Topic: Great PCB House for Prototyping (Read 20171 times) previous topic - next topic
xl97
no I have not tried to order 200+ board from them..  (all mine have been the 5x5-10pc orders more or less..)
all my shipping has been in the $5.00-$8.00 range.. (not free.. was that advertised? or told to you over the phone?  or your just bringing up/mentioning that seeed does that as a plus for them?..and not really a 'neg' for itead?)
seems like this was a while back (since they didnt even offer these larger batches to be purchased on the store front).. but the two different price thing would have been a turn off for me as well.
I have been wanting to give seeed a chance myself at least once.. but the prices on my small batches of pcb has always been lowest from itead.
CrossRoads
You should try itead again liudr - they have "small batch" pricing  now for 50-300 pieces.
I've ordered 50 pieces a couple of times with no problems.
liuzengqiang
Seeed has free shipping for $50 for as long as I know them. You don't order enough so certainly this has not come up for you at check out. Remember if you do order more than the lowest quantity, just a couple of 10*10 designs will be $50. Shipping a couple hundred boards is around 30-40 at itead but still free at seeed. IDK where your price info came from but they have the same exact price except you pay shippinf with itead even for $50 orders.
@crossroads, I check itead price every time I order from seeed. They are not cheaper for 50-200 pcs. they are the same as seeed and they don't offer free shipping as seeed does. Unless Wendy is just an avertar I know I don't want to talk with Wendy from itead anymore.
jwatte
I use itead for quantity-10 orders, and it's fine, except for when they go on week-long breaks :-) (new years, fall festival, etc...) They do clearly communicate when this will happen, so it's not a surprise, just an inconvenience.
OSH Park is the productization of "Laen's dorkbot order" and I've used that too. Those boards are super nice -- gold finish, deep purple solder mask, 6 mil precision. A little more expensive for the total order of the bigger boards I make, though. Note that I don't need the 10 boards I get from ITEAD -- 3 is plenty per test design for me, but ITEAD is still a cheaper and faster option even when I toss the extra boards I don't need ;-)
When I order from ITEAD, I pay the extra $28 for DHL shipping, and the boards ship in 2-3 days after they're done, so I often have less than 10 days turn-around. Order monday morning, get next tuesday. The ITEAD people will also include devices in the same shipping if I buy them (nRF24L01+ boards etc.) So, $38 for 10x 4sqin boards -- a little more than laen for the order (less per board,) but faster. $50 for 10x 8sqin boards is cheaper, and the bigger the boards get, the better the price gets. Although if laen could deliver within 10 days, that might still be a nice option. (Last I ordered there, I had a 3 week wait before I got the boards, and I'm an impatient man...)
liuzengqiang
Thanks for the info. If I have impatient clients, I will ask them to pay the extra shipping to get the boards faster.
Texy
#20
Nov 05, 2012, 01:26 pm Last Edit: Nov 05, 2012, 02:08 pm by Texy Reason: 1
I,ve used itead a number of times now since Crossroads introduced them to me a year or so ago. I,ve not had them deliver to the UK in under 3 weeks, but thats my choice - the price and quality are good for me.
However I have a design where I need 25mm x 50mm. I already ordered the same design and doubled them up on a 50 x 50mm pcb, but I,m struggling to cut them in half with the tools (or lack of) I have at home - 1.6mm is surprisingly thick when you try and cut it! So if I ordered from itead a 25mm x 50mm design, but under the 50mm x 50mm ordering code, would I received just 10 pcb's and effectively waste half the order, or would they supply twice as much, ie 20 pcbs?
Thanks,
Texy
liuzengqiang
Thanks,
Texy
Yes to itead or seeed. They don't charge per area but charge per predefined area. It is wasting money and material but that is the only way they can offer low price. If you make more than 100 boards, you should email them to see if they are open to negotiate price down. Everyone fits within a predefind box so they can easily and quickly fill up a large board for printing. Hope if you do come to negotiating, your experince is better than mine.
skootles
No, you would get 10 PCBs. If you want to get 20, you would either double-up or add another 10 PCBs to your order. If you want to cut them, invest in a scroll saw or a dremel. I just cut some of mine this past weekend and had no problem with the scroll saw.
