Topic: Arduino LM335 and visual basic 6 (Read 5564 times) previous topic - next topic
fenderrobban
#15
Aug 21, 2012, 04:09 pm Last Edit: Aug 21, 2012, 10:06 pm by fenderrobban Reason: 1
Hi again
i tried RPcoyls program, and it seems that it finds the right comport (3),however i cant get the temp to display
here´s the program, all that happends is that the label1 disapears...:-(
please help
Private Sub Timer1_Timer()
Dim n As Long
Dim str As String
Dim i As Long
For n = 1 To 16 ' com ports
  ' close any open ports
  If MSComm1.PortOpen = True Then MSComm1.PortOpen = False
   On Error Resume Next
   MSComm1.CommPort = n
   MSComm1.InputLen = 0
   If MSComm1.CommID > 0 Then
     For i = 1 To 100 ' keep looking
      str = ""
      str = MSComm1.Input
      ' finds the port sending out the correct string.
      If InStr(str, "Tmp") > 0 And InStr(str, "@") > 0 Then GoTo jump:
      Label2.Caption = n
     Next i
  End If
Next n
jump:
Label3.Caption = str
End Sub
fenderrobban
i wonder if the code below is written for vb6 or some newer versions
The command " SLEEP 10" shows " Sub or function not defined"
i am running vb6 and all i get is 0
the string is ex "TMP22.15@"
in timer1 i have
call TempNow
label5.caption=TempNow
Function TempNow() As Single
Dim str As String
Dim strt, fin, ct As Integer
Dim tempstr As String
Dim u As Single
Dim i, B  As Integer
u = 0
str = ""
For i = 1 To 5
Sleep 10
str = MSComm1.Input
' I use "Tmp and "@" instead of "<" and ">"
   GoTo J1
End If
Next i
J1:
ct = 0
u = 0
  strt = InStr(str, "@-") + 2
  fin = InStr(str, "-Tmp")
  If (fin - strt) <= 0 Then
   Exit Function
  Else
   ct = ct + 1
   u = u + Mid(str, strt, (fin - strt))
End If
TempNow = u / ct
If Option1.Value = True Then
    TempNow = TempNow * (9 / 5) + 32
End If
End Function
RPCoyle
Quote
Re: Arduino LM335 and visual basic 6
Yes it is written for VB6... isn't that what you are using?
fenderrobban
yes. i use vb6, then i don´t understand why i can´t get the temperature to show..
PaulS
Code: [Select]
call TempNow
You are setting the caption to a function. Why? What is that supposed to accomplish?
Code: [Select]
For i = 1 To 5
Sleep 10
str = MSComm1.Input
   GoTo J1
End If
Next i
Try 5 times to read all data that has arrived so far. Hope like hell that one of those 5 times will contain a whole packet.
It does NOT work that way. Once you have read the data that has arrived so far, that data gets thrown away if it is not a complete packet. It is likely that it won't ever be.
You need to read each partial packet, and APPEND it to some other string. Then, test that other string to see if it contains a complete packet. Do NOT erase the other string. Ever. Just remove the complete packet from the front, and append data to the end.
fenderrobban
the label5.caption= TempNow is just for displaying the temperature, is there another way when using Functions,please tell me..
so i basically could remove the whole "For i=1 to 5"  line?
or decrease it to 1...3?
Do you mean something like
a=left(str,3,1)
b=right(str,9,1)
c=mid(str,b-a)
if not....please write an example, i think i understand it better that way.
PaulS
Quote
The first call to the function will collect information from the serial port, and throw it away. Then, you assign the result of the 2nd call to the caption. By the time the 2nd call is made, there is no serial data to read.
Quote
You're not listening. Perhaps I could illustrate the point this way:
What you need to do is...
(I'll put some more of the answer in the next post, but you can't read it until tomorrow, by which time you'll have forgotten the partial answer you got today.)
RPCoyle
Try this... start a new project in the VB IDE. Create a form and put a VB com control component on it. open the code window and paste the following code into it. be sure and change the com port to the one the Arduino is using. Make sure you have the Arduino IDE closed or the VB app will not connect.
open the immediate window in the VB IDE
This is the simplest possible case. If should work if you are sending a string with a @ in it .
Code: [Select]
Private Sub Form_Load()
With MSComm1
        If .PortOpen Then .PortOpen = False
        ' change this to the com port shown by the arduino
        .CommPort = 3
        .Settings = "9600,N,8,1"
        .DTREnable = True
        .RTSEnable = True
        .RThreshold = 4
        .SThreshold = 3
        .PortOpen = True
  End With
End Sub
Private Sub MSComm1_OnComm()
Dim strData As String
Static strBuffer As String
Dim strWords() As String
Dim intPos As Integer
Dim boComplete As Boolean
Dim mystr As String
        mystr = "" ' set the string to nothing
        mystr = MSComm1.Input
            intPos = InStr(mystr, "@")
            If intPos > 0 Then
            Debug.Print mystr
           End If
End Sub
fenderrobban
Thanks for the hint....beginning to understand it...But
after doing what you said this is the output:
@24.
15@
@24.
15@
@24.
15@
@24.
15@
67@
@24.
64@
@24.
15@
@24.
15@
@23.
67@
is it my Arduino program? here it is
float temp_in_celsius = 0, temp_in_kelvin=0, temp_in_fahrenheit=0;
  //Reads the input and converts it to Kelvin degrees
  temp_in_kelvin = analogRead(0) * 0.004882812 * 100;
  //Converts Kelvin to Celsius minus 2.5 degrees error
  temp_in_celsius = temp_in_kelvin - 2.5 - 273.15;
  temp_in_fahrenheit = ((temp_in_kelvin - 2.5) * 9 / 5) - 459.67;
  //Print the temperature in Celsius to the serial port
  // Serial.print("Celsius: ");
  Serial.print(temp_in_celsius);
  Serial.print("@");
  //Print the temperature in Fahrenheit to the serial port
  //Serial.print("Fahrenheit: ");
  //Serial.println(temp_in_fahrenheit);
  // Serial.println();
tried to change the
RThreshold = 4
SThreshold = 3
to
.RThreshold = 5
.SThreshold = 3
and then the outcome is:
23.67@
24.15@
23.67@
23.67@
24.15@
23.67@
24.15@
24.15@
24.15@
24.15@
24.15@
CLOSER!!!:-) but how to i get rid of the @
second question
can i use this in a label or ex mschart?
RPCoyle
you are pretty much there fenderrobban as far as I/O from the Arduino to the VB app.  You need to learn to use some of the string functions in VB. Look at my previous post with instr and mid and figure out what I am doing to pull the info out of the total string coming over from the Arduino.
The last Arduino code you sent had pretty much all commented out. you need a Serial.println() to terminate the string. look at what is coming out the Arduino side and compare it with what you have coded it to expect on the VB side
You can use VB to display the results in the form as a text box or label, or even drop them into a list box. You just need to take one step at a time and build your code on that.
I used the debug.print just because it was the easiest way to see if you were getting anything over the line.  Now you can use any of the widgets or functions in VB to manipulate it and get the output you want
Charting the output will require you to really know what you are doing in VB. Don't even think of it till you have a much better understanding of how to manipulate string and numeric values in VB. The chart widgets included in VB are not that good, and they are kind of hard to learn, unless you have a pretty good feel for what you are coding.
fenderrobban
ok, i understand,reason i ask about "getting rid of "@" is because i want to use that as a startbyte..
Story is....i am planning to build a computerized greenhouse and there will be about 10 to 15 diffrent sensors  attached to the arduino.
so from what i have understood i want something like.
s122.11@s266@s323.11......
where s1 s2 and s3 etc is the diffrent sensors
hope you understand
RPCoyle
Yes you can send a long string over from the Arduino like  @a13.98b200c0.079d346e122.7 and use the VB string functions to select out each sensor value. You might write a function to simplify this
function GetSensorVal(BeginingLetTer,EndingLetter)  returns float or whatever
then to get the first value you could just call Val1 = GetSensorVal("c","d") and it would give you 0.079
You really don't need the @. I just used it as the start of the string since I am looking at only one temperature value and it made a good character to use when I was trying to identify the correct com port.
fenderrobban
will try that.
now i have been able to get 2 sensors inplace however, if the second sensor shows a value less then 10 och more than 100 the strings get confused.
i beleive it is the threshold for mscomm1....cause if i incresase it by 1 and have a sensorvalue of ex 20 then the program program works fine but if it is less then 10 i have to decrease it by 1 and increase if sensorvalue is more than 100
how can i make the thresholds automaticlly sens how long the mystr is?
RPCoyle
Quote
if the second sensor shows a value less then 10 or more than 100 the strings get confused.
on which end the VB or Arduino?
Quote
The com port only sees characters coming through.You need to use the string functions to find the start and end of the value you are looking for. Then if it is a 10 or a 1000 will make no difference.
so if your input string is a10b or a1000b it makes no difference to the code below
Code: [Select]
strt = InStr(str, "a") +1  ' one char past the a
 fin = InStr(str, "b")
  Exit Function
 Else
  SensorVal =  Mid(str, strt, (fin - strt))
fenderrobban
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
