Author Topic: WiFi Shield - Buffering outsending data  (Read 685 times)
I am porting my old ethernet shield code to support the new WiFi shield (pretty cool).
The porting is quite easy but I noticed a different behavior in sending data which definitely impacts my project.
I send some messages from Arduino :
    sprintf(buffer,"%s=%d#", variable, (int)value);
    client.write((const uint8_t *)buffer, strlen(buffer)*sizeof(char));
using the ethernet shield each message is received almost instantly from the server which can follow a changing quantity on Arduino.
Using the WiFi, the first message is not received instantly but after a delay together with other messages.
After a new delay (without any message), a new bunch of messages is received. With this behaviour the server is not able doesn't follow the quantity on Arduino.
It seems that messages are queued somewhere.
Any suggestion how to change this behavior or how to flush data ?
Thank you
Seattle, WA USA
Seattle, WA USA
Oh, that shield. Umm, which one is that?
What library are you using?
Take a look here:
http://arduino.cc/en/Main/ArduinoWiFiShield
Miramar Beach, Florida
It will buffer somewhere to build a packet. The w5100 ethernet chip does that internally.
How long is the delay? WiFi is not exactly the most immediate response device, especially if the WiFi shield is not the only device connected.
Is that a "couple blinks of the eye" delay?
A "go to lunch" delay?
A "come back tomorrow" delay?
Does it depend on the amount of data you are sending?
Seattle, WA USA
Seattle, WA USA
OK. That describes the hardware. Nothing about your software...
The Netherlands
There are 10 types of people in the world: Those who understand binary, and those who don't.
Since the WiFiShield has a low power consuming chip, I suspect it needs to 'power up' after each period of inactivity. When powered up it will send the data without delay...
- Michel
@SurferTim
1) Delay is about "couple blinks of the eye"
2) Delay persists even after some time of operation so I don't think that the delay is related to any sort of wake up procedure
3) All messages I am sending are about 10 characters (see code below). I have built a test code with more data, same behavior
@PaulS
1) Official WiFi Library (http://arduino.cc/en/Reference/WiFi)
2) I have almost removed all the code. Now there is only something like this:
     while(true) {
@MSpijk
The delay persists even after that WiFi shield has been powered for some time
Thank you all guys for your cooperation
Seattle, WA USA
Seattle, WA USA
Why are you running an infinite loop inside an infinite loop?
This was a stupid mistake I made in the code I posted.
Any more useful suggestion ?
Hi all,
I have done some more tests.
Ethernet Shield code
IPAddress ip(192,168,1,220);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
EthernetServer server(80);
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    while (client.connected()) {
      // Receiving data
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
      // Sending data
      for(int i=0; i<500; i++) {
        char buffer[30];
        sprintf(buffer,"%s=%d#", "Pot", i);
    delay(1);
    client.stop();
    Serial.println("client disconnected");
The client receives messages continuously
2012-09-01 10:40:06.540 ConnectTest[3870:403] Pot=0#
2012-09-01 10:40:06.544 ConnectTest[3870:403] Pot=1#
2012-09-01 10:40:06.545 ConnectTest[3870:403] Pot=2#Pot=3#Pot=4#Pot=5#Pot=6#Pot=7#Pot=8#Pot=9#Pot=10#Pot=11#Pot=12#Pot=13#
2012-09-01 10:40:06.546 ConnectTest[3870:403] Pot=14#
2012-09-01 10:40:06.548 ConnectTest[3870:403] Pot=15#Pot=16#Pot=17#
2012-09-01 10:40:06.549 ConnectTest[3870:403] Pot=18#Pot=19#Pot=20#Pot=21#
2012-09-01 10:40:06.551 ConnectTest[3870:403] Pot=22#Pot=23#Pot=24#Pot=25#Pot=26#
2012-09-01 10:40:06.553 ConnectTest[3870:403] Pot=27#Pot=28#Pot=29#Pot=30#Pot=31#
2012-09-01 10:40:06.556 ConnectTest[3870:403] Pot=32#Pot=33#Pot=34#Pot=35#Pot=36#Pot=37#
2012-09-01 10:40:06.557 ConnectTest[3870:403] Pot=38#Pot=39#Pot=40#Pot=41#Pot=42#Pot=43#Pot=44#Pot=45#
2012-09-01 10:40:06.559 ConnectTest[3870:403] Pot=46#Pot=47#Pot=48#Pot=49#Pot=50#
2012-09-01 10:40:06.560 ConnectTest[3870:403] Pot=51#Pot=52#Pot=53#Pot=54#Pot=55#
2012-09-01 10:40:06.562 ConnectTest[3870:403] Pot=56#Pot=57#Pot=58#Pot=59#
2012-09-01 10:40:06.563 ConnectTest[3870:403] Pot=60#Pot=61#Pot=62#Pot=63#
2012-09-01 10:40:06.567 ConnectTest[3870:403] Pot=64#Pot=65#Pot=66#Pot=67#
2012-09-01 10:40:06.570 ConnectTest[3870:403] Pot=68#Pot=69#Pot=70#Pot=71#Pot=72#Pot=73#Pot=74#Pot=75#Pot=76#
WiFi Shield code
WiFiServer server(80);
  WiFiClient client = server.available();
  if (client) {
      // Receiving data
        Serial.write(c);
      // Sending data
        char buffer[30];
    delay(1);
    client.stop();
    Serial.println("client disonnected");
The client receives messages in bunch and a delay of about 2 secs between different bunches.
2012-09-01 10:32:40.359 ConnectTest[3475:403] Pot=0#Pot=1#Pot=2#Pot=3#Pot=4#Pot=5#Pot=6#Pot=7#Pot=8#Pot=9#Pot=10#Pot=11#Pot=12#Pot=13#Pot=14#Pot=15#Pot=16#Pot=17#Pot=18#Pot=19#Pot=20#Pot=21#Pot=22#Pot=23#Pot=24#Pot=25#Pot=26#Pot=27#Pot=28#Pot=29#Pot=30#Pot=31#
2012-09-01 10:32:40.360 ConnectTest[3475:403] Pot=32#
2012-09-01 10:32:42.096 ConnectTest[3475:403] Pot=33#Pot=34#Pot=35#Pot=36#Pot=37#Pot=38#Pot=39#Pot=40#Pot=41#Pot=42#Pot=43#Pot=44#Pot=45#Pot=46#Pot=47#Pot=48#Pot=49#Pot=50#Pot=51#Pot=52#Pot=53#Pot=54#Pot=55#Pot=56#Pot=57#Pot=58#Pot=59#Pot=60#Pot=61#Pot=62#Pot=63#Pot=64#
2012-09-01 10:32:42.098 ConnectTest[3475:403] Pot=65#
2012-09-01 10:32:44.120 ConnectTest[3475:403] Pot=66#Pot=67#Pot=68#Pot=69#Pot=70#Pot=71#Pot=72#Pot=73#Pot=74#Pot=75#Pot=76#Pot=77#Pot=78#Pot=79#Pot=80#Pot=81#Pot=82#Pot=83#Pot=84#Pot=85#Pot=86#Pot=87#Pot=88#Pot=89#Pot=90#Pot=91#Pot=92#Pot=93#Pot=94#Pot=95#Pot=96#Pot=97#
2012-09-01 10:32:44.126 ConnectTest[3475:403] Pot=98#
2012-09-01 10:32:46.144 ConnectTest[3475:403] Pot=99#Pot=100#Pot=101#Pot=102#Pot=103#Pot=104#Pot=105#Pot=106#Pot=107#Pot=108#Pot=109#Pot=110#Pot=111#Pot=112#Pot=113#Pot=114#Pot=115#Pot=116#Pot=117#Pot=118#Pot=119#Pot=120#Pot=121#Pot=122#Pot=123#Pot=124#Pot=125#Pot=126#Pot=127#Pot=128#Pot=129#Pot=130#
2012-09-01 10:32:46.147 ConnectTest[3475:403] Pot=131#
2012-09-01 10:32:48.169 ConnectTest[3475:403] Pot=132#Pot=133#Pot=134#Pot=135#Pot=136#Pot=137#Pot=138#Pot=139#Pot=140#Pot=141#Pot=142#Pot=143#Pot=144#Pot=145#Pot=146#Pot=147#Pot=148#Pot=149#Pot=150#Pot=151#Pot=152#Pot=153#Pot=154#Pot=155#Pot=156#Pot=157#Pot=158#Pot=159#Pot=160#Pot=161#Pot=162#Pot=163#
2012-09-01 10:32:48.171 ConnectTest[3475:403] Pot=164#
This indicates that somewhere there is a buffer which has to be filled before data are sent to the client.
Does anyone know how to change this behavior ?
Toronto, Canada
Any reason why you use write instead of print? Have you tried flush after the write or print?
what's the matter, it doesn't work in my router!Cartiers
No, I haven't., I have tried print with the same result.
Yes I have. No change.
Seattle, WA USA
Seattle, WA USA
I wouldn't expect any change. The Serial.flush() method simply blocks until the output buffer is empty. It doesn't force anything to happen.
Hello, I am experiencing the same issue. When I try to send a message every second, I will get a few messages concatenated together on the server side after 3 seconds (about 180 characters) And when I only send one message, I never receive it, The connection just opens and then eventually times out with no data being transferred. [To be clear, the same code with the EthernetClient works as expected, sending individual messages as client.print(char*) is called]
I was hoping the OP had figured out a solution, or if anyone has new insight into a possible fix (aside from modifying the server to parse apart multiple messages received in the same packet). If necessary I can point you to my code.
Thank you.
