Topic: UNO R3 ISP trouble (ATtiny45) (Read 4664 times) previous topic - next topic
winter14
With the "Fade" sketch working properly I removed the LED and used the Arduino IDE to verify the "Blink" sketch so I could get the address of the temporary .hex file. Then I used the AVRdude command line to try and burn the "Blink" hex file to the ATtiny45. Again, I got the "programmer is not responding" error:
Attempt using "stk500v1" as programmer:
Roberts-MacBook-Pro:~ robertwinter$ avrdude -p t45 -P /dev/cu.usbmodemfa131 -c stk500v1 -U flash:w:/var/folders/d2/j8mp7t8j3ng3dgflw6j29c5w0000gn/T/build3844067978631596133.tmp/Blink.cpp.hex
avrdude done.  Thank you.
Attempt using "arduino" as programmer:
Roberts-MacBook-Pro:~ robertwinter$ avrdude -p t45 -P /dev/cu.usbmodemfa131 -c arduino -U flash:w:/var/folders/d2/j8mp7t8j3ng3dgflw6j29c5w0000gn/T/build3844067978631596133.tmp/Blink.cpp.hex
After the AVRdude failed to burn the blink.hex file I plugged the LED back in and the "Fade" sketch is still running properly. Again, thanks for all the help. Hopefully I'm getting close to getting this thing to work.
Erni
#16
Aug 21, 2012, 08:35 pm Last Edit: Aug 21, 2012, 08:51 pm by Erni Reason: 1
In the verbose output when uploading you should see a line somthing like this:
avrdude.conf -v -v -v -v -pattiny85 -cavrispv2 -P\\.\COM2 -Uflash:w:C:\Users\EC\AppData\Local\Temp\build7624827821914026099.tmp\Blink.cpp.hex:i
So you could substitute the blink.hex whit the firefly.hex just to be sure that the command line is right
winter14
I think you may have figured it out!!! I found that line and typed this into the AVRdude command line:
avrdude -v -v -v -v -pattiny45 -cstk500v1 -P/dev/cu.usbmodemfd121 -b19200 -Uflash:w:firefly.hex
...and it looks like IT WORKED!!! The only thing to do now is remove the ATtiny45 from the breadboard, solder it to the surfboard, and test it! I'll report back. Thanks!
winter14
#18
Aug 22, 2012, 12:08 am Last Edit: Aug 22, 2012, 12:18 am by winter14 Reason: 1
I am pleased to announce that it worked!!! I'll be making an Intsructable teaching other people how to load .hex files onto the ATtiny45 using the Arduino as an ISP. Hopefully I can save someone else the headache. Thanks again for all your help!!
wannabe_pilot
oh man this would very much be appreciated  :)
mtD
any progress about it? I've same problem :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
