Loading...
Pages: [1] 2   Go Down
Author Topic: Transferring an Integer under 100 us  (Read 455 times)
BC, Canada
Offline Offline
Newbie
To fail or not to fail
View Profile
Hello All,
I'm working on a project that has two Arduinos: one to drive a stepper motor and another to read a sdCard and figure out how many motor steps are required.  Currently, I have the sd Arduino read the card, convert the file and fill an array with those steps.  The sd card then sends the steps over to the motor controller arduino via I2C and the motor controller runs the array.
I want to make it so I don't require an array anymore.  I want the sd Arduino to feed an integer of motor steps to the motor Arduino during the motor's downtime.  I've calculated the downtime to being no less than ~120 microseconds.
Is there an easy way to do this?
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Quote
Depends on what's easy for you.
With this description http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1241668644 you can increase the speed of the I2C to 400kHz. This way you should be able to transmit an integer in about 50us.
Although, from your description I don't get the reason to do so. Maybe you describe in a bit more detail to let us comprehend the reason.
Logged
BC, Canada
Offline Offline
Newbie
View Profile
Thanks pylon!  I assumed the I2C bus was already confirmed to run in Fast mode.  It lowers the time from ~330 us to ~130 us which still isn't enough.  I also found that the Adafruit Touch screen shield does not like I2C set to Fast Mode.
The reason I need this done is to allow the motor to run without any interruption.  I want to feed the motor controller arduino commands and values without interrupting the motor at its fastest speed.  I also want to drop using an array so I'm no longer limited by the memory size on the controller.
Logged
USA
Offline Offline
God Member
View Profile
How big are these values?  Could they fit in a byte (0 to 255) instead?
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
You didn't mention that a touch shield is involved. How many integers do you need to transfer? 3?
Logged
BC, Canada
Offline Offline
Newbie
View Profile
The integers can go from -800 to +800.
I expect to send an integer every 100 ms.  The integer is how many steps the motor must take for the next 100 ms period.  I could break up the integer into a LSB and MSB and send only a byte per step (reassembling the bytes into an integer on the third step), but I am hoping there is a comm protocol fast enough to do it in one shot.
Logged
USA
Offline Offline
God Member
View Profile
Then that's a no go on my idea...
Well there is Serial Peripheral Interface, which can achieve faster communication between individual microcontrollers, and some other devices as well, than I2C.  Unless your implementation somehow precludes using SPI, it could be a better communication option between the Arduinos at least.
Logged
Southampton, UK
Offline Offline
Newbie
View Profile
WWW
With the steppers there is certainly SPI, but you are reliant on being able to read the SPI (and the data being present) between issuing steps to the stepper motor... which you have told us is 120us, which ain't a lot. Linking the two cards with an 8 bit bus as farseeker was alluding to is probably more reliable.. if the value is -800 to 800 you can do that with an 11 bit bus... i.e. 11 digital lines on one arduino linked to 11 digital lines on the other... but timing will be an issue I think.
This does demonstrate the inherent problem of stepper motors and microcontrollers... you have to keep telling the motor to keep going around, leaving little time for other tasks. Consider using a DC motor and an encoder with a PID controller algorithm... you'll have plenty of time (easily 5000-1000us) between the PID calculations to do all manner of things, like read the SD card thus eliminating an entire arduino.
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Quote
This kind of integers does perfectly fit into two bytes. With a 400kHz I2C you need about 50us to transmit 2 bytes. How do you get to 130us?
Logged
USA
Offline Offline
God Member
View Profile
Quote
Recall that this project has to communicate between two Arduinos, then from the second Arduino to the stepper motors.  With two transimissions of ~50 µs, plus the processing time on the second Arduino, I can see how the total time could exceed 130 µs.
Edit: Typo
« Last Edit: August 20, 2012, 09:59:02 am by Far-seeker » Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
For numbers of that magnitude, you only need eleven bits, not sixteen.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
BC, Canada
Offline Offline
Newbie
View Profile
Quote
Edit: Typo
Correct.  I also need to figure out which integer to send and to break the integer up, send the integer bytes, and then reassemble the integer.
Turns out SPI was the answer.  I'm getting around ~52 us from start to finish.  It's a bit more complicated to set up a Salve, but well worth the effort.
Thanks to everyone for the input.
Logged
USA
Offline Offline
God Member
View Profile
I'm glad you found a solution that worked for you! smiley
Logged
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
Gee, I was going to suggest choose eleven pins and bit bang the heck out of them using the direct port manipulation method.  You should be able to get at least that much speed out of it, maybe more like a few us per port (pair) update.
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Why do you need 2 unos?. Can't you just read from the SD card and then output the value?
Mark
Logged
Pages: [1] 2   Go Up
Print
Jump to:
