Topic: Swimming Pool Water Level Sensor (Read 8679 times) previous topic - next topic
ScottG
I have an Arduino that measures various things around my pool: Pressure across filter, water temp before and after heater, etc.  It also controls the circulation pump and a sprinkler valve that adds make-up water.  I would like to be able to measure the water level so I know when I need to add water and do it automatically.  I can't run any wires out to the pool, but I thought I could put a wireless system in the cover to the pool strainer (see attached picture).  I could make a new cover and attach some sort of enclosure to the underside.  Maybe even 3D print it.  In the enclosure would be a sensor that would point down on the water in the strainer and tell me the distance from the sensor to the water.  It would then send this info to my main Arduino via RF.
I have been using panStamps in another project and they work great.  They are essentially an Arduino Pro Mini v3.3 with an RF transceiver.  A panStamp should be able to run a couple months on a CR123 battery if I use sleep mode (that's still to be verified).  I think this would work well to send the water level to my main Arduino.
My problem is I don't know how to measure the water level.  I need a sensor that can detect the water and won't get messed up if there are leaves in there.  In the day the water is moving around and it might be hard to read, but I could set things up so I only process the reading when the pump is off and things are nice and still.  I'd like to be able to measure the level to 1/8" resolution, but 1/4" would be okay too.  The sensor would be around 5 inches from the water.  It won't be submerged, but it will get splashed.  When kids play in the pool there are a lot of waves, so I'm pretty sure the surface of the sensor will get wet from time to time.  And it would be humid all the time.  The sensor should be able to operate on 3 volts.
Any suggestions on how to do this?
dertester
Do you need to measure the height or is it enough to measure one fixed point, lets say your minimal level?
There are liquid-level sensors: http://www.omega.com/Green/pdf/LV170.pdf
Think they could work with arduino or something similar.
Well there are ultrasonic distance sensors, but i found many threads and no solution with water-resistant ones like used in cars.
Generally there are waterprooved sensors, i wrote earlier here:
http://arduino.cc/forum/index.php/topic,119753.msg905918.html#msg905918
That could be mounted on the cover of your pool strainer? When pump is off i guess these could deliver pretty good distances.
yosler
How about something float-able and if the water is high enough, the thing will hit a wire and tell you it's too high.
Code: [Select]
int levelPin = 9;
  pinMode(levelPin, INPUT);
  int level = digitalRead(levelPin);
  if (level == HIGH)
    Serial.println("Water is too high!");
I'm 13 and I'll frequently be wordy, not writing to the point.
But don't worry, I know somethings about electronics.
ScottG
I don't think that would work to well.  Ideally I'd like to have a sensor that used sound or light to measure the distance.  If that's not realistic, I could have some sort of probe going down into the water.  Not sure what kind of probes are available for something like this, if any.
ScottG
My first choice would be a sensor that had a variable output that told me the level.  But I'm starting to think that's not a realistic option, especially with a couple CR123 batteries powering everything.  A float switch like this one at McMaster.com might be best: 50195K93.   I could have a small mounting pipe come out of my housing under the lid, with this float switch on the end of it.
ScottG
The waterproof ultrasonic sensor might work.  I think I'll get one and try it out.
aralrj
How about this tape level ?
http://www.adafruit.com/products/463
JohnHoward
Does the pool have a bottom drain line accessible such that you could plumb-in a small vertical tube making, in effect, a 'U-tube manometer' - and measure the height of the water column?
dc42
The tape level suggested by aralrj looks like a good solution to me. Alternatively, I have been successful using a capacitive sensor and 555 timer to sense water level, see http://forum.arduino.cc/index.php?topic=71628.msg536307#msg536307.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
yosler
How about a good ping sensor and, since water may confuse the sensor, similar to what I said before, have something float on the water(where the sensor is pointing). Program it so that if the sensor says that the distance to the water is too close for more than a few seconds.
cptdondo
Washing machines use cheap pressure transducers.  Google for pressure transducer - you can usually get them in specified ranges.  The transducer would have to be under water.
Other reliable options are an ultrasonic meter or a bubbler; both are in the thousands of $.
yosler
Ping))) sensor:
http://www.parallax.com/tabid/768/productid/92/default.aspx
Very accurate down to the Centimeter up to 3.3 meters. ~$30
ScottG
I ended up using a simple float switch.  Since my sensor is battery powered I wanted something very low power.  I ended up using a panStamp which is like and Arduino pro mini with a radio transceiver built in.  I set it up to sleep for 8 seconds, wake up, check the level, transmit the status then go back to sleep. The whole thing is attached to my skimmer cover.  I also added an accelerometer and set it up for low power setting.  I did this so the sensor would know when the cover was not in place.  I didn't want it to send out a low water signal when I removed the cover to clean out the skimmer basket.  I'm using a CR123 battery and the voltage drops about 1/100 volts per day (the panStamp is also transmitting the battery voltage).  So that's not bad.  The panStamp does have a different sleep mode which uses even less power.  Also the accelerometer is powered all the time, even though it doesn't use much, I could probably power it with an output pin, only turning on power to the accelerometer when I wanted to check it.
I attached a couple pictures of my setup.
JohnHoward
Nicely done!  Why poll for water level every 8 seconds?  Does your pool have a big leak  :smiley-eek: ?  Seems you could conserve even more power and only wake up every few minutes or longer.
ScottG
8 seconds is the max sleep time for the panStamp.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
