Loading...
Pages: [1]   Go Down
Author Topic: Arduino Ethernet board serial connection to PC  (Read 525 times)
Offline Offline
Newbie
View Profile
Hi everyone,
I recently bought an Arduino Ethernet board, but I didn't buy the USB2Serial adapter so I'm having a buig time problem connecting my board with the computer, I tried connecting the board directly to a PC that has a Serial Port installed. I connected the GND, TX and RX to the respective GND, RX and TX of the Arduino Ethernet serial connection. I have the board energy supplied buy a 12V source but I'm not able to identify, send or receive information from the board. Since the the arduino program emulates a serial port when using a USB connection I thought I could simply connect to it towards a real serial port. Is it not possible to connect directly using a serial port? Should I just buy the USB2Serial adapter?
thank you for your help,
Rui Pedro
Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
Which ethernet board did you buy?
Logged
Offline Offline
Newbie
View Profile
I bought the Arduino Ethernet board w/o PoE, here is the link:
http://arduino.cc/en/Main/ArduinoBoardEthernet
thank you for your reply smiley
Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
That page tells you what you need to know to program the board: The 6-pin serial programming header is compatible with the USB Serial adapter and also with the FTDI USB cables or with Sparkfun and Adafruit FTDI-style basic USB-to-serial breakout boards.
Look here: https://www.sparkfun.com/search/results?term=ftdi&what=products
And here: https://www.adafruit.com/index.php?main_page=adasearch&q=ftdi
Logged
Offline Offline
Newbie
View Profile
Thank you very much for your reply, nevertheless I was wandering if it's possible to connect the 6pins directly to a Serial Port of a computer (I have a computer with a serial port) instead of using it's USB port. I thought since I have a serial port I wouldn't need the USB converter because I could connect it directly to a serial port in my PC.
I tried connecting it, but the PC doesn't recognize anything.
Logged
Tucson, AZ
Offline Offline
Sr. Member
View Profile
This will explain why that will not work.
http://www.sparkfun.com/tutorials/215
Logged
Offline Offline
Newbie
View Profile
Thanks a lot for your help smiley
Logged
Offline Offline
Newbie
View Profile
Is it possible to use arduino uno as ISP to program forementioned arduino ethernet?
Logged
Pages: [1]   Go Up
Print
Jump to:
