Topic: Solar Charger Required for Arduino Breadboard Implementation (Read 703 times) previous topic - next topic
Vik009
I am using a bread board implementation of Arduino. I want to charge it via a solar powered batteries. I am looking for a commercial solution in which I have some reserve battery such as 2000 mAH or more and a automatic functionality that whenver solar power is available,it uses that for power and when it is not then it uses that battery to power the system.
Can you please suggest any commerical products available for this. I want to have a compact one solution for this. Dont want to get in to separate solar panels and other stuff.
BR,
Vik
Chagrin
Seeedstudio sells a "LiPo Rider" that might be what you're looking for. Sparkfun sells something similar.
TI's LM1117 datasheet shows how to build a battery backed power supply (page 20) that might meet your needs. That circuit should have something added to prevent overcharging the battery (zener shunt regulator, etc.).
wanderson
LadyAda sells a product that is specifically designed to charge a LiPo battery from a 6V solar panel.  As far as I know it is the only device specifically designed for this purpose using solar as a charge source,
http://www.adafruit.com/products/390
At the very least I suggest looking at her design notes for the product, which address some of the drawbacks to using a traditional lipo charging circuit (including her own) with solar.
New true random number library available at: http://code.google.com/p/avr-hardware-random-number-generation/
Current version 1.0.1
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
