Topic: Servo on any I/O pin? (Read 655 times) previous topic - next topic
SouthernAtHeart
Can I put a servo on pin 1?  If so, then I should be able to plug a servo in the FTDI plug on the pro mini, on pins 2,3,& 4, which are GND,+5V, and RX.
thanks
(assuming I won't be using Serial)
dxw00d
You can put a servo on pin 1, but you can't use the normal servo library to drive it. You can use the software servo library (http://www.arduino.cc/playground/ComponentLib/servo) instead. There are other limitations to using software servo. It isn't 'set and forget' like the normal timer based library, you have to regularly 'refresh' the servos.
SouthernAtHeart
So what pins can you use the regular servo library with?  I don't see this info on the Servo Page.
http://arduino.cc/en/Reference/Servo
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
