Topic: Arduino LM335 and visual basic 6 (Read 5857 times) previous topic - next topic
fenderrobban
Hi!
I am trying to send a temperature (LM335) from the arduino to my visual basic 6.0 program and sofar i get the correct temp inside the "serial monitor" but when i try to receive it in VB6 all i get is a large number.
ex
Serial monitor  24.11
VB6 11870
hereĀ“s the vb program
Private Sub Form_Load()
' Fire Rx Event Every Two Bytes
MSComm1.RThreshold = 2
' When Inputting Data, Input 2 Bytes at a time
MSComm1.InputLen = 2
' 2400 Baud, No Parity, 8 Data Bits, 1 Stop Bit
MSComm1.Settings = "9600,N,8,1"
' Make sure DTR line is low to prevent Stamp reset
MSComm1.DTREnable = False
' Open COM3
MSComm1.CommPort = 3
MSComm1.PortOpen = True
End Sub
Private Sub MSComm1_OnComm()
Dim sData As String
Dim lHighByte As Long
Dim lLowByte As Long
Dim lByte As Long
' If Rx Event then get data and process
If MSComm1.CommEvent = comEvReceive Then
    sData = MSComm1.Input ' Get data
    lHighByte = Asc(Mid$(sData, 1, 1)) ' get 1st byte
    lLowByte = Asc(Mid$(sData, 2, 1))  ' Get 2nd byte
    lByte = JoinHighLow(lHighByte, lLowByte)
    Label2.Caption = CStr(lByte)
    DrawScale lByte
End If
End Sub
what do i do wrong?
i want to get 24 in the vb6 instead
robban
PaulS
Code: [Select]
Gets the data as a string.
Code: [Select]
Pretends that you got binary data. You didn't.
Why are you doing that?
fenderrobban
i tried the
mscomm1.input=sdata
label2.caption=sdata
but all i get is the last decimals of the temp.
here is my arduino program
float temp_in_celsius = 0, temp_in_kelvin=0, temp_in_fahrenheit=0;
  //Reads the input and converts it to Kelvin degrees
  temp_in_kelvin = analogRead(0) * 0.004882812 * 100;
  //Converts Kelvin to Celsius minus 2.5 degrees error
  temp_in_celsius = temp_in_kelvin - 2.5 - 273.15;
  temp_in_fahrenheit = ((temp_in_kelvin - 2.5) * 9 / 5) - 459.67;
  //Print the temperature in Celsius to the serial port
// Serial.print("Celsius: ");
  Serial.print(temp_in_celsius);
  //Print the temperature in Fahrenheit to the serial port
  //Serial.print("Fahrenheit: ");
  //Serial.println(temp_in_fahrenheit);
// Serial.println();
what is wrong?
PaulS
Quote
but all i get is the last decimals of the temp. ... what is wrong?
You are sending strings that have no delimiters between packets, and relying solely on data arriving in a timely fashion.
For certain baud rates, on lightly loaded PCs, that will work for a short period of time. For robust communications, you need to send start and end of packet markers between the strings.
Then, read data on the PC, appending it to a buffer until the buffer contains a start and end of packet marker. When it does, extract the value between the markers.
The Arduino should send something like "<19.5><19.6><19.5><19.4>".
fenderrobban
How would the code look like?
(pretty new with arduino)
PaulS
Quote
Very similar to what you have, except you need two more Serial.print() statements:
Code: [Select]
  Serial.print("<");
  Serial.print(">");
fenderrobban
ok,thanks, tried it in vb6 but i cant seem to get it right..
ideas?
PaulS
Quote
Tried what in VB6?
Quote
ideas?
Oh, I don't know. Maybe post your code.
fenderrobban
MSComm1.RThreshold = 5
MSComm1.InputLen = 5
' Open COM3
End Sub
Dim sData As String
Dim lByte As Long
If MSComm1.Input = "<" Then
Do
Label2.Caption = sData
Loop Until sData =">"
End If
End If
End Sub
PaulS
Code: [Select]
So, why is the length 5?
Quote
This event fires when there is some serial data to read - not just when there is a complete packet. It is up to you to read and store data until a complete packet (or more) has arrived.
Quote
The Input field contains all the data that has arrived so far, NOT just one character.
You need to define a String object that you append any serial data to. When all the available data has been read, you need to see if that String object contains a < and a >. If it does, extract the portion up to the >, then strip off the first character. What will be left will be the packet contents.
fenderrobban
ok, i changed it to the following
' Open COM1
End Sub
Private Sub Timer1_Timer()
Dim sData As String
    If sData = "<" Then
    Do
    Loop Until (sData = ">")
End If
End If
End Sub
but still nothing,just 0 :-(
RPCoyle
This works for me. You should be able to modify it to get what you want.
Code: [Select]
Function TempNow() As Single
Dim str As String
Dim strt, fin, ct As Integer
Dim tempstr As String
Dim u As Single
Dim i, B  As Integer
u = 0
str = ""
For i = 1 To 5
Sleep 10
str = MSComm1.Input
' I use "Tmp and "@" instead of "<" and ">"
If InStr(str, "Tmp") > 0 And InStr(str, "@") > 0 Then
  GoTo J1
End If
Next i
J1:
ct = 0
u = 0
 strt = InStr(str, "@-") + 2
 fin = InStr(str, "-Tmp")
 If (fin - strt) <= 0 Then
  Exit Function
 Else
  ct = ct + 1
  u = u + Mid(str, strt, (fin - strt))
End If
TempNow = u / ct
If Option1.Value = True Then
   TempNow = TempNow * (9 / 5) + 32
End If
End Function
fenderrobban
ok, i copied your program and pasted it into mine, deleted my "oncomm..." etc and added at the end of your program label2.caption=Tempnow
i changed my < and > to your Tmp and @ in the arduino
but still nothing
here is the vb program
' Open COM1
End Sub
Dim str As String
Dim u As Single
Dim i, B  As Integer
u = 0
str = ""
For i = 1 To 5
Sleep 10
str = MSComm1.Input
   GoTo J1
End If
Next i
J1:
ct = 0
u = 0
   Exit Function
  Else
   ct = ct + 1
End If
TempNow = u / ct
    Label2.Caption = TempNow
End If
End Function
and here is the arduino program
  Serial.print("Tmp");
  Serial.print("@");
getting a headache...:-(
RPCoyle
the Arduino code is ok. I ran it and it showed the correct values in my VB program, so it's coming across the USB ok
Here is the code I use to find the correct com port. It cycles through until it finds a com port sending out the correct string
you will have to declare some of the variables to get it running, but it
stick some debug.print statements in the code and step through it. You should be getting values comming over if the baud rate is set correctly
also, you need to put the VB side read insome kind of loop also so it will keep reading the input
Code: [Select]
For n = 1 To 16 ' com ports
  ' close any open ports
  If MSComm1.PortOpen = True Then MSComm1.PortOpen = False
   On Error Resume Next
   MSComm1.CommPort = n
   MSComm1.InputLen = 0
   If MSComm1.CommID > 0 Then
     For i = 1 To 100 ' keep looking
      str = ""
      str = MSComm1.Input
      ' finds the port sending out the correct string.
      If InStr(str, "Tmp") > 0 And InStr(str, "@") > 0 Then GoTo jump:
      Sleep 50
     Next i
  End If
Next n
jump:
PaulS
Code: [Select]
If you are not going to maintain the comments, delete them. Otherwise, they make you look like an idiot.
