Loading...
Pages: [1]   Go Down
Author Topic: Ayuda con Codigo Alcholimetro =(  (Read 398 times)
Offline Offline
Newbie
View Profile
Tengo este codigo para un Alcoholimetro con sensor MQ3 y me da el siguiente error:
CODIGO:
Code:
#include <Button.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
// Set pin to the LCD's rxPin
int pin = 2;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// Set button pin
Button btn(7);
  lcd.clear();
  //Push the button to start
  lcd.print("Apasa-ti butonul");
  lcd.print("pentru a incepe!");
  btn.setup();            // setup & describe the button's normal state
  btn.normallyOpen();        // button closes circuit when pressed
    //btn.normallyClosed();    // button opens circuit when pressed
  btn.buttonCold();        // button shorts to sink
    //btn.buttonHot();        // button shorts to voltage
  bool isButtonPressed ( void ); // is the button in the opposite of normal state ?
  bool buttonMoved ( void ); // did the button change ?
#define skipCount 2
#define sampleCount 5
  btn.loop();
  int sensorValue = 0;   // The sensor value
  sensorValue = analogRead(A0);
    // only while the button is pushed
    if (btn.isButtonPressed()) {
        // read the sensor X times and average the total, skipping the 1st Y readings
        for (int i=0; i< skipCount ; i++) analogRead(A0);
        for (int i=0; i< sampleCount ; i++)
          sensorValue += analogRead(A0);
        sensorValue /= sampleCount + 1;
  //detection concentartion scope is between 0.04 to 4 mg/L
  float mappedValue = map(sensorValue, 120, 1023, (0.04*100.00),(4.00*100.00))/100.00;
  lcd.clear();
  lcd.print("Alcool: ");
  if (mappedValue >= 0.04)
    lcd.print(mappedValue);
      lcd.print("0.00");
  lcd.print("mg/L");
  //averaged raw value
  lcd.print(sensorValue);
  delay(2000);
ERROR: 'class button' has no member named setup smiley-confuse
Gracias de antemano smiley-wink
Logged
Albacete
Offline Offline
Full Member
Arduino mola que te pasas
View Profile
WWW
El error se debe a que la clase button no tiene un método que se llama setup... (me limito a traducir literalmente el error). No conozco esa libreria, pero  revisa a ver si te falta algun underscore o algo parecido... Animo, que esos errores suelen ser una bobada.
Logged
Offline Offline
Newbie
View Profile
Gracias, por contestar
Espero a mas gente smiley-wink
Logged
Euskadi
Offline Offline
God Member
Arduinotarrak
View Profile
Hola,
Si nos dices de dónde podemos bajarnos esa librería, alguien le podría echar un vistazo.
Logged
Offline Offline
Newbie
View Profile
Ok aqui te dejo el link: http://arduino.cc/playground/uploads/Code/Button.zip
Logged
Albacete
Offline Offline
Full Member
View Profile
WWW
Me da la impresion de que el codigo que has copiado esta escrito para una libreria llamada button, pero no es la que estas usando. En el enlace que mandas, efectivamente, no existe un metodo llamado setup, pero tampoco existe normallyOpen ni buttonCold.
Logged
Offline Offline
Sr. Member
View Profile
la libreria no tiene miembros llamado setup().tu puede tratar de compilar el sketch eliminando "btn.setup()"
Logged
Offline Offline
Newbie
View Profile
Buenas a todos, resulta que la libreria estaba debajo del codigo, vaya cabeza tengo smiley-razz
De aqui a unos dias apro un foro y pongo el codigo con sus librerias para que podais usarlo smiley-wink
Logged
Pages: [1]   Go Up
Print
Jump to:
