master and stm32 as slave... i hope to have less problem :p
Logged
Offline Offline
Jr. Member
View Profile
i tryed to traspose my master code to arduino i have just a slave code to stm32 that work good (tested ok)
Code:
#include <SPI.h>
const int buttonPin = 2;     // the number of the pushbutton pin
int buttonState = 0;         // variable for reading the pushbutton status
pinMode(buttonPin, INPUT);
SPI.begin();
SPI.setDataMode(SPI_MODE0);
void loop(){
   buttonState = digitalRead(buttonPin);
    if (buttonState == HIGH) {
 digitalWrite(SS, LOW);
 int a = SPI.transfer(0x12);
 digitalWrite(SS, HIGH);
In slave nothing data is arrived.
Some Idea?
Logged
Offline Offline
Jr. Member
View Profile
i try to indentify the problem with this debug..
Code:
#include <SPI.h>
#define SCK   13
#define MISO  12
#define MOSI  11
#define SS    10
uint8_t RX_Data[32] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
                       0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E,
                       0x0F, 0x10, 0x11, 0x12, 0x13, 0x14, 0x15,
                       0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C,
                       0x1D, 0x1E, 0x1F, 0x20};
  pinMode(SCK, OUTPUT);
  pinMode(MOSI, OUTPUT);
  pinMode(SS, OUTPUT);
SPI.begin();
void loop(){
  SPCR = (0<<SPIE) ;
 SPCR=  (0<<DORD);
 SPCR=(1<<MSTR);
 SPCR=(0<<CPOL);
 SPCR=(0<<CPHA);
 SPCR=(0<<SPR1);
 SPCR=(0<<SPR0);
 SPCR = (1<<SPE);
   Serial.print(RX_Data[i], HEX);
Serial.print(',');
SPI.transfer(RX_Data[i]);
 with this code i will know what i'm sending time by time, indeed i have a identify that code stops at spi.transfer routine
COM3 (serial) code:
Code:
1,
a little help?
Logged
Offline Offline
Tesla Member
View Profile
WWW
These lines
 SPCR=  (0<<DORD);
 SPCR=(1<<MSTR);
 SPCR = (1<<SPE);
 SPCR=(0<<CPHA);
 SPCR=(0<<SPR1);
Are already done by the SPI.begin(), SPI.setBitOrder() and SPI.setDataMode() functions so you should remove them.
But this line
  SPCR = (0<<SPIE) ;
Is a real problem. You are enabling interrupts and have no ISR to handle them so I'd say the code goes to la-la land after you transmit the first byte. Remember that with SPI you transmit and receive at the same time so somewhere in the SPI.transfer() function you get an interrupt from the SPI port and you don't handle it.
Remove that line and see what happens.
______
Rob
Logged
Offline Offline
Jr. Member
View Profile
thx now it's run partially. From master arduino i see this
Code:
1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,
But from slave i recive only odd from 3 to 65
Code
Code:
#include <SPI.h>
#define SCK   13
#define MISO  12
#define MOSI  11
#define SS    10
SPI.begin();
void loop(){
Serial.print(',');
SPI.transfer (RX_Data[i]);
delay (100);
« Last Edit: September 02, 2012, 07:41:45 am by zuzzuz » Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
