Loading...
Pages: [1]   Go Down
Author Topic: Arduino Bios Programmer  (Read 556 times)
California
Offline Offline
Newbie
View Profile
WWW
I need help trying to re-flash a bios chip, I looked it up on the internet and I've only found completed projects being showed, not any instructions. Can you please tell me which Arduino ports I connect this chip to: [link]http://pdf1.alldatasheet.com/datasheet-pdf/view/47677/WINBOND/W55F10.html[/link]
Also how do I program the chip with the Asus bios?
Logged
Proud Member of the Nighthawk Robotics Club Team 569 B
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
From this datasheet for the part:
I'd have to say, I don't know!
I would guess you could connect it to any 6 pins you wanted and then bit-bang out the transfers, possibly 32 bits at a time, with the up to 128K of data ( 1 Mbit for the W55F10) coming in from a PC.
The different Modes are not explained at all. Perhaps more data is available on the datasheets for these other parts:
"The W55FXX is a serial input/output flash EEPROM series that is typically used as the memory cell
of a W51300 (voice recorder controller) or the ROM code emulator for the PowerSpeechTM series."
Try searching the Playground for a Library for this part, maybe you'll get lucky.  If not, you need to do some more research more first.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
California
Offline Offline
Newbie
View Profile
WWW
I can't really find any information on this, I've tried to research it but I'm confused.
Logged
Pages: [1]   Go Up
Print
Jump to:
