Loading...
Pages: [1]   Go Down
Author Topic: Burning Arduino to ATmega32A  (Read 711 times)
Offline Offline
Newbie
View Profile
Dear Friends,
I have an USBASP programmer and a couple of ATmega32A(unfortunately this is the most sold controller at my place) lying around. I wish to know if i can burn an Arduino Bootloader onto it to take advantage of using Arduino framework for writing my applications. Because more than AVR, Arduino suits me better for the greater society, ease in learning curve on the programming front (sorry i find Arduino a bit easier than AVR). Also I found a site where they have given the pin mapping of the ATMega32 http://retrointerfacing.com/?p=30.
Can someone help me through this? I do not mind burning my application hex files manually or to discard the Arduino IDE. All i need is a way to figure out running my Arduino framework based programs on my ATmega32 for which I believe the Arduino bootloader has to be burned into before.
Regards,
Ashok Srinivasan.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Go to www.avr-developers.com and download the files for ATMega32.
May need to create a new board type in boards.txt and make an entry in avrdude.conf after that.
IDE 1.0.1 has an updated structure that supports "variants" of microcontrollers. I'm not knowledgeable enough really descibe it better for you.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Firstly, thanks for your time and reply. Got it boss. One more thing to boot up the process, will this version work under 1.0.1 or do I have to use any specific version(ex., in the site you have mentioned 0.20)
Regards,
Ashok Srinivasan
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Give it a try with 1.0.1, can always go back to -0020 if it doesn't work.
avrdude.conf already has the info for atmega32.
You'll have to make a new boards.txt entry for the device.
Logged
Pages: [1]   Go Up
Print
Jump to:
