Topic: transforming interfering singnals into sound (Read 527 times) previous topic - next topic
starsraindown
Aug 28, 2012, 03:10 pm Last Edit: Aug 28, 2012, 03:14 pm by starsraindown Reason: 1
hey there,
for an installation I am going to tape a huge copper tape circuit on a wall that works as an interface to control various devices by touching/approaching the sensors. one end of the copper tape goes to the sensor, the other one to the arduino. I want to connect 10 sensors and some leds wit the arduino in a circuit of circa 2x4m. imagine it like this but much bigger: http://hlt.media.mit.edu/?p=2505. now: the idea is to transform the interfering signals of this circuit into a drone-like sound. how would you scan the interfering signal to an audio jack so that I can Input it into effects pedals etc??
DuaneB
This project reads two analog inputs and uses them to control the speed and pitch or a track that is generated on the Arduino - you could use the same approach but instead of cycling through a pre defined sequence, use some of the other inputs to drive the sequence or apply effects.
http://rcarduino.blogspot.com/2012/08/the-must-build-arduino-project-illutron.html
The code is still not up on github, so if you want it, PM Me
Duane B.
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
