Loading...
Pages: 1 2 [3]   Go Down
Author Topic: SOLVED: Seeedstudio BT Shield  (Read 8382 times)
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
If anyone knows a better way to trap the numbers and A-F only; please let me know.
Code:
    if ((recvChar >= '0' && recvChar <= '9') || (recvChar >= 'A' && recvChar <= 'F"))  // no comment needed
Logged
Georgia, US
Offline Offline
Jr. Member
View Profile
That's not really a better way; just a little more verbose.
Maybe I'll just write a hex trapping function.
Logged
Texas
Offline Offline
Newbie
View Profile
I sent an email to the Arduino Commander people. Got the email from Google Play. They said that UNO R3 does not yet work for the Arduino Commander :/ They have to get the board and work the bugs out smiley-sad
Logged
Georgia, US
Offline Offline
Jr. Member
View Profile
Hopefully there's not that many bugs in there. I haven't been able to get any of the "Google Play" Bluetooth SPP apps to work.
Only what I've listed above about the Arduino being able to detect other Bluetooth devices. But I'm still working on it.
Logged
Offline Offline
Newbie
View Profile
I have similar problem using the bluetooth shield, some phone are not able to see the Arduino while other can...
The code to initialize the BT connection it's just the same as you are using and I keep the baud rate to 38400...
This is an example with video that explain how it works using a Samsung 9003, while if I try to search Arduino and the related BT shiel using a Samsung Next I cannot find the device:-(
This is the link showing how it works on Samsung 9003, what is wrong? Any suggestion?
http://eco-mobilita.blogspot.it/2012/05/interface-between-arduino-and-android.html
This is the BT setup source I use
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  blueToothSerial.print("\r\n+STNA=E-Scooter\r\n"); //set the bluetooth name as "SeeedBTSlave"
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  blueToothSerial.flush();
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Also I've the same problem, My phone is samsung galaxy ace with android 2.3.3
Logged
Offline Offline
Newbie
View Profile
I am having the exact same problem. Using GS3 to connect to UNO R3 with Seeeduino Bluetooth shield. I tried the code listed at the begining of this thread and I was able to pair with the device but it will not connect in ArduinoCommander. Please keep us posted as to what you hear back from the ArduinoCommander people. Thanks.
« Last Edit: January 22, 2013, 04:40:30 am by Jake5k » Logged
Offline Offline
Newbie
View Profile
total newb here.
i've tried several sketches for the BT shield and i can get "bluetooth inquirable", but i'm not getting the blinking red/green lights. i only get the standard green blinking light.
i've tried different pin locations and different sketches, but have yet to get the red/green blinking lights.
i'm using an uno r3 with the seeedstudio BT shield. any help would be appreciated as i'm about to go crazy.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
