Topic: Using analogReference() (Read 14821 times) previous topic - next topic
ScottG
I have a couple questions about using analogReference on an Pro Mini 3.3volts.
If I set the reference to 1.1volts with analogReference(INTERNAL), I assume it's till okay to have the actual voltage on the pins go up to 3.3 volts.  Is that correct?
Can I change the analogReference before I read an input, then change it back to read a different input. Any issues with doing this.  For example:
Code: [Select]
analogReference(INTERNAL);
analogRead(0);
analogReference(DEFAULT);
analogRead(1);
retrolefty
Yes, electrically no problem, however all values above 1.1vdc will read as 1023 counts.
Code: [Select]
analogRead(0);
analogRead(1);
Yes in theory it will work, but I've found that a analogRead() right after a change in analogReference() will usually return a 'faulty' value. I've usually do a couple of analogReads on the same pin after such a reference change and the last reading tends to be OK. You may have to play around with it to see what you get.
Lefty
runaway_pancake
http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
ScottG
That's a neat trick, I'm gonna have to try it out
jerrymonkey123
Code: [Select]
int A0 = analogRead(0)*(1.1/5);
analogRead(1);
