Loading...
Pages: [1] 2   Go Down
Author Topic: sd with serial communication, how do?  (Read 857 times)
piacenza
Offline Offline
Sr. Member
prima della pazzia c'è la passione
View Profile
hi
I have find this (bottom) Sd card reader but it work with serial communication, I try it but don't work, someone can help me
regards
stefano
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Not likely. You haven't posted any code. You haven't described how that reader is connected. You haven't said what expect the code you have to do, or what it actually does. You haven't described what is on the card, and whether you are trying to read from it or write to it.
There is so much missing from your post that it is impossible to help you.
Logged
piacenza
Offline Offline
Sr. Member
View Profile
ok
in the arduino's playground/storage I read SD reader examples with spi communication only and library about this, with serial communication can I use the statements's file (bottom)
thanks
stefano
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I'm not sure that I understand the question. You won't be able to use the SD library to communicate with your reader, since the SD library expects to use SPI to talk to the SD reader, and yours will not respond to SPI pin wiggling.
There are commands in the pdf file that you linked that let you communicate with the device. Presuming that the device is connected to the same pins that the Serial instance is talking to.
Logged
piacenza
Offline Offline
Sr. Member
View Profile
hi
this SD work with RX TX not SPI, then I am not sure I can use statements's file (bottom)
thanks
stefano
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Quote
Quote
What 'statements's file (bottom)'? What does that mean?
Logged
piacenza
Offline Offline
Sr. Member
View Profile
hi
this is the sketch and file attachments
Code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);
  Serial.println("Goodnight moon!");
   mySerial.println("mode /m \r\n");
    if (mySerial.available())
    Serial.println((char)mySerial.read());
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
void loop() // run over and over
 mySerial.println("init \r\n");
  mySerial.println("fcreate test.txt \r\n");
thanks
stefano
« Last Edit: August 23, 2012, 01:08:53 pm by stefa24 » Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
You start by trying read and write to/from mySerial before the mySerial.begin().
Code:
Then you repeatedly initialise the card and open a new zero byte file.
Code:
I'll assume you have the card reader connected correctly to pins 2 and 3, and that the 5v and ground connections are correct. What are you getting back, if anything, in the serial monitor?
You do have the card formatted as fat16?
Logged
piacenza
Offline Offline
Sr. Member
View Profile
Code:
ops
Code:
yes card reader connected correctly this is the new sketch
Code:
  Serial.begin(9600);  // set the data rate for the Serial port
    mySerial.begin(9600);  // set the data rate for the SoftwareSerial port
  delay(50);
   delay(50);
    Serial.println(mySerial.read());
 mySerial.println("init\r\n");
 delay(50);
 while(mySerial.available())
  mySerial.println("fcreate test3.txt\r\n");
  delay(50);
  while(true){}
test3.txt is created and this is the output
Code:
Goodnight moon!
53
189
145
149
233
129
106
26
170
133
52
171
11
139
171
11
82
171
107
215
87
214
86
86
82
72
248
49
69
50
48
have you any idea?
thanks
stefano
Logged
Leeds, UK
Offline Offline
Newbie
View Profile
Code:
  delay(50);
With this code you are sending "fcreate test3.txt" for every character recieved over mySerial. Is this really what you want to do?
Code:
You then exit the first loop when mySerial.available() returns false and enter try and enter the second loop above expecting mySerial.available() to return something different.
Can you explain what you are tyring to achieve, then maybe someone will be able to give you more helpful advice?
Logged
piacenza
Offline Offline
Sr. Member
View Profile
hi
I want read end write a SD card with serial communication, arduino use SPI only, see file attachment
this is the sketch
Code:
SoftwareSerial mySerial(5,4);// pin 5 RX pin 4 TX
#include <String.h>
  delay(50);
mySerial.print("baud 9600 \r\n");
   delay(50);
   mySerial.println("mode /m");
   delay(50);
    while (mySerial.available())
   mySerial.println("init");
 delay(50);
  mySerial.print("fcreate test.txt\r\n");
  delay(50);
  while(true){}
Code:
Goodnight moon!
62
77
111
100
101
58
32
77
67
85
40
115
105
109
112
108
101
32
109
101
115
115
97
103
101
41
13
10
79
79
test.txt file is created but the output not match output datasheet
stefano
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
If you convert the ascii output to characters, it looks quite reasonable:
Code:
62 >
 77 M
111 o
100 d
101 e
 58 :
 32 <space>
 77 M
 67 C
 85 U
 40 (
115 s
105 i
109 m
112 p
108 l
101 e
 32 <space>
109 m
101 e
115 s
115 s
 97 a
103 g
101 e
 41 )
 13 <carriage return>
 10 <line feed>
 79 O
 79 O
Quote
Not sure what you mean by that.
Logged
piacenza
Offline Offline
Sr. Member
View Profile
hi
from datasheet
Code:
mode /m
>Mode: MCU(simple message)init
my output is
Code:
Goodnight moon!
OO
init output is missing?
stefano
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
A capital O indicates that a command was successful. A return of 'O' from your init and fcreate calls seems ok.
Logged
piacenza
Offline Offline
Sr. Member
View Profile
hi
Code:
ok knew
Code:
SoftwareSerial sdSerial(5,4);// pin 5 RX pin 4 TX
#include <String.h>
char incoming_char=0;
int dato;
String datostringa,scrivistringa;
    sdSerial.begin(9600);  // set the data rate for the SoftwareSerial port
  delay(50);//pausa
  Serial.println("SD start operation");
  Serial.println("mode");  //set mode
   sdSerial.print("mode /m \r\n");
   delay(100);
    while (sdSerial.available())  //check response
    Serial.print(char(sdSerial.read()));    //print response
  Serial.println();  //empty line
  Serial.println("init");  //set init
   sdSerial.print("init \r\n");
   delay(100);
  while(sdSerial.available())  //check response
 Serial.println("create file");
 sdSerial.print("fcreate test.txt\r\n");
 delay(100);
 Serial.println("write file first time");
sdSerial.print("fputs test.txt /w temp \r\n");
  delay(100);
    delay(50);
  for(dato=1;dato<=10;dato++)
   datostring=String(dato);
 sdSerial.print("fputs test.txt /a "+datostring+" \r\n");
 delay(100);
    delay(50);
 Serial.println("end write");
 while(true){}
now it work, then I can to continue with my datalogger
tanks dxw00d
stefano
Logged
Pages: [1] 2   Go Up
Print
Jump to:
