Topic: Switching an Output to opposite to last status (Read 914 times) previous topic - next topic
fiddler
I use the onboard LED on pin 13 as a simple visual monitor, to see that, 1; the program is running and 2; how fast the it get around the loop.
So I have a function like this:
void  HeartBeat(void)
  if (HeartBeatState>0)  {
    digitalWrite(13,HIGH);
    HeartBeatState= 0;
  else{
    digitalWrite(13,LOW);
    HeartBeatState= 1;
  return;
Is there a way to use XOR on the output ?
I guess my question really is: What is the fastest way of switching an output pin ?
Cheers
K
eried
    HeartBeatState= 0;
  else{
    HeartBeatState= 1;
  return;
Cheers
K
I remember time ago someone asking for a DigitalWrite(TOGGLE); but I think it was never added. You can however use something like this:
boolean s;
void HeartBeat()
   digitalWrite(13,s=!s);
My website: http://ried.cl
Grumpy_Mike
You can read outputs, so you could do.
digitalWrite(13, !digitalRead(13) );
Udo Klein
Or you could have the hardware invert the pin by writing a 1 into the PIN instead of the PORT register.
fiddler
PeterH
How fast is fast enough? I find it hard to believe you're actually going to notice the LED switching frequency if you're calling this code frequently enough for performance to be an issue.
I only provide help via the forum - please do not contact me for private consultancy.
