Topic: Determining the Cause of MCU restart - Atmega168 (Read 627 times) previous topic - next topic
mr_LYI
I have found a trouble in determining the cause of Atmega168 restart.
According to the documentation, the 3rd bit of the MCUSR register should be 1 if MCU restarted due WDT (00001000b).
But seems that this bit is never 1.
Checked other bits - PowerUp bit (00000001b) is working correctly.
Wasnt able to find anything about this in errata...
Hope someone have solved this somehow and can help with the issue.
Thanks
westfw
The Arduino bootloader intercepts all resets, and will likely interfere with the user sketch determining the reason for reset.  (this is certainly true of Optiboot: http://code.google.com/p/optiboot/issues/detail?id=66 )  Whether it's true of 168-based arduinos (which run one of several other bootloaders) is uncertain...)
