Topic: Quick IR Question (Read 823 times) previous topic - next topic
DuaneB
   Can anyone confirm for me that the different frequencies of IR Detectors available have their band pass filters tight enough that I could point a 40Khz transmitter directly at a 38Khz receiver at close range without it detecting the signal ?
Its a neat solution to running multiple cars on my laptimer boxes if its possible.
All of the boxes are 38Khz at the moment so single car only unless I build a multi car protocol in software, I would much rather just use a 50 cent component if its possible.
http://www.youtube.com/watch?v=ryQFShhtzlQ
Thanks
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
westfw
No; pick them further apart if you can (33kHz and 40kHz, for example.)
(This is from the datasheet, which typically show 40% sensitivity at 10% off-center frequency, in a nice bandpass-filter-shaped graph somewhere.  I haven't actually tried it, though I was considering a similar application at various times.)
DuaneB
   Thats disappointing. I will order some from either end of the available range as you suggest and see how I get on, I really don't want to have to do this in software if I can get a piece of  50 cent hardware to do it.
Thanks
Duane B
Read this
then watch this
oric_dan
westfw is 100% correct about the rolloff characteristics. Look in the datasheets.
A while back, I built my own IR proximity detectors that had adjustable detection
ranges, going from about 18" down to 6". I simply varied the driving frequency on
the IR Led from about 32-38 khz, and took advantage of the rolloff in sensitivity.
DuaneB
Thats a really neat idea, I had seen an approach where the emitter is driven through different resistors to sense reflection at different ranges, but your approach gets away from the need for additional components.
Unfortunatley for me though, it looks like I am stuck with implementing a software solution or maybe building some very tight filters with opamps might be an option ?
Duane B
Read this
then watch this
jackrae
Couldn't you superimpose different coded data stream loops onto each of the 38kHz signals and interpret from the data stream which car is sensed.
DuaneB
Yes, but If I could have done it in hardware for 30 cents I would have preferred to, here is a candidate solution -
http://rcarduino.blogspot.com/2012/08/lap-timer-potential-coded-transponder.html
Other than that I can get at least two cars running using 555 Timers, one with a long pulse and the other with rapid short pulses, it should be trivial to tell the two apart in software.
Duane B
Read this
then watch this
oric_dan
IR detectors come in different frequency ranges, eg 32, 38, something else, and
56-Khz ranges as I recall. You might be able to get adequate isolation by using
one 32 and one 56 Khz device.
DuaneB
That sounds like a viable option, I will have a look what I can order in the UAE,
Thanks
Duane B
Read this
then watch this
cragv
Hope it's okay to reply to such an old thread but it's exactly what I've been looking to find!
Duane, did you ever end up testing multiple iR detectors with different ranges with multiple vehicles/matching emitters?
I was following your build back in 2012 and very much enjoyed the build-along (link to related thread here). It would seem you've moved onto other things since then, but if you have a minute to reply here, I'd be awfully appreciative! If you're reading this, please also consider sharing your most recent code for this excellent little project. Your blog says to ask you here on the forums, so here I am - please send if you can. Thanks very much indeed!
(I may very well try multiple detectors and emitters myself if I don't hear back - will post here if/when this is done so that this old thread may finally get some closure! Cheers).
