Topic: SPI Slave [SOLVED] (Read 8754 times) previous topic - next topic
Graynomad
How about the slave code?
Mind you if it's stm32 code using their libraries I don't know if we can help, but maybe.
Just a thought, add a small delay() here
digitalWrite(SS, LOW);
delay (10);
for (int i = 0; i < 32; i++){
Maybe the stm can't respond in time after SS goes LOW. That might explain why you are missing the first number.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
zuzzuz
delay (10);
______
Rob
I use that dalay for being sure it's not too fast than slave (cause i tryed without and i have same result) also i try with 10 but same result.
This is Slave code of stm32 (i used it with 2 stm32VLdiscovery and run good)
When i used arduino as slave i have had same problem if u remember same post ago cause "while (!(SPSR & _BV(SPIF)))".
Code: [Select]
   while (1)
     /* Transfer procedure */
     for (RxIdx=0; RxIdx < BufferSize;RxIdx++)
       //    /* Wait for SPIz data reception */
       while (SPI_I2S_GetFlagStatus(SPIy, SPI_I2S_FLAG_RXNE) == RESET);
       //    /* Read SPIz received data */
       SPIy_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPIy);
     STM32vldiscovery_LEDToggle(LED3);
this is the setting:
Code: [Select]
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPIy, &SPI_InitStructure);
Graynomad
Quote
But did you have a delay in the same place I did? It's no use after the byte has been sent (I'm referring here to the apparent loss of the first byte, not the overall problem).
What does "SPI_CPHA_2Edge" mean?
_____
Rob
zuzzuz
SPI_CPHA_2Edge = data is captured on the second edge.
rising is first edge and falling is second edge.
CPOL and CPHA have same use in stm32 like SPI.setDataMode()
Nick Gammon
http://www.gammon.com.au/spi
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
zuzzuz
Solved:
i don't know why but mode0 of arduino doesn't work with
Code: [Select]
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
That configure the same state at stm32, then i changed arduino to mode1 and stm32 to
Code: [Select]
and work good with 0x00 to 0x20 number.
Thx for help.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
