Topic: sketch stays on Ethernet.begin when no ethernet connection (Read 699 times) previous topic - next topic
ScottG
I was trying out this Time NTP sketch: (http://arduino.cc/en/Tutorial/UdpNtpClient?action=sourceblock&num=1).   If the ethernet cable is not plugged in, my sketch stays on if (Ethernet.begin(mac) == 0) and never moves on.  I figured this would timeout after a while.
I have Arduino 1.01 with a Leonardo and Ethernet shield R3.
Code: [Select]
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start Ethernet and UDP
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  Udp.begin(localPort);
SurferTim
Mine times out ok on a R2 ethernet shield and a Mega 2560. I disconnected the CAT5 and uploaded the sketch. It takes about a minute to print a fail. I checked with UdpNtpClient and DhcpAddressPrinter sketches.
edit: I removed the memory card from the microSD slot for both tests.
ScottG
I tried it again and it timed out after 62 seconds.  I guess I didn't wait long enough before.
