Topic: Pushing a buttom with servo (Read 1 time) previous topic - next topic
Browser
Hello,
i am trying to push a button with a servo. I need to push it with different pressures, so i have to control the pressure.
Any idea about can i do it?
Thanks.
johnwasser
Put a spring between the button and the pushrod from the servo.
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
Browser
I don't understand what you mean. I have tried with elastic to push it. It's the button of a spray
johnwasser
Are you sure the button responds to different pressures?
What do you expect to happen?
What is happening?
Browser
Yes, of course, depend on the strength the painting is different.
I want to control from the arduino board the strength to press the spray.
I don't know how can i make something to push the spray's head (button)
johnwasser
A servo will turn a disk or arm.  Connect a stick to the disk or arm and when the disk or arm rotates it will push or pull the stick.  The stick is called a pushrod.
retrolefty
I assume then that the 'spray button' has a finite travel range that causes it to travel through full off, some variable spray to full spray? So it would seen that you just need to mechanically couple a servo arm such that you can manipulate the spray buttons travel range via the specific servo position. Your servo must also have a torque rating high enough to overcome the force/friction of the button and cause this travel, via the servo's basic torque rating and/or by using mechanical leverage linkage such that the desired travel and torque requirements are both met.
Lefty
zoomkat
You may want to get a cheap spray can holder like below and modify it to work with a servo.
https://www.google.com/search?q=can+spray+paint+gun&num=100&hl=en&lr=&newwindow=1&safe=off&as_qdr=all&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=4LMuUNizGdStyAH7p4DoDw&ved=0CIwFELMY&biw=1291&bih=627
