Topic: Trying to use stand alone FT232RL not working (w/ 328) (Read 3664 times) previous topic - next topic
MatCat
I am trying to use a breakout FT232RL (This one to be exact http://www.gravitech.us/ftusbtouabrb.html), however all I get is programmer not responding, I have rX and TX  hooked up properly, DTR to reset with cap (I don't have a 0.1uf but I have tried various caps), I have tried manually resetting at the right time, and it always comes out saying Programmer not Responding.  I know the chip has a bootloader (blinks 3 times rapidly when reset), and I can put a sketch to it easily with ArduinoISP but I just cannot get it to take a sketch using this breakout board, anyone have any ideas?
johnwasser
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
MatCat
RX of breakout is to TX of chip, and TX to RX, plus I tried them backwards too just to be sure...
baselsw
RX to TX is correct way! How did you connect the power to the chip? Will you please put up a schematic of your connections! The cap capacity does matter but I've tried caps from 470pF to 100nF and they all seem to work. Which caps did you try out?
spcomputing
Why not just put a bootloader of your choosing on with the Arduino as ISP?  Then you know what you have...
CrossRoads
Did you connect the CTS input on the FTDI breakout to Gnd also?
MatCat
No, I haven't seen that mentioned anywhere to do so I will try it.  I tried various caps from 1nf to 1uf, though I picked up some .1's at radioshack today so I will try that on the DTR.
As far as power goes I am just powering up using the USB power (the breakout board has some power conditioning built in)
MatCat
I just tried, still not responding!  I am running out of ideas... maybe the FT232RL eeprom needs to be programmed differently to work with the optiboot?
spcomputing
Quote
I have quite a few FT232RLs (Not the Breakout though) and the only thing to change is the board to Uno.  The breadboard Arduino project uses a FTDI Breakout and the only connections are Vcc/Gnd/Rx/Tx which is all that I use.
MatCat
Pretty much identical to what I have, nothing is working or happening though, using ArduinoISP will upload a sketch without a hitch, optiloader will put a bootloader on it without a hitch, but trying to communicate with it on this FT232RL just will not... I even tried putting a sketch with serial communications to see if i could atleast serial monitor it, but nope.
spcomputing
Does the Tx LED blink three times when the sketch is attempting the upload?  Maybe uninstall and reinstall the FTDI driver?
MatCat
Pin 13 blinks 3 times rapidly (so reset works and bootloader is there), the tx light on the ftdi board blinks a few times but no rx activity.
spcomputing
Try this for my curiosity, upload a sketch and press and hold the reset on the target and watch the Tx LED for two flashes and then immediately release the switch.
MatCat
spcomputing
Try getting the verbose output of the sketch from the IDE and post that.  The only other thing would to try burning the Duemilanove bootloader and see if it will upload then.
