Author Topic: Question about servos  (Read 583 times)
I am new to servos and need some help interfacing an arduino to one...
I have a hitec hs-322hd of which I have not been able to find much useful information to program this device online, so bear with me.
I am building a simple animatronic chicken and I want the wings to flap up and down. I have the framework all figured out but need to know how to program the boarduino to cycle the servo from one extreme to the other 5 times.
I hooked up the servo to the boarduino and found that I can cycle it from one end to the other when a button is pressed but when I change from one extreme to the other, the servo only moves a small amount so I set this up in a loop to repeat the write a number of times to get to the other end of the servo travel... Also, I found that the two values that move the servo from one end to the other are 0 and 180...
Here is my code...
#include <Servo.h>
#include <Wire.h>
#include <string.h>
#include <stdio.h>
#define Button   13       // action button is connected to d13
Servo servo1; Servo servo2;
  pinMode(1,OUTPUT);
  servo1.attach(14); //analog pin 0
  servo1.setMaximumPulse(2000);
  servo1.setMinimumPulse(700);
  servo2.attach(15); //analog pin 1
  pinMode(Button, INPUT);            // sets the digital pin 13 as input
  static int v = 0;
  int j, k;
  int Abtn = 0;           // value read from Adam button
  int run =1;                // value to keep loop running
  int RS=0;               // value read from runstop switch
//      servo1.write(v);
  while (run == 1){
    Abtn = digitalRead(Button);    // get the current status of the button
    if (Abtn == HIGH) {
        for (k = 0; k < 5; k++) {
         if (v == 180)
            v = 0;
            v = 180;
         for (j = 1; j < 13; j++) {
            servo1.write(v);
            delay (80);
           Servo::refresh();
There must be a better way to do this...
how can I improve this?
Thanks
London
Have fun!
You don't say which library you are using but I am guessing it's the software servo library because.
This library needs to have the refresh method called at least every 50 ms and  20ms will give best performance.
Below is some code to give you an idea of how you can cycle the servos. Note that servos take time to move.  Increasing the value of the flapRato variable will increase the time it takes to flap. Reducing this value much below that in the example may try to drive the servo faster than it can move.
#include <Servo.h>
#define Button   12       // action button is connected to d12
 pinMode(Button, INPUT);            // sets the digital pin 12 as input
void flap(int nbrOfTimes, int flapRate){
  // routine cycles the servos back and forth
  while( nbrOfTimes--){
     for(int i=0; i < 180; i+= flapRate){
        servo1.write(i);
        servo2.write(i);
        servo::refresh();
        delay(20);
      for(int i=180; i > 0; i -= flapRate){
        servo1.write(i);
        servo2.write(i);
        servo::refresh();
        delay(20);
   if (digitalRead(Button) == HIGH) {
       flap(5,15); // flap 5 times at a fast rate
BTW, you had the button attached to pin 13 – this pin has an led attached on the standard arduino boards so I changed it to 12.
Good luck!
« Last Edit: February 23, 2009, 08:21:31 am by mem » Logged
thanks mem-
I will give it a try when I get home tonight!
Ok, I got a chance to try this and it will not compile clean due to an error stating that "servo is not declared..."
I am using the same servo.h file as before and it is choking on the "servo::refresh();"  line...
Here is the error that I received:
In function 'void flap(int, int)':
error: 'servo' has not been declared.
I added a few items to the code but other than that it is pretty much as you sent it.
Also, the servo.h file is stored in the folder c:\aduino-0010\hardware\libraries\servo as it was with my original bad code...
Here is the code:
#include <Servo.h>
#include <Wire.h>
#include <string.h>
#include <stdio.h>
#define yada     10      // yadayadayada is connected to d10
Servo servo1;
Servo servo2;
 pinMode(yada, OUTPUT);         // sets the digital pin 10 as output
 digitalWrite(yada, HIGH);      // turns the yadayadayada off
} void flap(int nbrOfTimes, int flapRate){
   servo1.write(i);
   servo2.write(i);
   servo::refresh();
   delay(20);
   servo1.write(i);
   servo2.write(i);
   servo::refresh();
   delay(20);
}void loop() {
      digitalWrite(yada, LOW);      // turns the yadayadayada on
      delay(100);
What am I doing wrong?
thanks!
I'm guessing if you replace all of your "servo::refresh();" with "Servo::refresh();" it will be happy.  If not, I'm sure mem will have the answer.
London
Have fun!
Yes, Digger450 has the fix.
very, very subtle...  Servo::refresh();
Good eye! I didn't even see that  I had is as a small case "s"....
Thanks Digger450 & mem, I appreciate the help!
Netherlands
Can't we get rid of this case-sensitivity in the Arduino language? I have fallen in the same trap some time ago too.
London
Have fun!
Case sensitivity is a fundamental part of the underlying C and C++ language that Arduino is built on. Its worth getting used to and becomes second nature after a while.
Netherlands
I guess you are right. I have developed software in Clipper for ages and this language is not case sensitive.
In VB.Net, case is automatically adjusted. Maybe all IDE's should be able to do that.
