Topic: Trying to use stand alone FT232RL not working (w/ 328) (Read 3491 times) previous topic - next topic
MatCat
Quote
Binary sketch size: 1,316 bytes (of a 32,256 byte maximum)
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/build8484854813470968549.tmp/Fade.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  9 2011 at 16:00:41
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
         User configuration file is "/home/matcat/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
avrdude done.  Thank you.
spcomputing
Hmmm...nothing is coming back from the Atmega at all.  Do you have a way to get the fuse info off the chip.  If not, Nick has a sketch...
http://arduino.cc/forum/index.php/topic,73748.0.html
The only other thing of interest would be getting the actually voltage coming off of the Vcc on the FTDI.
http://www.spcomputing.com
MatCat
I believe the voltage would hold around 4.9, I just realized another component I have came with a USB->TTL (using PL1303 chip), and it works just fine for serial communications, of course the DTR is not exposed on it though.  I really want to get this FT232RL working!  I have emailed gravitech whom I bought it from twice in 2 weeks and no response from them.  I tried uploading a default setting with mprog but it is setup for FT232BM, and not the RL so it will not upload.
spcomputing
Can you get a picture of your setup to share with us?
MatCat
Yes, here is a picture.  I have the USB->TTL hooked up to the TX/RX lines, as well as the FT232RL breakout in the picture, plus UNO is attached to it as an ISP as well.  In testing of course only one of these things are ever hooked up at once :).
spcomputing
Maybe a 100uF electrolytic cap in the power rails and some 0.1uF on the power to the chip?  It could be that the FTDI is not filtered well enough.
Other than that, everything seems in order.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