CrossRoads
Visit your local hardware store and pick up a hacksaw, works great for cutting in half also.
They might inquire with you about the duplicate design on the board, but as along as you're not adding a row of holes or similar down the middle they'll likely make it for you.
jwatte
Yes, you would "waste" that area.
A hacksaw actually cuts PCBs just fine, if you cut along the flat area. If you try to cut on the edge, it doesn't work very well.
Just put the PCB on a corner of a workbench, lay the hacksaw flat across the line you want to cut, and saw; takes only a minute!
Texy
Thanks guys. I will give that a go ;-)
Texy
liuzengqiang
The fiber dust from rapidly rotating tools is bad to your lungs. Hack saw is probably safer.
xl97
#27
Feb 28, 2013, 01:51 pm Last Edit: Feb 28, 2013, 08:36 pm by xl97 Reason: 1
update for me:
iTeadStudio = F
(I am completely, 100%,  PISSED OFF right now too!)
my last order had some problems with them.. (shipping slow.. but not even emailing me telling me anything, accepted?  completed?  shipped?.... apologized..moved on)..
now I have placed another order.. (over chinese new year)..  so I new it wouldnt start until 17th of Feb....
Since then.. I ordered, paid.. and there is no entry/order history in my account on the website..?? (no order history)
although they have taken the money from PayPal account?
No emails...
I emailed asking about the order? why not showing up? status?..etc.. got 1 reply saying  (quoted)  "Sorry about this condition. We've checked with the transation ID and it's received. And we've fabricated all the files. Sorry for the long delay and we will ship your order today or tomorrow."
I have emailed using their contact forms, help forms, on-line emails.. and Sunny, John & Wendy directly..
all emails have gone without any responses......(zero)
NO emails to say designs were accepted, designs were done..   designs were shipped.. and no tracking number!!
To top it all off.. I paid for the fast $29.00 FEDEX shipping too!.. but since the order was lost, not done in time and no communication was given.. that was a complete waste too!
Just an FYI people.. iTeadStudio custom server/quality has left the building!
I hate feeling 'burned' liek this.. (espeically when I have posted good reviews about them in the past, and have sent many customers/friends there to get pcbs done too)
well all thats stops now.. no more support form me until they can fix this:
I suggest using:
SeeedStudio -
(very similar to iTeadStudio)
http://www.seeedstudio.com/depot/fusion-pcb-service-p-835.html
Sitopway (Technology Limited) -
(new, but has bigger pcb size for their smallest package/cost compared to the two above)
http://www.sitopway.com/en/index.php
again iTeadStudio = terrible service lately!!
(seems like every since iMall took over.. things have been crap)
Wendy, Sunny, John & Sales @iteadstudio.com  can all be fired as far as Im concerned...
Not one of them can or have done their job.
Completely, un-professional...
go somewhere else, that will actually email you back or delivery your product to you.
iteadStudio (as of now) = thieves & liars..
Leon Heller
People seem to have more problems with Seeed. I've been very happy with ITead, I've used them three times and haven't had any problems.
Leon Heller
G1HSM
xl97
I havent had any problems with iTead in the past either.. except for minor communication problem last order (their fault).. and now this order which is a HUGE problem..(again their fault)
Usually Im ok with problems as long as communication is great...  (shit happens ya know) ;)
but this is terrible, complete lack of customer service!...
no email saying the boards were accepted?
no email saying they were done?
no email for the shipping/tracking number?
No entry fr it in my order history on THEIR website?
I had initial contact the first day or two things went wrong...
getting ANY reply after that to see if things have been fixed?  a status update?  anything...   has resulted in ZERO response.
