Loading...
Pages: [1]   Go Down
Author Topic: Ayuda con código  (Read 371 times)
Offline Offline
Newbie
View Profile
Hola Amigos,
Soy nuevo en el foro. Me estoy iniciando el mundo arduino siguiendo el libro 'Beninning Arduino' y me acabo de encontrar un código que no entiendo (aún con las explicaciones del autor). Es el proyeto número 8: RGB Mood Lamp:
float RGB1[3];
float RGB2[3];
float INC[3];
int red, green, blue;
int RedPin=11;
int GreenPin=10;
int BluePin=9;
randomSeed(analogRead(0));
      RGB1[0]=0;
      RGB1[1]=0;
      RGB1[2]=0;
      RGB2[0]=random(256);
      RGB2[1]=random(256);
      RGB2[2]=random(256);
    for(int x=0; x<3; x++)
        INC
  • =(RGB1
  • -RGB2
  • )/256;
    for(int x=0; x=256; x++);
    red = int(RGB1[0];
    green = int(RGB1[1];
    blue =i nt(RGB1[2];
    analogWrite(RedPin, red);
    analogWrite(GreenPin,green);
    analogWrite(BluePin,blue);
    delay(100);
    RGB1[0]  -= INC[0];
    RGB1[1]  -= INC[1];
    RGB1[2]  -= INC[2];
    for (int x=0; x<3; x++)
    RGB2
  • = random(556)-300;
    RGB2
  • = constrain(RGB2
  • , 0, 255);
Los comentarios del autor son los siguientes:
'In the main programo loop, you first take a look at the start and end RGB values and work out what value is needed as an increment to progress from one value to the other in 256 steps (as PWM value can only be between 0 and 255). You do this with the following:
        INC
  • =(RGB1
  • -RGB2
  • )/256;
This 'for' loop sets the INCrements values for the R, G and B channels by working out the difference between the two brightness values and dividing that by 256.
You have another 'for' loop
    red = int(RGB1[0];
    blue =i nt(RGB1[2];
    delay(100);
    RGB1[0]  -= INC[0];
    RGB1[1]  -= INC[1];
    RGB1[2]  -= INC[2];
that sets the red, green, and blue values to the values in the RGB1 array; writes those values to Digital Pins 9, 10 and 11; deducts the increment values; and repeats this process 256 times to slowly fade from one random color to the next step. The delay of 100 ms in between each step ensures a slow and steady progression.
After you have taken 256 slow steps from one random color to the next, the RGB1 array will have the same values(nearly) as the RGB2 array. You now need to decide upon another set of three random values ready for the next time. You do this with another 'for' loop:
    RGB2
    RGB2
  • = constrain(RGB2
  • , 0, 255);
The random number is chosen by picking a random number between 0 and 556 (256+300) and then deducting 300. In this manner, you are trying to force primary colors from time to time to ensure that you won't always just get pastel shades. You have 300 chances out of 556 in getting a negative number and therefore forcing a bias towards one or more of the other two color channels.
The next command makes sure that the numbers sent to the PWM pins are not negative by using the 'constrain()' function.
As you use random(556)-300 for you RGB values, some of those values will be lower than zero; the constrain function makes sure that the values sent to the PWM is not lower than zero.'
Espero puedan ayudarme. Tengo varias dudas de como funciona el programa:
1) En el programa aparecen tres 'for'. Entiendo que el segundo 'for' no se inicia hasta que se completa el primero, no? Y lo mismo debe ocurrir con el tercer, verdad?
2) ¿Cúal es el objetivo de la ecuación 'INC
  • ? ¿Que valores devuelve la primera vez que se incia el programa? Negativos?
3) ¿Qué se consigue con el segundo for? por ejemplo que devuelve red=int(RGB1[0]) en un rango de x=0; x<256 si en void setup() se define que RGB1[0]=0;
Bueno demasiadas dudas,
Siento no concretar mucho más de cuales son mis dudas reales pero no veo como trabaja el código,
Espero puedan orientarme y darme algún consejo de como puedo ir aprendiendo el lenguaje de programación arduino
Muchas gracias,
Un saludo
Logged
Euskadi
Offline Offline
God Member
Arduinotarrak
View Profile
        INC
=(RGB1
-RGB2
)/256;
Hola,
deberías poner el código correctamente escrito, porque esta parte no se entiende.
Logged
Offline Offline
Newbie
View Profile
Hola, tienes razón no me di cuenta. A ver ahora:
Code:
float RGB1[3];
float RGB2[3];
float INC[3];
int red,green, blue;
int RedPin = 11;
int GreenPin = 10;
int BluePin = 9;
  RGB1[0];
  RGB1[1];
  RGB1[2];
  RGB2[0] = random(256);
  RGB2[1] = random(256);
  RGB2[2] = random(256);
  INC[x]=(RGB1[x] - RGB2[x])/256;
for (int x=0; x<256; x++)
  red= int(RGB1[0]);
  green= int(RGB1[1]);
  blue= int(RGB1[2]);
  analogWrite (RedPin,red);
  analogWrite (GreenPin,green);
  analogWrite (BluePin,blue);
  delay(100);
  RGB1[0] -= INC[0];
  RGB1[1] -= INC[1];
  RGB1[2] -= INC[2];
for(int x=0; x<3; x++);
  RGB2[x] = random(556)-300;
  RGB2[x] = constrain(RGB2[x],0,255);
Un saludo y gracias
Logged
Euskadi
Offline Offline
God Member
Arduinotarrak
View Profile
Hola,
En el setup() todavía esto no está completo:
  RGB1[0];
  RGB1[1];
  RGB1[2];
Los valores de RGB1 se cambian aquí:
  RGB1[0] -= INC[0];
  RGB1[1] -= INC[1];
  RGB1[2] -= INC[2];
donde
  RGB1[0] -= INC[0]
equivale a
  RGB1[0] = RGB1[0] - INC[0]
Logged
Offline Offline
Newbie
View Profile
Gracias Curro92, crees que lo que ocurre en el código es lo siguiente?: (lo expresaré solo con el led rojo para no extenderme mucho)
La primera vez que se inicia el código se sabe que:
RGB1 = 0
RGB2 = random(256) que por ejemplo un valor aleatorio de 140
Por tanto con el primer 'for' se obtiene la ecuación:
INC = (0 - 140)/256 = -0.547
Se inicia el segundo 'for':
El primer valor que se va a recibir en el Pin digital 11 será cero (porque en el setup se dice que RGB1 = 0) y por tanto no se iluminaría el led.
Entonces, como me indicabas antes el nuevo valor para RGB1 sería:
RGB1 = RGB1 - INC = 0 - (-0.547) = 0.547
El segundo valor que se va a recibir en el Pin digital 11 sería 0.547 con lo que el led daría un pequeño brillo.
El nuevo valor que tomará RGB1 será:
RGB1  = RGB1 - INC = 0.547 - (-0.547) = 1.094
Este proceso se va a repetir 256 veces y obtendremos un aumento de brillo difuminado del led, no?
analogWrite (RedPin, 0)            // cuando x=0
analogWrite (RedPin, 0.547)      // cuando x=1
analogWrite (RedPin, 1.094)      // cuando x=2
analogWrite (RedPin, 140)         // cuando x=140
Después de los 256 ciclos el valor de RGB1 es igual al de RGB2 (140)
Con el tercer 'for' se pretende buscar un nuevo valor aleatorio para RGB2
Crees que son estos los pasos que va siguiendo el código?
Un poco complejo todo!!!
Gracias y un saludo
Logged
Pages: [1]   Go Up
Print
Jump to:
