Loading...
Pages: [1] 2 3 ... 8   Go Down
Author Topic: SPI interface with other board_AVR_ESK1100 or among Arduino itself  (Read 4258 times)
Offline Offline
Full Member
View Profile
Hi...!!!
I want to read a data from another board using SPI(MOSI,MISO,SCK and SS) wires.
First I want to read some data as an acknowledgement then I want to send some data.Sending data part code is working fine but reading is happening. Please help me.
Sending data Code:-
Code:
#include <SPI.h>// include the SPI library:
const int spidata = 10;//Pin 11 is data(MOSI) and pin 13 SCK ,set pin 10(SS) as the slave select for the digital pot:
int mm =0;
  pinMode (spidata, OUTPUT);// set the spi_data_pin as an output:
  SPI.begin();// initialize SPI:
  Serial.begin(4800);
     int arry[16] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
      digitalWrite(spidata,LOW);
      Serial.println("If condition-1 Matches then:");
      Serial.println("I am writting on SPI");
      Serial.println(arry[0], BIN);
      SPI.transfer(arry[0]); //  send in the address and value via SPI:
      delay(1500);
      Serial.println("If condition-2 Matches then:");
      Serial.println(arry[1], BIN);
      SPI.transfer(arry[1]);
     delay(1500);
     Serial.println("If condition-3 Matches then:");
      Serial.println(arry[2],BIN);
      SPI.transfer(arry[2]);
      delay(1500);
      Serial.println("If condition-4 Matches then:");
      Serial.println(arry[3], BIN);
      SPI.transfer(arry[3]);
     delay(1500);
     Serial.println("If condition-5 Matches then:");
      Serial.println(arry[4], BIN);
      SPI.transfer(arry[4]);
      delay(1500);
      Serial.println("If condition-6 Matches then:");
      Serial.println(arry[5], BIN);
      SPI.transfer(arry[5]);
      delay(1500);
      Serial.println("If condition-7 Matches then:");
      Serial.println(arry[6], BIN);
      SPI.transfer(arry[6]);
      delay(1500);
      Serial.println("If condition-8 Matches then:");
      Serial.println(arry[7], BIN);
      SPI.transfer(arry[7]);
     Serial.println("If condition-9 Matches then:");
      Serial.println(arry[8], BIN);
      SPI.transfer(arry[8]);
      delay(1500);
      Serial.println("If condition-10 Matches then:");
      Serial.println(arry[9], BIN);
      SPI.transfer(arry[9]);
     delay(1500);
     Serial.println("If condition-11 Matches then:");
      Serial.println(arry[10], BIN);
      SPI.transfer(arry[10]);
     delay(1500);
     Serial.println("If condition-12 Matches then:");
      Serial.println(arry[11], BIN);
      SPI.transfer(arry[11]);
      delay(1500);
      Serial.println("If condition-13 Matches then:");
      Serial.println(arry[12], BIN);
      SPI.transfer(arry[12]);
      delay(1500);
      Serial.println("If condition-14 Matches then:");
      Serial.println(arry[13], BIN);
      SPI.transfer(arry[13]);
      delay(1500);
      Serial.println("If condition-15 Matches then:");
      Serial.println(arry[14], BIN);
      SPI.transfer(arry[14]);
      delay(1500);
      Serial.println("ALL THE CONDITIONS are over now::");
      Serial.println("\n");
      digitalWrite(spidata,HIGH);// take the SS pin high to de-select the chip:
      delay(1500);
Recieving data code:-
Code:
// Slave
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
void SlaveInit(void) {
  // Set MISO output, all others input
  pinMode(SCK_PIN, INPUT);
  pinMode(MOSI_PIN, INPUT);
  pinMode(MISO_PIN, OUTPUT);
  pinMode(SS_PIN, INPUT);
  // Enable SPI
  SPCR = B00000000;
  SPCR = (1<<SPE);
byte ReadByte(void) {
  while(!(SPSR & (1<<SPIF))) ;
  return SPDR;
void WriteByte(byte value) {
  SPDR = value;
  while (!(SPSR & (1<<SPIF))) ;
  return;
unsigned long lastSent;
  Serial.begin(57600);
  digitalWrite(5, HIGH);
  SlaveInit();
  lastSent = millis();
  pinMode(5, OUTPUT);
  if (digitalRead(10) == LOW) {
    Serial.println("Pin 10 low...");
    byte rxData;
    rxData = ReadByte();
    Serial.print("Command: ");
    Serial.println(rxData, DEC);
    if (rxData == 17) {
      Serial.println("Sending data to master...");
      WriteByte(19);
      Serial.println("Done Sending data...");
  if (millis() > lastSent + 2000) {
    Serial.println("Pin 5 low...");
    digitalWrite(5, LOW);
    delay(10);
« Last Edit: August 28, 2012, 04:54:33 am by ranjeetray » Logged
Offline Offline
Full Member
View Profile
Hi...!!!
Sending data Code:-
Code:
int mm =0;
  Serial.begin(4800);
      delay(1500);
     delay(1500);
      delay(1500);
     delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
     delay(1500);
     delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
Code:
// Slave
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
  // Enable SPI
  SPCR = B00000000;
  SPCR = (1<<SPE);
  return SPDR;
  SPDR = value;
  return;
  SlaveInit();
  pinMode(5, OUTPUT);
    byte rxData;
    if (rxData == 17) {
      WriteByte(19);
    delay(10);
Dear Sir @Nick Gammon
Please help me out.
Logged
Offline Offline
Full Member
View Profile
Hi...!!!
Sending data Code:-
Code:
int mm =0;
  Serial.begin(4800);
      delay(1500);
     delay(1500);
      delay(1500);
     delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
     delay(1500);
     delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
Code:
// Slave
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
  // Enable SPI
  SPCR = B00000000;
  SPCR = (1<<SPE);
  return SPDR;
  SPDR = value;
  return;
  SlaveInit();
  pinMode(5, OUTPUT);
    byte rxData;
    if (rxData == 17) {
      WriteByte(19);
    delay(10);
Please help me out.
Dear Sir
Even this code is working fine .
Code:
int mm =0;
  Serial.begin(4800);
      for(mm=0; mm<256;mm++){
      Serial.println(mm, BIN);
      SPI.transfer(mm); //  send in the address and value via SPI:
      delay(1500);}
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Then, what IS your problem?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I think your WriteByte routine is failing to complete the process - it reads SPSR but doesn't read SPDR once there's a byte so the hardware never clears ready for the next byte?  To quote the datasheet:
Quote
the SPIF bit is cleared by first reading the SPI Status Register with SPIF set, then accessing the SPI Data Register (SPDR)
  How about rewriting WriteByte thus:
Code:
byte WriteByte (byte value) {
  SPDR = value ;
  return SPDR ;
(So easy to miss a semicolon after a while, use a blank block instead, harder to misread)
Logged
Offline Offline
Full Member
View Profile
Quote
Sir.
I am able to send/write data on the SPI but I am not able to read the data, Please help me out.
I tried following code also
Code:
int mm =0;
//int ReadByte();
  SPI.setDataMode(SPI_MODE3);
  SPI.setClockDivider(SPI_CLOCK_DIV8);
  SPCR = B00000000;
  SPCR = (1<<SPE);
  Serial.begin(4800);
  return SPDR;
// int ReadByte(int value) {
//  SPDR = value;
//  while((!SPSR & (1<<SPIF)))
//  return 0;
//byte WriteByte (byte value) {
//  SPDR = value ;
//  while (!(SPSR & (1<<SPIF)))
//  return SPDR ;
      int rxData;
      rxData = ReadByte();   // Sir, this part is not working, please help me.
      Serial.println("Read value ");
       Serial.println("Newline");
    //if (rxData == 59) {
      Serial.println("If condition-1 Matches and recieves 0x3B from SPI then:");
      Serial.println("I am Sending 1st data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 2nd data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 3rd data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 4th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 5th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 6th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 7th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 8th data of 15 data on SPI");
      Serial.println("I am Sending 9th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 10th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 11th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 12th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 13th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 14th data of 15 data on SPI");
      delay(1500);
      Serial.println("I am Sending 15th data of 15 data on SPI");
      delay(1500);
      Serial.println("ALL 15 datas are sent on SPI, process completed ::");
      delay(1500);
Output of the above code:
Code:
Read value
0
Newline
1
10
11
100
101
110
111
1000
1001
1010
1011
1100
1101
1110
1111
« Last Edit: August 29, 2012, 12:30:26 am by ranjeetray » Logged
Offline Offline
Full Member
View Profile
Quote
Code:
  SPDR = value ;
  return SPDR ;
Sir,
I have tried with your suggestion also but it is not able to read from other board which is just keep on pumping the data and giving 0 as output, I have connected MOSI,MISO,CS,SCK wires across the two Arduino boards.
Tried code.
Code:
int mm =0;
//int ReadByte();
  SPCR = B00000000;
  SPCR = (1<<SPE);
  Serial.begin(4800);
  return SPDR;
//  SPDR = value;
//  return 0;
//  SPDR = value ;
//  return SPDR ;
      int rxData;
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
Output of the above code which reads "0"
[code]
Read value
0
Newline
1
10
11
100
101
110
111
1000
1001
1010
1011
1100
1101
1110
1111
[/code]
Logged
Offline Offline
Full Member
View Profile
Quote
Sir,
Please help me out on this.
Logged
Offline Offline
Full Member
View Profile
Quote
Code:
  SPDR = value ;
  return SPDR ;
Sir,
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
If you are going to ignore the questions, and ignore the suggested corrections, please don't keep re-posting "Please help me out on this".
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Sir,
That is not a meaningful answer to the question "what IS your problem?".
Logged
Offline Offline
Full Member
View Profile
Sir,
I am using two Arduino board, from one board I am able to send the data which is available on oscilloscope.
But when I read from another board, it is not able to read.
Code:
    return SPDR;
      int rxData;
Sir, this read function is returning 0.
Please suggest something.
« Last Edit: August 29, 2012, 02:09:44 am by ranjeetray » Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Logged
Offline Offline
Full Member
View Profile
Dear Sir
I am using two arduino board for SPI communication. I am sending data from one board which is happening and data is available on oscilloscope. But when I try to read from with another board it is reading the data.
Data Sending Code
Code:
int mm =0;
      SPI.transfer(1);
      delay(1500);
Data Recieving code:
Code:
  pinMode (spidata, INPUT);// set the spi_data_pin as an output:
  Serial.begin(9600);}
    return SPDR;
      int rxData;
   delay(1500);
Sir, please help me.
Sorry I had replied him like this only before then again I asked him to help me.
Read value is coming as "0".
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
OK, now re-read reply #4 and explain why you ignored his suggestion.
Logged
Pages: [1] 2 3 ... 8   Go Up
Print
Jump to:
