Topic: High current LED's (Read 908 times) previous topic - next topic
soundguymatt
hi there all
for one of my projects I'm looking at using multiple high current RGB LED's, 3W LED's where each colour is 1w. I know Arduino cannot cope with that so i need something between the two - i looked at a Darlington array ULN2803A but that has a maximum of 500mA - i think i need 1A of more.
Any other idea's on how to amplify the PWM signal - or any other ways of doing it?
Many thanks
Matt
Grumpy_Mike
You can't just switch a high current LED like you can a low current one. You need to use a constant current driver. Either purchased or one you make yourself.
ardudillo
Check this out:
http://www.instructables.com/id/Circuits-for-using-High-Power-LED-s/?ALLSTEPS
(step 8 ).
I 've tried it out with an Arduino and works quite well.
mcreefer
I used this
https://www.sparkfun.com/products/10256
like this
http://bildr.org/2012/03/rfp30n06le-arduino/
To run my 20W led. Works great with PWM.
