Topic: SPI interface with other board_AVR_ESK1100 or among Arduino itself (Read 26821 times) previous topic - next topic
ranjeetray
Aug 28, 2012, 11:52 am Last Edit: Aug 28, 2012, 11:54 am by ranjeetray Reason: 1
Hi...!!!
I want to read a data from another board using SPI(MOSI,MISO,SCK and SS) wires.
First I want to read some data as an acknowledgement then I want to send some data.Sending data part code is working fine but reading is happening. Please help me.
Sending data Code:-
#include <SPI.h>// include the SPI library:
const int spidata = 10;//Pin 11 is data(MOSI) and pin 13 SCK ,set pin 10(SS) as the slave select for the digital pot:
int mm =0;
 pinMode (spidata, OUTPUT);// set the spi_data_pin as an output:
 SPI.begin();// initialize SPI:
 Serial.begin(4800);
    int arry[16] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
     digitalWrite(spidata,LOW);
     Serial.println("If condition-1 Matches then:");
     Serial.println("I am writting on SPI");
     Serial.println(arry[0], BIN);
     SPI.transfer(arry[0]); //  send in the address and value via SPI:
     delay(1500);
     Serial.println("If condition-2 Matches then:");
     Serial.println(arry[1], BIN);
     SPI.transfer(arry[1]);
    delay(1500);
    Serial.println("If condition-3 Matches then:");
     Serial.println(arry[2],BIN);
     SPI.transfer(arry[2]);
     delay(1500);
     Serial.println("If condition-4 Matches then:");
     Serial.println(arry[3], BIN);
     SPI.transfer(arry[3]);
    delay(1500);
    Serial.println("If condition-5 Matches then:");
     Serial.println(arry[4], BIN);
     SPI.transfer(arry[4]);
     delay(1500);
     Serial.println("If condition-6 Matches then:");
     Serial.println(arry[5], BIN);
     SPI.transfer(arry[5]);
     delay(1500);
     Serial.println("If condition-7 Matches then:");
     Serial.println(arry[6], BIN);
     SPI.transfer(arry[6]);
     delay(1500);
     Serial.println("If condition-8 Matches then:");
     Serial.println(arry[7], BIN);
     SPI.transfer(arry[7]);
    Serial.println("If condition-9 Matches then:");
     Serial.println(arry[8], BIN);
     SPI.transfer(arry[8]);
     delay(1500);
     Serial.println("If condition-10 Matches then:");
     Serial.println(arry[9], BIN);
     SPI.transfer(arry[9]);
    delay(1500);
    Serial.println("If condition-11 Matches then:");
     Serial.println(arry[10], BIN);
     SPI.transfer(arry[10]);
    delay(1500);
    Serial.println("If condition-12 Matches then:");
     Serial.println(arry[11], BIN);
     SPI.transfer(arry[11]);
     delay(1500);
     Serial.println("If condition-13 Matches then:");
     Serial.println(arry[12], BIN);
     SPI.transfer(arry[12]);
     delay(1500);
     Serial.println("If condition-14 Matches then:");
     Serial.println(arry[13], BIN);
     SPI.transfer(arry[13]);
     delay(1500);
     Serial.println("If condition-15 Matches then:");
     Serial.println(arry[14], BIN);
     SPI.transfer(arry[14]);
     delay(1500);
     Serial.println("ALL THE CONDITIONS are over now::");
     Serial.println("\n");
     digitalWrite(spidata,HIGH);// take the SS pin high to de-select the chip:
     delay(1500);
Recieving data code:-
// Slave
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
void SlaveInit(void) {
 // Set MISO output, all others input
 pinMode(SCK_PIN, INPUT);
 pinMode(MOSI_PIN, INPUT);
 pinMode(MISO_PIN, OUTPUT);
 pinMode(SS_PIN, INPUT);
 // Enable SPI
 SPCR = B00000000;
 SPCR = (1<<SPE);
byte ReadByte(void) {
 while(!(SPSR & (1<<SPIF))) ;
 return SPDR;
void WriteByte(byte value) {
 SPDR = value;
 while (!(SPSR & (1<<SPIF))) ;
 return;
unsigned long lastSent;
 Serial.begin(57600);
 digitalWrite(5, HIGH);
 SlaveInit();
 lastSent = millis();
 pinMode(5, OUTPUT);
 if (digitalRead(10) == LOW) {
   Serial.println("Pin 10 low...");
   byte rxData;
   rxData = ReadByte();
   Serial.print("Command: ");
   Serial.println(rxData, DEC);
   if (rxData == 17) {
     Serial.println("Sending data to master...");
     WriteByte(19);
     Serial.println("Done Sending data...");
 if (millis() > lastSent + 2000) {
   Serial.println("Pin 5 low...");
   digitalWrite(5, LOW);
   delay(10);
ranjeetray
Hi...!!!
Sending data Code:-
int mm =0;
 Serial.begin(4800);
     delay(1500);
    delay(1500);
     delay(1500);
    delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
    delay(1500);
    delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
// Slave
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
 // Enable SPI
 SPCR = B00000000;
 SPCR = (1<<SPE);
 return SPDR;
 SPDR = value;
 return;
 SlaveInit();
 pinMode(5, OUTPUT);
   byte rxData;
   if (rxData == 17) {
     WriteByte(19);
   delay(10);
Dear Sir @Nick Gammon
Please help me out.
ranjeetray
Hi...!!!
Sending data Code:-
int mm =0;
 Serial.begin(4800);
     delay(1500);
    delay(1500);
     delay(1500);
    delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
    delay(1500);
    delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
     delay(1500);
// Slave
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
#define SS_PIN    10
 // Enable SPI
 SPCR = B00000000;
 SPCR = (1<<SPE);
 return SPDR;
 SPDR = value;
 return;
 SlaveInit();
 pinMode(5, OUTPUT);
   byte rxData;
   if (rxData == 17) {
     WriteByte(19);
   delay(10);
Please help me out.
Dear Sir
Even this code is working fine .
int mm =0;
  Serial.begin(4800);
      for(mm=0; mm<256;mm++){
      Serial.println(mm, BIN);
      SPI.transfer(mm); //  send in the address and value via SPI:
      delay(1500);}
PaulS
Then, what IS your problem?
MarkT
I think your WriteByte routine is failing to complete the process - it reads SPSR but doesn't read SPDR once there's a byte so the hardware never clears ready for the next byte?  To quote the datasheet:
the SPIF bit is cleared by first reading the SPI Status Register with SPIF set, then accessing the SPI Data Register (SPDR)
  How about rewriting WriteByte thus:
byte WriteByte (byte value) {
  SPDR = value ;
  return SPDR ;
(So easy to miss a semicolon after a while, use a blank block instead, harder to misread)
ranjeetray
#5
Aug 29, 2012, 07:18 am Last Edit: Aug 29, 2012, 07:30 am by ranjeetray Reason: 1
Sir.
I am able to send/write data on the SPI but I am not able to read the data, Please help me out.
I tried following code also
int mm =0;
//int ReadByte();
 SPI.setDataMode(SPI_MODE3);
 SPI.setClockDivider(SPI_CLOCK_DIV8);
 SPCR = B00000000;
 SPCR = (1<<SPE);
 Serial.begin(4800);
 return SPDR;
// int ReadByte(int value) {
//  SPDR = value;
//  while((!SPSR & (1<<SPIF)))
//  return 0;
//byte WriteByte (byte value) {
//  SPDR = value ;
//  while (!(SPSR & (1<<SPIF)))
//  return SPDR ;
     int rxData;
     rxData = ReadByte();   // Sir, this part is not working, please help me.
     Serial.println("Read value ");
      Serial.println("Newline");
   //if (rxData == 59) {
     Serial.println("If condition-1 Matches and recieves 0x3B from SPI then:");
     Serial.println("I am Sending 1st data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 2nd data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 3rd data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 4th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 5th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 6th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 7th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 8th data of 15 data on SPI");
     Serial.println("I am Sending 9th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 10th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 11th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 12th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 13th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 14th data of 15 data on SPI");
     delay(1500);
     Serial.println("I am Sending 15th data of 15 data on SPI");
     delay(1500);
     Serial.println("ALL 15 datas are sent on SPI, process completed ::");
     delay(1500);
Output of the above code:
Read value
Newline
1
10
11
100
101
110
111
1000
1001
1010
1011
1100
1101
1110
1111
ranjeetray
  SPDR = value ;
  return SPDR ;
Sir,
I have tried with your suggestion also but it is not able to read from other board which is just keep on pumping the data and giving 0 as output, I have connected MOSI,MISO,CS,SCK wires across the two Arduino boards.
Tried code.
int mm =0;
//int ReadByte();
  SPCR = B00000000;
  SPCR = (1<<SPE);
  Serial.begin(4800);
  return SPDR;
//  SPDR = value;
//  return 0;
//  SPDR = value ;
//  return SPDR ;
      int rxData;
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
      delay(1500);
Output of the above code which reads "0"
[code]
Read value
Newline
1
10
11
100
101
110
111
1000
1001
1010
1011
1100
1101
1110
1111
[/code]
ranjeetray
Sir,
Please help me out on this.
ranjeetray
  SPDR = value ;
  return SPDR ;
Sir,
Nick Gammon
If you are going to ignore the questions, and ignore the suggested corrections, please don't keep re-posting "Please help me out on this".
More info:
Nick Gammon
Sir,
That is not a meaningful answer to the question "what IS your problem?".
More info:
ranjeetray
#11
Aug 29, 2012, 09:01 am Last Edit: Aug 29, 2012, 09:09 am by ranjeetray Reason: 1
Sir,
I am using two Arduino board, from one board I am able to send the data which is available on oscilloscope.
But when I read from another board, it is not able to read.
   return SPDR;
     int rxData;
Sir, this read function is returning 0.
Please suggest something.
Nick Gammon
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
More info:
ranjeetray
Dear Sir
I am using two arduino board for SPI communication. I am sending data from one board which is happening and data is available on oscilloscope. But when I try to read from with another board it is reading the data.
Data Sending Code
int mm =0;
     SPI.transfer(1);
     delay(1500);
Data Recieving code:
 pinMode (spidata, INPUT);// set the spi_data_pin as an output:
 Serial.begin(9600);}
   return SPDR;
     int rxData;
  delay(1500);
Sir, please help me.
Sorry I had replied him like this only before then again I asked him to help me.
Read value is coming as "0".
Nick Gammon
OK, now re-read reply #4 and explain why you ignored his suggestion.
More info:
