Author Topic: SmartStrip - Yet another web GUI for relay control  (Read 1546 times)
Piemonte, Italia
Just a brick in the wall
Maybe it's a bit early to announce this, but I need help, comments, suggestions, beta testers, whatever smiley-sweat:
SmartStrip is a sketch for Arduino meant to allow advanced control of relays through a web interface. SmartStrip currently supports always ON/always OFF and temperature-controlled relays, i.e.: a relay can be configured to turn on when the temperature goes above/below a given threshold (with a given hysteresis margin). The temperature is measured through a DS18B20 sensor connected to any pin of the Arduino.
https://github.com/SukkoPera/SmartStrip
Probably the most important feature is that SmartStrip is compatible with both the official Ethernet Shield and ENC28J60-based shields, which makes it able to run almost everywhere. To achieve this goal, SmartStrip uses a library I wrote that I'm announcing as well:
Sukkino is a collection of libraries for the Arduino platform. I originally wrote them for my own projects but I think many arduinists can take advantage from them. It contains a universael webserver capable of delivering dynamic contents, a method for writing runtime assertions and one for reading/writing arbitrary objects from/to EEPROM.
https://github.com/SukkoPera/Sukkino
So here we go. I'm very open to suggestions, collaboration, questions, so just reply with your ideas smiley.
Topsham, Vermont USA
... in The Woods In Vermont
Hi, this looks very interesting!
I'd like to try to get this running with a standard Ethernet shield and widely-available low-cost relay boards.
Also, you may want to consider the start-up / reset issue to assure no relays can momentarily click on. Some info here: http://arduino-info.wikispaces.com/ArduinoPower#4-8
I'd want to use optically-isolated relay boards like these, which have 2,4 and 8 relay versions: http://goo.gl/xeV7l
DISCLAIMER: Mentioned stuff from my own shop...  (which is what I know best  smiley  )
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Piemonte, Italia
You can surely do that! One of my test setups is Mega 2560 + W5100 Ethernet Shield (Made in China, but identical to the official one) + 2 boards similar to the $6,50 you have in stock, but without OptoCouplers + DS18B20 mounted on a protoboard. It works like a charm!
If you use pins 8, 7, 6 and 5 for the relays and pin 2 for the DS18B20 data line, it will most likely work out of the box!
Hi very interesting project!
It could be controlled by a SCADA/domotic software to work together other devices.
We have created plugins for ipx800 boards or progetti-hwsw boards. So with a single software you can control different technologies.
I think your system is similar to these devices.
More info at:
http://freedomotic.com/content/plugins/ipx800
http://freedomotic.com/forum/tcp-progetti-hw-sw-board-plugin
Regards
Freedomotic Domotica Open Source
We need your help. Please contact us for contributing
