Topic: SmartStrip - Yet another web GUI for relay control (Read 4267 times) previous topic - next topic
SukkoPera
Maybe it's a bit early to announce this, but I need help, comments, suggestions, beta testers, whatever :smiley-sweat::
Quote
SmartStrip is a sketch for Arduino meant to allow advanced control of relays through a web interface. SmartStrip currently supports always ON/always OFF and temperature-controlled relays, i.e.: a relay can be configured to turn on when the temperature goes above/below a given threshold (with a given hysteresis margin). The temperature is measured through a DS18B20 sensor connected to any pin of the Arduino.
https://github.com/SukkoPera/SmartStrip
Probably the most important feature is that SmartStrip is compatible with both the official Ethernet Shield and ENC28J60-based shields, which makes it able to run almost everywhere. To achieve this goal, SmartStrip uses a library I wrote that I'm announcing as well:
Quote
Sukkino is a collection of libraries for the Arduino platform. I originally wrote them for my own projects but I think many arduinists can take advantage from them. It contains a universael webserver capable of delivering dynamic contents, a method for writing runtime assertions and one for reading/writing arbitrary objects from/to EEPROM.
https://github.com/SukkoPera/Sukkino
So here we go. I'm very open to suggestions, collaboration, questions, so just reply with your ideas :).
Make your Sega MegaDrive/Genesis region-free with Arduino! https://goo.gl/X7zBcq
Guida rapida a ESP8266: https://goo.gl/kzh62E
terryking228
Hi, this looks very interesting!
I'd like to try to get this running with a standard Ethernet shield and widely-available low-cost relay boards.
Also, you may want to consider the start-up / reset issue to assure no relays can momentarily click on. Some info here: http://arduino-info.wikispaces.com/ArduinoPower#4-8
I'd want to use optically-isolated relay boards like these, which have 2,4 and 8 relay versions: http://goo.gl/xeV7l
DISCLAIMER: Mentioned stuff from my own shop...  (which is what I know best  :)  )
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
SukkoPera
You can surely do that! One of my test setups is Mega 2560 + W5100 Ethernet Shield (Made in China, but identical to the official one) + 2 boards similar to the $6,50 you have in stock, but without OptoCouplers + DS18B20 mounted on a protoboard. It works like a charm!
If you use pins 8, 7, 6 and 5 for the relays and pin 2 for the DS18B20 data line, it will most likely work out of the box!
freedomotic
Hi very interesting project!
It could be controlled by a SCADA/domotic software to work together other devices.
We have created plugins for ipx800 boards or progetti-hwsw boards. So with a single software you can control different technologies.
I think your system is similar to these devices.
More info at:
http://freedomotic.com/content/plugins/ipx800
http://freedomotic.com/forum/tcp-progetti-hw-sw-board-plugin
Regards
Freedomotic Open IoT Framework
http://www.freedomotic.com
We need your help. Please contact us for contributing
