Loading...
Pages: [1]   Go Down
Author Topic: arduino leonardo and processing serial issues  (Read 1128 times)
italy
Offline Offline
Full Member
Muuuuu
View Profile
hello, I have a problem communicating with my arduino leonardo.
This is the processing code:
Code:
    import processing.serial.*;
    Serial myPort;  // Create object from Serial class
    int val;      // Data received from the serial port
      size(200, 200);
      // I know that the first port in the serial list on my mac
      // is always my  FTDI adaptor, so I open Serial.list()[0].
      // On Windows machines, this generally opens COM1.
      // Open whatever port is the one you're using.
      String portName = Serial.list()[1];
      println(Serial.list());
      myPort = new Serial(this, portName, 9600);
    void draw()
      if ( myPort.available() > 0) {  // If data is available,
        val = myPort.read();         // read it and store it in val
        print((char) val);
and this is the arduino one:
Code:
      Serial.begin(9600);                    // Start serial communication at 9600 bps
        while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
        Serial.print("hoila ");               // send to Processing
        Serial.print("hoibo ");               // send to Processing
I receive all char if I use another arduino (not leonardo), or anoter serial terminal with leonardo, but with arduino leo and processing connected on the serial port nothing is read.
Do you have any idea?
thanks in advance
Logged
California
Offline Offline
God Member
View Profile
WWW
Is the Processing machine an WinXP?
I have the same issue on serial on a WinXP but not on Vista Machine (Have not tested Win7).
Logged
Offline Offline
Newbie
View Profile
I'm having the same issue but trying to interface with a vb.net application. I can send data to the Leonardo fine (and the Leonardo can read it) but when I try to make the Leonardo send anything back I never can get it to fire any kind of data received function in vb.net. The code I've been toying with works fine on an UNO though.
Logged
California
Offline Offline
God Member
View Profile
WWW
Yeah, I even did a Hot Fix to update the usbser.sys... no change.  I am curious on how cantore got it to output in another terminal program.  I tried teraserv and hyperterm...no joy.  cantore has success w/ Win7 and I did with Vista.
Logged
Offline Offline
Newbie
View Profile
Can you get it to receive messages from the computer, just not send any that the computer can catch or are you not getting anything at all either direction?
Logged
California
Offline Offline
God Member
View Profile
WWW
I can get it to actually receive a sketch.  I have sent the "fade" sketch switching from D9 to D13 and it works perfectly.  If I try to read anything from the serial communications on USB I get nothing.  If I move the Leonardo to a Vista machine and just open the serial monitor, it spews all kinds of data.
Logged
italy
Offline Offline
Full Member
Muuuuu
View Profile
I have windows 7 and it soed not work, but I have tested it on an Xp computer with the same result
Logged
Pages: [1]   Go Up
Print
Jump to:
