Offline
God Member
« on: August 21, 2012, 12:21:17 pm » |
hi all my router is running linux and it is missing of any usb port ='( fortunately i've got 3 miniPCI slots in where usually people put a wifi card (usually atheros-wifi card, which is the suggested and well tested one)
it would be nice if i could put a miniPCI-usb in order to add one or the usb port to my router =D
i have an other technical request about this miniPCI card: it MUST be pci-mem-only because my router is not able to handle any pci-IO card
i live in italy any idea about where i could buy such a strange toy ?
regards =)
« Last Edit: August 21, 2012, 12:24:49 pm by legacy »
Logged
Dallas, Texas
Offline
God Member
Old, decrepit curmugeon
« Reply #1 on: August 21, 2012, 01:44:44 pm » |
Logged
Offline
God Member
« Reply #2 on: August 21, 2012, 01:50:58 pm » |
ops, thanks but they are PCI Express, i have no PCI Express slot in my router, only miniPCI =P
Logged
Offline
God Member
« Reply #3 on: August 21, 2012, 01:51:27 pm » |
(eheehehe it's not so easy job, i think =P)
Logged
Dallas, Texas
Offline
God Member
« Reply #4 on: August 21, 2012, 02:04:21 pm » |
Logged
Offline
God Member
« Reply #5 on: August 21, 2012, 02:16:07 pm » |
interesting, thanks =D
Logged
Offline
God Member
« Reply #6 on: August 22, 2012, 03:15:55 am » |
also i have found this one http://www.abigo4u.com/tf-per-c20u-a10-mini-pci-usb-2-0-module.html?___store=en&___from_store=defaultit's cheap, only 60 euro shipping included the mounted chip is NEC μD720101 unfortunately i can't find the datasheet to check if it is pci-mem-ony (no pci-IO) compliant but i know that a similar chip, NEC uPD720200, is pci-mem-only well, i wander if i should give it a try crossing my fingers =P
Logged
Offline
God Member
« Reply #7 on: August 23, 2012, 05:40:54 am » |
Ok, it seems that it doesn't matter which chip you have mounted pci-mem vs pc-io is depending on how the chip is programmed Dear Sir, Thank you for contacting us. Our PER-C20U is PCI IO space based. If you want to use it with MEN space, we have to modify that.
Logged
Offline
Newbie
« Reply #8 on: October 24, 2012, 08:49:48 am » |
Hi, I got myself into similar sotuation. Did you manage to get USB port as minipci sollution on a non-io slot? I have ubiquity device that I need to extend.
Logged
Offline
Sr. Member
« Reply #9 on: October 24, 2012, 03:02:49 pm » |
just one usb port ? what about using an usb hub ? have you evaluated penalties to the usb bandwidth ?
Logged
Offline
Newbie
« Reply #10 on: October 25, 2012, 01:16:46 am » |
I want to use usb lcd 2x40 screen. The screen will be inside the case. I have spare minipci slot that is not pci-IO compliant. USB hub is not realy an option, since I cannot place it inside the case.
Logged
Offline
Sr. Member
« Reply #11 on: October 25, 2012, 09:29:11 am » |
it seems impossible to find out a miniPCI board which uses pci-mem instead of pci-io, and your router is not able to work with pci-io personally i have only seen the mem-only used in wifi miniPCI card, but we are talinkg about something made and sold by the same people who sell your router. it seems there are no other miniPCI card on the market, i guess i wonder if somebody has ever seen them and could suggest us something about. dunno.
btw, any free GPIO inside your router ? couldn't use GPIO to bit anging a sort of i2c, or SPI or uart ?
Logged
Offline
Newbie
« Reply #12 on: October 28, 2012, 04:11:37 pm » |
Thank you for the reply. You are correct for the WiFi part - there are plenty of WiFi cards that work with my router, though all of them are based on Atheros chipset. There are 7 gpios available, but I don't even know where to start in order to use them.
Logged
Offline
Sr. Member
« Reply #13 on: November 04, 2012, 08:34:00 am » |
is your kernel able to put on/off the GPIO's pins ? if so you could use an SPI to UART.
Logged
Offline
Newbie
« Reply #14 on: November 04, 2012, 02:05:45 pm » |
Yes, I can control the GPIO pins. Can you point me to a place where I can educate myself about SPI to UART? Though, this is GPIO, not UART?
Logged
