Topic: SPI interface with other board_AVR_ESK1100 or among Arduino itself (Read 30949 times) previous topic - next topic
ranjeetray
OK, now re-read reply #4 and explain why you ignored his suggestion.
Respected Sir
Thanks a lot for your kind reply. I have tried with his suggestion also but still I was getting value 0. Please explain me in depth. I am doing something wrong which I am not able to understand. Kindly guide me.
I had used this code also
byte WriteByte (byte value) {
  SPDR = value ;
  while (!(SPSR & (1<<SPIF)))
  return SPDR ;
ranjeetray
I think your WriteByte routine is failing to complete the process - it reads SPSR but doesn't read SPDR once there's a byte so the hardware never clears ready for the next byte?  To quote the datasheet:
the SPIF bit is cleared by first reading the SPI Status Register with SPIF set, then accessing the SPI Data Register (SPDR)
  How about rewriting WriteByte thus:
  SPDR = value ;
  return SPDR ;
(So easy to miss a semicolon after a while, use a blank block instead, harder to misread)
Respected Sir
I have used this code also but getting the same value as 0.
Please explain me how to make SPDR to work.
  SPDR = value ;
  return SPDR ;
nickgammon
 byte ReadByte(void) {
 while(!(SPSR & (1<<SPIF)))
   return SPDR;
Do you see a similar problem here?
MarkT said:
ranjeetray
#18
Aug 29, 2012, 09:40 am Last Edit: Aug 29, 2012, 09:55 am by ranjeetray Reason: 1
   return SPDR;
MarkT said:
Respected Sir
When I use ; it goes in infinite loop and does not give any output and without ; it gives output as
Output:
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Read value
Sir ,
Is this code correct, please suggest if something is wrong:
#include <SPI.h>// include the SPI library:
const int spidata = 10;//Pin 11 is data(MOSI) and pin 13 SCK ,set pin 10(SS) as the slave select for the digital pot:
 pinMode (spidata, INPUT);// set the spi_data_pin as an output:
 SPI.setDataMode(SPI_MODE3);
 SPI.setClockDivider(SPI_CLOCK_DIV8);
 SPI.begin();// initialize SPI:
 Serial.begin(9600);}
 while(!(SPSR & (1<<SPIF)));
   return SPDR;
     int rxData;
   digitalWrite(spidata,LOW);
     rxData = ReadByte();
     Serial.println("Read value ");
    Serial.println(rxData, DEC);
   digitalWrite(spidata,HIGH);
  delay(1500);
nickgammon
Will you please explain why you are not using SPI.transfer() ?
MarkT
That's a good point - SPI.transfer will work for both master and slave I think (master mode doesn't require the SPDR to be read, but transfer does this anyway).
graynomad
There was an almost exact same problem on this thread
http://arduino.cc/forum/index.php/topic,118712.0.html
Same code even.
I still don't know why it didn't work but using SPI.transfer() fixed it.
______
Rob
ranjeetray
Same code even.
______
Rob
Dear Sir
Thanks a lot for your kind support.
Can you please provide us the both master and slave codes, it will be great help for me.
Thanks & Regards..
ranjeetray
#23
Aug 30, 2012, 07:15 am Last Edit: Aug 30, 2012, 07:21 am by ranjeetray Reason: 1
Respected Sir
Thanks a lot for your kind support. Now I am able to receive data form master but after receiving I want to send some data to master back, how can we do this. I have used SPI.transfer() in the master/data-sending code.
Working code.
Sending data code:
int mm =0;
 pinMode (spidata, OUTPUT);// set the spi_data_pin as an output:
     SPI.transfer(0x3b); //  send in the address and value via SPI:
     digitalWrite(spidata,HIGH);// take the SS pin high to de-select the chip:
     delay(1500);
Receiving data code:
#include <SPI.h>
#include <stdio.h>
#include <avr/io.h>
#include <stdlib.h>
#define MOSI 11
#define MISO  12
#define SCK  13
#define SS 10
int data = 0;
char buff[8];
 pinMode(MOSI, INPUT);
 pinMode(MISO, OUTPUT);
 pinMode(SCK,INPUT);
 pinMode(SS,INPUT);
 SPCR = 0x40;  // Enable SPI in slave mode
//  SPI.begin();
 Serial.println("Data Received from Master Board");
 data = SPI_SlaveReceive();
  Serial.println(data, HEX);
 data = 0;
unsigned char SPI_SlaveReceive()
 return SPDR;
Output from receiving code:
3B
3B
3B
3B
And now what should I do modification in the code so that I can send some data to master once I receive 0x3B from master.
I am trying like this at receiving(slave) side, it is receiving 0x3B from master but not able to send data to master
#include <SPI.h>
#include <stdio.h>
#include <avr/io.h>
#include <stdlib.h>
#define MOSI 11
#define MISO  12
#define SCK  13
#define SS 10
#define sss 9
int data = 0;
char buff[8];
 pinMode(SCK,INPUT);
 pinMode(SS,INPUT);
 pinMode(sss, OUTPUT);
//  SPI.begin();
int xx;
 xx = data;
 data = 0;
 delay(20);
 if(xx == 59)
   delay(600);
   void master_init();
   unsigned char send2();
   delay(600);
 unsigned char send2(){
 digitalWrite(SS, LOW);
 WriteByte(16);
 digitalWrite(SS, HIGH);
 delay(600);}
 return SPDR;
void master_init()
   pinMode(MOSI, OUTPUT);
 pinMode(MISO, INPUT);
 pinMode(SCK,OUTPUT);
 pinMode(SS,OUTPUT);
void WriteByte(byte value) {
 SPDR = value;
 while (!(SPSR & (1<<SPIF))) ;
 return;
And at the master side I am doing like this but it is not able to receive the data
#define sss 9
int mm =0;
unsigned char data1 = 0;
    //for(mm=0; mm<23;mm++){
     //Serial.println("I am writting on SPI");
     //Serial.println(mm, BIN);
    // SPI.transfer('IMU');
     delay(600);
     //digitalWrite(sss,LOW);
     unsigned char read1();
     delay(600);
     //digitalWrite(sss,HIGH);
       void slave_init();
     data1 = read_ready();
     Serial.println(data1, DEC);
     data1 = 0;
     delay(60);
     unsigned char read_ready()
       return SPDR;
  void slave_init()
    SPCR = 0x40;
   pinMode(11, INPUT);
   pinMode(12, OUTPUT);
   pinMode(13, INPUT);
   pinMode(10, INPUT);
   delay(600);
Kindly suggest me for the modification.
ranjeetray
Dear Sir
Thanks a lot for your kind support. Kindly go through the post  Reply #23 on: Today at 05:15:07 PM and please suggest for the modification on the code.
Thanks and Regards.
nickgammon
ranjeetray
Kindly go through the post  Reply #23 ...
Kindly stop ignoring our suggestions.
Dear Sir
Where do you want me to use this SPI.transfer() function in my code, And I am not trying to avoid yours suggestion. Please guide me and help me out.
Thanks & Regards..
ranjeetray
Respected Sir,
This code is able to send the data but not able to receive, what is wrong in this;
//send receive
#define SCK_PIN   13
#define MISO_PIN  12
#define MOSI_PIN  11
//#define SS_PIN    10
unsigned char receive_data(void);
unsigned char rd = 0;
void SlaveInit(void) {
  // Set MISO output, all others input
  pinMode(SCK_PIN, INPUT);
  pinMode(MOSI_PIN, OUTPUT);
  pinMode(MISO_PIN, INPUT);
  pinMode(spidata, INPUT);
  // Enable SPI
  SPCR = B00101100;
     SPCR = (1<<SPE);
     //SPCR = 0x00;
   pinMode(SCK_PIN, OUTPUT);
  pinMode(MOSI_PIN, INPUT);
  pinMode(MISO_PIN, OUTPUT);
  pinMode(spidata, OUTPUT);
  //pinMode (spidata, OUTPUT);// set the spi_data_pin as an output:
  //SPI.setBitOrder(LSBFIRST);
  //SPCR = 0x90;
void loop() {digitalWrite(spidata,LOW);
            delay(400);
           receive_data();
    unsigned char read_data(void)
    {  //SPCR = 0x60;
      return SPDR; }
    unsigned char receive_data(){
     SlaveInit();
     rd = read_data();
      Serial.println(rd, DEC);
      rd = 0;
      delay(400);
      return 0;
ranjeetray
Even this code is working fine .
Then, what IS your problem?
Respected Sir,
Can we read/transmit here 16 bit data on Arduino board using SPI protocol. Will it generate 16 continuous clock signal.
graynomad
The Arduino has an 8-bit SPI peripheral and therefore only transmits 8 bits at a time.
However you can just transmit two bytes in a row, the end result is the same.
______
Rob
