Loading...
Pages: 1 [2] 3 4 ... 8   Go Down
Author Topic: SPI interface with other board_AVR_ESK1100 or among Arduino itself  (Read 4292 times)
Offline Offline
Full Member
View Profile
OK, now re-read reply #4 and explain why you ignored his suggestion.
Respected Sir
Thanks a lot for your kind reply. I have tried with his suggestion also but still I was getting value 0. Please explain me in depth. I am doing something wrong which I am not able to understand. Kindly guide me.
I had used this code also
Code:
byte WriteByte (byte value) {
  SPDR = value ;
  while (!(SPSR & (1<<SPIF)))
  return SPDR ;
Logged
Offline Offline
Full Member
View Profile
I think your WriteByte routine is failing to complete the process - it reads SPSR but doesn't read SPDR once there's a byte so the hardware never clears ready for the next byte?  To quote the datasheet:
Quote
the SPIF bit is cleared by first reading the SPI Status Register with SPIF set, then accessing the SPI Data Register (SPDR)
  How about rewriting WriteByte thus:
Code:
  SPDR = value ;
  return SPDR ;
(So easy to miss a semicolon after a while, use a blank block instead, harder to misread)
Respected Sir
I have used this code also but getting the same value as 0.
Please explain me how to make SPDR to work.
Code:
  SPDR = value ;
  return SPDR ;
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
 byte ReadByte(void) {
  while(!(SPSR & (1<<SPIF)))
    return SPDR;
Do you see a similar problem here?
MarkT said:
Quote
Logged
Offline Offline
Full Member
View Profile
Code:
    return SPDR;
MarkT said:
Quote
Respected Sir
When I use ; it goes in infinite loop and does not give any output and without ; it gives output as
Output:
Code:
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Read value
0
Sir ,
Is this code correct, please suggest if something is wrong:
Code:
#include <SPI.h>// include the SPI library:
const int spidata = 10;//Pin 11 is data(MOSI) and pin 13 SCK ,set pin 10(SS) as the slave select for the digital pot:
  pinMode (spidata, INPUT);// set the spi_data_pin as an output:
  SPI.setDataMode(SPI_MODE3);
  SPI.setClockDivider(SPI_CLOCK_DIV8);
  SPI.begin();// initialize SPI:
  Serial.begin(9600);}
  while(!(SPSR & (1<<SPIF)));
    return SPDR;
      int rxData;
    digitalWrite(spidata,LOW);
      rxData = ReadByte();
      Serial.println("Read value ");
     Serial.println(rxData, DEC);
    digitalWrite(spidata,HIGH);
   delay(1500);
« Last Edit: August 29, 2012, 02:55:56 am by ranjeetray » Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Will you please explain why you are not using SPI.transfer() ?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
That's a good point - SPI.transfer will work for both master and slave I think (master mode doesn't require the SPDR to be read, but transfer does this anyway).
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
There was an almost exact same problem on this thread
http://arduino.cc/forum/index.php/topic,118712.0.html
Same code even.
I still don't know why it didn't work but using SPI.transfer() fixed it.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Full Member
View Profile
Same code even.
______
Rob
Dear Sir
Thanks a lot for your kind support.
Can you please provide us the both master and slave codes, it will be great help for me.
Thanks & Regards..
Logged
Offline Offline
Full Member
View Profile
Respected Sir
Thanks a lot for your kind support. Now I am able to receive data form master but after receiving I want to send some data to master back, how can we do this. I have used SPI.transfer() in the master/data-sending code.
Working code.
Sending data code:
Code:
int mm =0;
  pinMode (spidata, OUTPUT);// set the spi_data_pin as an output:
      SPI.transfer(0x3b); //  send in the address and value via SPI:
      digitalWrite(spidata,HIGH);// take the SS pin high to de-select the chip:
      delay(1500);
Receiving data code:
Code:
#include <SPI.h>
#include <stdio.h>
#include <avr/io.h>
#include <stdlib.h>
#define MOSI 11
#define MISO  12
#define SCK  13
#define SS 10
int data = 0;
char buff[8];
  pinMode(MOSI, INPUT);
  pinMode(MISO, OUTPUT);
  pinMode(SCK,INPUT);
  pinMode(SS,INPUT);
  SPCR = 0x40;  // Enable SPI in slave mode
//  SPI.begin();
  Serial.println("Data Received from Master Board");
  data = SPI_SlaveReceive();
   Serial.println(data, HEX);
  data = 0;
unsigned char SPI_SlaveReceive()
  return SPDR;
Output from receiving code:
Code:
3B
3B
3B
3B
And now what should I do modification in the code so that I can send some data to master once I receive 0x3B from master.
I am trying like this at receiving(slave) side, it is receiving 0x3B from master but not able to send data to master
Code:
#include <SPI.h>
#include <stdio.h>
#include <avr/io.h>
#include <stdlib.h>
#define MOSI 11
#define MISO  12
#define SCK  13
#define SS 10
#define sss 9
int data = 0;
char buff[8];
  pinMode(SCK,INPUT);
  pinMode(SS,INPUT);
  pinMode(sss, OUTPUT);
//  SPI.begin();
 int xx;
  xx = data;
  data = 0;
  delay(20);
  if(xx == 59)
    delay(600);
    void master_init();
    unsigned char send2();
    delay(600);
  unsigned char send2(){
  digitalWrite(SS, LOW);
  WriteByte(16);
  digitalWrite(SS, HIGH);
  delay(600);}
  return SPDR;
void master_init()
    pinMode(MOSI, OUTPUT);
  pinMode(MISO, INPUT);
  pinMode(SCK,OUTPUT);
  pinMode(SS,OUTPUT);
void WriteByte(byte value) {
  SPDR = value;
  while (!(SPSR & (1<<SPIF))) ;
  return;
And at the master side I am doing like this but it is not able to receive the data
Code:
#define sss 9
int mm =0;
unsigned char data1 = 0;
     //for(mm=0; mm<23;mm++){
      //Serial.println("I am writting on SPI");
      //Serial.println(mm, BIN);
     // SPI.transfer('IMU');
      delay(600);
      //digitalWrite(sss,LOW);
      unsigned char read1();
      delay(600);
      //digitalWrite(sss,HIGH);
        void slave_init();
      data1 = read_ready();
      Serial.println(data1, DEC);
      data1 = 0;
      delay(60);
      unsigned char read_ready()
        return SPDR;
   void slave_init()
     SPCR = 0x40;
    pinMode(11, INPUT);
    pinMode(12, OUTPUT);
    pinMode(13, INPUT);
    pinMode(10, INPUT);
    delay(600);
Kindly suggest me for the modification.
« Last Edit: August 30, 2012, 12:21:30 am by ranjeetray » Logged
Offline Offline
Full Member
View Profile
Dear Sir
Thanks a lot for your kind support. Kindly go through the post  Reply #23 on: Today at 05:15:07 PM and please suggest for the modification on the code.
Thanks and Regards.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Kindly go through the post  Reply #23 ...
Kindly stop ignoring our suggestions.
Logged
Offline Offline
Full Member
View Profile
Dear Sir
Where do you want me to use this SPI.transfer() function in my code, And I am not trying to avoid yours suggestion. Please guide me and help me out.
Thanks & Regards..
Logged
Offline Offline
Full Member
View Profile
Respected Sir,
This code is able to send the data but not able to receive, what is wrong in this;
Code:
//send receive
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
//#define SS_PIN    10
unsigned char receive_data(void);
unsigned char rd = 0;
void SlaveInit(void) {
  // Set MISO output, all others input
  pinMode(SCK_PIN, INPUT);
  pinMode(MOSI_PIN, OUTPUT);
  pinMode(MISO_PIN, INPUT);
  pinMode(spidata, INPUT);
  // Enable SPI
  SPCR = B00101100;
     SPCR = (1<<SPE);
     //SPCR = 0x00;
   pinMode(SCK_PIN, OUTPUT);
  pinMode(MOSI_PIN, INPUT);
  pinMode(MISO_PIN, OUTPUT);
  pinMode(spidata, OUTPUT);
  //pinMode (spidata, OUTPUT);// set the spi_data_pin as an output:
  //SPI.setBitOrder(LSBFIRST);
  //SPCR = 0x90;
void loop() {digitalWrite(spidata,LOW);
            delay(400);
           receive_data();
    unsigned char read_data(void)
    {  //SPCR = 0x60;
      return SPDR; }
    unsigned char receive_data(){
     SlaveInit();
     rd = read_data();
      Serial.println(rd, DEC);
      rd = 0;
      delay(400);
      return 0;
Logged
Offline Offline
Full Member
View Profile
Quote
Even this code is working fine .
Then, what IS your problem?
Respected Sir,
Can we read/transmit here 16 bit data on Arduino board using SPI protocol. Will it generate 16 continuous clock signal.
Logged
Offline Offline
Tesla Member
View Profile
WWW
The Arduino has an 8-bit SPI peripheral and therefore only transmits 8 bits at a time.
However you can just transmit two bytes in a row, the end result is the same.
______
Rob
Logged
Pages: 1 [2] 3 4 ... 8   Go Up
Print
Jump to:
