Topic: General advice needed! Audio codec sheild or other DSP? (Read 1 time) previous topic - next topic
mattomatto
Hi there,
I have been making small synths with the atmega328 for sometime and am starting to get frustrated with the quality of sound. I can run about 5 oscs at 12 bit, 8kHz (with a lot of noise).
I have seen the MICrODEC and Audio Codec sheild here: http://www.openmusiclabs.com/projects/codec-shield/ and have a few questions...
It appears that the Codec chip used in these products is used to clock the atmega. I don't really understand why the codec is needed if the atmega is running at ~44kHz and telling the codec exactly what to do, couldn't the atmega be doing it itself?
I want to be able to make something with lots of voices and oscillators, with a high sound quality.  Further down the road, I'd like to playback samples too.  Should I just try and get into proper DSP programming or could I potentially be doing all this with my own version of something like the wavesheild / MICrODEC?
All advice is greatly appreciated.
Matt
mattomatto
Wow over 100 views and no replies!
Well, if anyone is interested, I just bought a dsPIC33F and a microstick II.  A little worried about the lack of support for noobs, but hopefully I'll be making quality noises soon enough.
brandondrury
Great questions.  I'm curious of the answers myself.   :D
DuaneB
I was probably one of the 100 - as far as audio goes I am a total noob, but interested, hence I had a look but had nothing to add.
Still interested in what you are doing though so keep us updated.
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
ryansupak
Arduino noob here, but experienced programmer/systems engineer. I think that Arduino can do all the things the Audio Codec Shield can do, but they've done a lot of the "piddly work" for the user, added hardware connections, etc... rs
Nantonos
You lost me at
could you explain that part?
